Page 3 of 9
Posted: Mon Dec 30, 2019 7:25 pm
by Pito
64b or 32 fpu is basically the "same" speed.
64b vs. 32b in sw - 64b is ~2x slower and the lib code is ~2x larger.
PS: added the whetstone built with Roger's core but with the xpack-arm-none-eabi-gcc-9.2.1-1.1, F407ZET @168MHz, FPU on,
default
Loops: 1000 Iterations: 10 Duration: 8396 millisec.   0 clocks
C Converted Single Precision Whetstones: 119.10 mflops
0       0       0       1.00    -1.00   -1.00   -1.00   0
12000   14000   12000   -0.13   -0.18   -0.43   -0.48   12000
14000   12000   12000   0.02    -0.03   -0.04   -0.09   14000
345000  1       1       1.00    -1.00   -1.00   -1.00   345000
210000  1       2       6.00    6.00    -0.04   -0.09   210000
32000   1       2       0.09    0.09    0.09    0.09    32000
899000  1       2       1.00    1.00    1.00    1.00    899000
616000  1       2       3.00    2.00    3.00    -0.09   616000
0       2       3       1.00    -1.00   -1.00   -1.00   0
93000   2       3       1.00    1.00    1.00    1.00    93000
-O3
Loops: 1000 Iterations: 10 Duration: 4580 millisec.   0 clocks
C Converted Single Precision Whetstones: 218.34 mflops
LTO does not work.
Posted: Tue Dec 31, 2019 4:00 pm
it works STM32F401 black pill - steve's libmaple core
https://youtu.be/LEJK8lathQc
and happy new year everyone :D
Beginning Whetstone benchmark at 84 MHz ... -Os
Loops:10000, Iterations:1, Duration:15026.61 millisec
C Converted Single Precision Whetstones:66.55 Mflops
Beginning Whetstone benchmark at 84 MHz ... -O3
Loops:10000, Iterations:1, Duration:8381.00 millisec
C Converted Single Precision Whetstones:119.32 Mflops
getting that much Mflops for only 84 mhz for $3 still feel quite worth it :lol:
#include <Arduino.h>
#include <usb_serial.h>
#include "whetstone.h"
void checkcmd(void);
void printtempvbat(void);
void enablefpu(void);
void fade();
//int ledPin = 33; // LED connected to 'pin' 33 on maple mini
//int ledPin = 6; // LED connected to 'pin' PA5 olimexino
int ledPin = LED_BUILTIN; //PA6
int led1 = LED_BUILTIN; //PA7
#define PER 20
#define REP 10
int print = false;
int8_t led = 0;
bool dir = false;
int8_t n = PER;
int cnt = 0;
// the setup() method runs once when the sketch starts
//	enablefpu();
	SerialUSB.begin(0);
	//initialize the digital pin as an output:
	pinMode(ledPin, OUTPUT);
	pinMode(led1, OUTPUT);
	digitalWrite(ledPin, HIGH);
	// ADC_CCR_VBATE;  // f401 allows only vbat or temp sensor read, setting VBATE reads vbat
	ADC_COMMON->CCR |= ADC_CCR_TSVREFE; //| ADC_CCR_VBATE;    // enable VREFINT, VBAT or temp sensor
	//adc_calibrate(ADC1);
	adc_set_sampling_time(ADC1, ADC_SMPR_480); // sample time for temp sensor
void blinks(int8 led_pin) {
	bool led = true;
	for(int i=0; i<10;i++) {
		digitalWrite(led_pin, led);
		led = ~led;
		delay(100);
// Enable the FPU (Cortex-M4 - STM32F4xx and higher)
// http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/BEHBJHIG.html
//void enablefpu() {
//	  __asm volatile
//	    "  ldr.w r0, =0xE000ED88    \n"  /* The FPU enable bits are in the CPACR. */
//	    "  ldr r1, [r0]             \n"  /* read CAPCR */
//	    "  orr r1, r1, #( 0xf << 20 )\n" /* Set bits 20-23 to enable CP10 and CP11 coprocessors */
//	    "  str r1, [r0]              \n" /* Write back the modified value to the CPACR */
//	    "  dsb                       \n" /* wait for store to complete */
//	    "  isb"                          /* reset pipeline now the FPU is enabled */
//the loop() method runs over and over again,
//as long as maple has power
	checkcmd();
	if (print && n == 0) printtempvbat();
	fade();
void fade() {
  digitalWrite(LED_BUILTIN,led);
  led = ~led & 1;
  if(led)
    delay(PER-n);
  else
    delay(n);
  if(cnt>REP) {
    if(dir) {
      n++;
      if(n>PER) {
        dir = false;
        n = PER;
    } else {
      n--;
      if(n<0) {
        dir = true;
        n = 0;
    cnt = 0;
  } else
    cnt++;
void printtempvbat() {
