Updated question, How to set PA15 to GPIO Output, and PWM questions...
Re: Updated question, How to set PA15 to GPIO Output, and PWM questions...
Theoretically that would be sufficient.
Make a short sketch only to test PA11 functionality on a bluepill.
Mangy_Dog
Post by Mangy_Dog »
ummm
back to my generic as I struggled to get my one last maple mini working over usb....
PA11 is working again... randomly........... and PA15 not working again!
Its not enabledebugports function has just stopped doing anything :/
added
its getting stranger and stranger......... Still cant use those jtag pins thast just stopped working for no reason...
But if i build from within sloeber, PA11 doesnt work right... If i build from arduino IDE............ PA11 works.... But i still cant get jtag pins working :/
this is turning incredibly infuriating.
Mangy_Dog
Post by Mangy_Dog »
Right forgot to uncomment that remap... the other pins are working now...
Got to hotwire PA1 to PB1 and figure out why building in sloeber is foofing up PA11 PWM, when building in arduino ide works............ sighs! Why cant things just work. I already got tons of work to do with the main program :p
Mangy_Dog
Re: Updated question, How to set PA15 to GPIO Output, and PWM questions... Update Page3
Post by Mangy_Dog »
Bit of a bump returning to this problem as its evolved with the new version of this project....
Basically im back at having trouble getting PB5 to run PWM.
I have this code setup in the boards.cpp file.
extern const stm32_pin_info PIN_MAP[BOARD_NR_GPIO_PINS] = {
        {&gpioa, &timer2, &adc1,  0, 1,    0}, /* PA0 */
        {&gpioa, &timer2, &adc1,  1, 2,    1}, /* PA1 */
        {&gpioa, &timer2, &adc1,  2, 3,    2}, /* PA2 */
        {&gpioa, &timer2, &adc1,  3, 4,    3}, /* PA3 */
        {&gpioa,   NULL, &adc1,  4, 0,    4}, /* PA4 */
        {&gpioa,   NULL, &adc1,  5, 0,    5}, /* PA5 */
        {&gpioa,   NULL, &adc1,  6, 0,    6}, /* PA6 */
        {&gpioa,   NULL, &adc1,  7, 0,    7}, /* PA7 */
        {&gpioa, &timer1, NULL,  8, 1, ADCx}, /* PA8 */
        {&gpioa, &timer1, NULL,  9, 2, ADCx}, /* PA9 */
        {&gpioa, &timer1, NULL, 10, 3, ADCx}, /* PA10 */
        {&gpioa, &timer1, NULL, 11, 4, ADCx}, /* PA11 */
        {&gpioa,   NULL, NULL, 12, 0, ADCx}, /* PA12 */
        {&gpioa,   NULL, NULL, 13, 0, ADCx}, /* PA13 */
        {&gpioa,   NULL, NULL, 14, 0, ADCx}, /* PA14 */
        {&gpioa, &timer2, NULL, 15, 1, ADCx}, /* PA15 */
        {&gpiob, &timer3, &adc1,  0, 3,    8}, /* PB0 */
        {&gpiob, &timer3, &adc1,  1, 4,    9}, /* PB1 */
        {&gpiob,   NULL, NULL,  2, 0, ADCx}, /* PB2 */
        {&gpiob,   NULL, NULL,  3, 0, ADCx}, /* PB3 */
        {&gpiob, &timer3, NULL,  4, 1, ADCx}, /* PB4 */
        {&gpiob, &timer3, NULL,  5, 2, ADCx}, /* PB5 */
        {&gpiob, &timer4, NULL,  6, 1, ADCx}, /* PB6 */
        {&gpiob, &timer4, NULL,  7, 2, ADCx}, /* PB7 */
        {&gpiob, &timer4, NULL,  8, 3, ADCx}, /* PB8 */
        {&gpiob, &timer4, NULL,  9, 4, ADCx}, /* PB9 */
        {&gpiob,  NULL, NULL, 10, 0, ADCx}, /* PB10 */
        {&gpiob,  NULL, NULL, 11, 0, ADCx}, /* PB11 */
        {&gpiob,   NULL, NULL, 12, 0, ADCx}, /* PB12 */
        {&gpiob,  NULL, NULL, 13, 0, ADCx}, /* PB13 */
        {&gpiob,   NULL, NULL, 14, 0, ADCx}, /* PB14 */
        {&gpiob,   NULL, NULL, 15, 0, ADCx}, /* PB15 */
        {&gpioc,   NULL, NULL, 13, 0, ADCx}, /* PC13 */
        {&gpioc,   NULL, NULL, 14, 0, ADCx}, /* PC14 */
        {&gpioc,   NULL, NULL, 15, 0, ADCx}, /* PC15 */
extern const uint8 boardPWMPins[BOARD_NR_PWM_PINS] __FLASH__ = {
    PB0, PB5, PA6, PA3, PA2, PA1, PA0, PB7, PB6, PA10, PA9, PA8
and this in my ino file...
    afio_cfg_debug_ports(AFIO_DEBUG_SW_ONLY);
    afio_remap(AFIO_REMAP_TIM3_PARTIAL);
    afio_remap(AFIO_REMAP_TIM2_PARTIAL_1);
The pin is working, as I can set it HIGH or LOW and it would turn the led on... but I cant get it to run PWM. Just stays blank.
Any ideas?
In PIN_MAP PB15 has no timer and no channel defined. So it is normal that PWM is not working :)
Mangy_Dog
Post by Mangy_Dog »
stevestrong wrote: Thu Dec 08, 2022 6:12 pm In PIN_MAP PB15 has no timer and no channel defined. So it is normal that PWM is not working :)
PB5 not PB15
try calling
	Timer3.init();
Mangy_Dog wrote: Thu Dec 08, 2022 6:48 pm
PB5 not PB15
It seems that I need glasses, earlier than I thougt ;)
Mangy_Dog
Post by Mangy_Dog »
ag123 wrote: Fri Dec 09, 2022 1:57 am try calling
	Timer3.init();
That sseemed to break PWm for the other leds using that timer3...
I dont think the timer itself is the problem just the pin for some reason isnt getting routed to it. Even though its listed in the PinMap
Unless theres another place that needs setting.... Or afio remap needs calling for it.
Mangy_Dog
Post by Mangy_Dog »
Ive now even tried
 timer_set_compare(&timer3, 2, 32767);
So if i understand correctly it bypasses the table and "SHOULD" just force the timer on that pin at 50% duty?
Its still not working.
Is there something else taking that pin away from the timer?
Im out of ideas.
