f1 = HAL_RCC_GetSysClockFreq();
f2 = HAL_RCC_GetHCLKFreq();
Serial.printf("SYSCLK: %d HCLK : %d\n",f1,f2);
So with HSI it is possible to run core with 64 MHz ?
then in rm0444SysTick timer (STK)
When enabled, the timer counts down from the reload value to zero, reloads (wraps to) the value in the
SYST_RVR on the next clock cycle, then decrements on subsequent clock cycles. Writing a value of zero to the
SYST_RVR disables the counter on the next wrap. When the counter transitions to zero, the COUNTFLAG status
bit is set to 1. Reading SYST_CSR clears the COUNTFLAG bit to 0.Writing to the SYST_CVR clears the register
and the COUNTFLAG status bit to 0. The write does not trigger the SysTick exception logic. Reading the register
returns its value at the time that it is accessed.SysTick control and status register (STK_CSR)Code: Select all
Address Name Type Required privilege Reset value Description 0xE000E010 STK_CSR RW Privileged 0x00000000 Section 4.4.1: SysTick control and status register (STK_CSR) 0xE000E014 STK_RVR RW Privileged Unknown Section 4.4.2: SysTick reload value register (STK_RVR) 0xE000E018 STK_CVR RW Privileged Unknown Section 4.4.3: SysTick current value register (STK_CVR) 0xE000E01C STK_CALIB RO Privileged 0xC0000000(1) Section 4.4.4: SysTick calibration value register (STK_CALIB)
SysTick reload value register (STK_RVR)Code: Select all
Bits31:17 Reserved, must be kept cleared. Bit 16 COUNTFLAG Returns 1 if timer counted to 0 since the last read of this register. Bits 15:3 Reserved, must be kept cleared. Bit 2 CLKSOURCE Selects the SysTick timer clock source: 0 = External reference clock. 1 = Processor clock. Bit 1 TICKINT Enables SysTick exception request: 0 = Counting down to zero does not assert the SysTick exception request. 1 = Counting down to zero to asserts the SysTick exception request. Bit 0 ENABLE Enables the counter: 0 = Counter disabled. 1 = Counter enabled
The STK_RVR specifies the start value to load into the SYST_CVR. See the register summary in
Table 32. System timer registers summary for its attributes. The bit assignments are:Code: Select all
Bits 23:0 RELOAD Value to load into the STK_CVR when the counter is enabled and when it reaches 0, see Calculating the RELOAD value Bits31:24 Reserved, must be kept cleared.
it seemed External reference clock and Processor clock maps to HCLK and HCLK / 8 but it is uncertain which is mapped to which.SysTick (Cortex® core system timer), with these clock sources to select from:
– HCLK (AHB clock)
– HCLK clock divided by 8
The selection is done through SysTick control and status register.
HCLK is used as Cortex®-M0+ free-running clock (FCLK). For more details, refer to the
programming manual PM0223.
Today (it's cooler outside and also inside flat) it works with HSE.
void SystemClock_Config(void)
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
RCC_OscInitStruct.PLL.PLLN = 16;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
