Re: what would you use to measure a distance 600..1300mm?
Posted: Sun Mar 14, 2021 2:58 pm
i ordered 2 pieces from aliexpress as i decided i'd like to play with them, apparently these little sensors may have a variety of uses.DiTBho wrote: Sun Mar 14, 2021 2:06 pmyeah, I need 5mm of precision, but I don't know if the above dispersion data plot is really trust-able. Something tells me this sensor is 10mm of precision if not worse. I'd like to investigate, so I have just bought a couple from Amazonag123 wrote: Sun Mar 14, 2021 12:25 pm they may not meet the 'industrial' requirements, hence u'd need to decide if you would play with those![]()
Kind of sensor fusion? Nice idea.ag123 wrote: Sun Mar 14, 2021 12:25 pm take several measurements and with different sensors and taking an average?
(concur with the ebay digressions).
i'd think it may be 'worth' trying out as the specs don't seem too bad, and costs is moderate. i'm not really good nor rigorous with stats, but that given that the stats is based on standard deviations (i.e. normal distribution), taking multiple sample i'd guess may make the sample mean closer to the actual mean.
my guess is this may make it more accurate, but there is no basis for this intuition and i'm just speculating.
my guess is using perhaps 2 sensors taking multiple samples and averaging them may literally work.