	//SerialUSB.println("Hello world F407");
	//ADC1 channel 18 is vrefint 1.23v
	uint16_t vrefint = adc_read(ADC1, 17);
	Serial.print("Vref int (1.21v):");
	Serial.print(vrefint);
	Serial.println();
	//ADC1 channel 16 is temperature sensor
	uint16_t vtemp = adc_read(ADC1, 18);
	Serial.print("temp sensor:");
	Serial.print(vtemp);
	Serial.println();
	uint16_t mv = (1210 * vtemp) / vrefint;
	Serial.print("mvolt:");
	Serial.print(mv);
	Serial.println();
	// specs 5.3.22 temp sensor characteristics
	// V 25 deg ~ 0.76v
	// slope 2.5 mv/C
	uint16_t v25 = 760;
	float temp = (mv - v25) * 1.0 / 2.5 + 25.0;
	Serial.print("temp:");
	Serial.print(temp);
	Serial.println();
void checkcmd() {
	if(Serial.available()) {
		char r = Serial.read();
		if(r=='p') {
			print = true;
		} else if (r=='s') {
			print = false;
		} else if (r=='w') {
			whetstone(84); //84 mhz
void blinks() {
	for (int i = 0; i < 5; i++) {
		delay(100);
		delay(100);
whetstone.h, whetstone.cpp
https://github.com/stevstrong/Arduino_S ... /whetstone
serial commands:
'p' print temperature
's' stop printing
'w' run whetstone benchmark
install:
- press reset + boot0
- release reset, hold boot0
- check for dfu device
dfu-util -a 0 -s 0x8000000 -D blackpill_f401o3.bin
a recent dfu-util is needed
or stm32cubeprogrammer
https://github.com/stm32duino/wiki/wiki ... programmer
Posted: Tue Dec 31, 2019 4:13 pm
It is also suported with ST core ;)
Posted: Tue Dec 31, 2019 4:19 pm
i'd try that out soon, happy new year :D
Posted: Tue Dec 31, 2019 7:22 pm
by Pito
As above with -O3 and with your setting: 10000 loops, iterations 1
Loops: 10000 Iterations: 1 Duration: 4171 millisec.   0 clocks
C Converted Single Precision Whetstones: 239.75 mflops
120000  140000  120000  -0.00   0.00    -0.00   0.00    120000
140000  120000  120000  -0.00   0.00    0.00    0.00    140000
3450000 1       1       1.00    -1.00   -1.00   -1.00   3450000
2100000 1       2       6.00    6.00    0.00    0.00    2100000
320000  1       2       0.00    0.00    0.00    0.00    320000
8990000 1       2       1.00    1.00    1.00    1.00    8990000
6160000 1       2       3.00    2.00    3.00    0.00    6160000
930000  2       3       1.00    1.00    1.00    1.00    930000
PF 2020!
Posted: Tue Dec 31, 2019 7:35 pm
by Pito
ag123 wrote: Tue Dec 31, 2019 4:00 pm it works STM32F401 black pill - steve's libmaple core
Looks nice..
Quality?
Fake stm32F401 chip? :D
Does it fit into the solderless breadboard fine?
Posted: Wed Jan 01, 2020 2:16 am
Pito wrote: Tue Dec 31, 2019 7:35 pm Looks nice..
Quality?
pretty good quality, that 32k crystal is so tiny and has a mirror reflective surface
and the 25mhz crystal isn't those cheap bulky tin cans
both of them looked like those
https://support.epson.biz/td/api/doc_ch ... AN&lang=en
https://support.epson.biz/td/api/doc_ch ... 8T&lang=en
legendary jap epson crystals, we'd maybe try to measure it against NIST atomic clocks :lol:
https://www.youtube.com/watch?v=lzHqhNoyx2o
pcb routing looks good
the stm32f401 doesn't look fake :lol:
i've not soldered it yet, but it looks to fit the breadboards, the other nice thing is there is a smd solder pads for a spi flash
i'm going to try this 8MB psram instead
https://www.aliexpress.com/item/33028533291.html
the ad that i bought the board from is this, the f411 board cost ~$1 more, there are several vendors selling it, so one may like to do a search instead
https://www.aliexpress.com/item/4000103610226.html
Posted: Wed Jan 01, 2020 2:33 am
seem like this is the board layout
board layout
board layout
note that the 3rd button on the right named key isn't there
Posted: Wed Jan 01, 2020 3:11 am
this seemed to be a relevant schematic, i've not verified all the details, some details seemed a little different
Posted: Wed Jan 01, 2020 9:31 am
by Bingo600
Happy new year.
Does usb-serial , bootloader & upload work too ?
I'll have to try (on the 11') when i get back home
/Bingo
