PWM and code in the main loop
julian_lpp
Re: PWM and code in the main loop
Post by julian_lpp »
Just added SetPixelColor as to let modify each led individually....
Tested with RGBW (dont have now rgb neopixels)
regards, julian
#include <Arduino.h>
#include <HardwareTimer.h>
//con o sin white
#define ES_RGBW 1
#define LED_COUNT 7
#if ES_RGBW == 1
    #define BITS_PER_LED 32
    uint8_t leds[LED_COUNT][4];
#else
    #define BITS_PER_LED 24
    uint8_t leds[LED_COUNT][3];
#define BUFFER_SIZE (LED_COUNT * BITS_PER_LED + 2)  // allow space for 2 dummy entries
// WS2812 Timing Values (for 72MHz clock)
#define T0H 28  // ~0.35µs high
#define T0L 56  // ~0.9µs low
#define T1H 56  // ~0.9µs high
#define T1L 28  // ~0.35µs low
uint16_t pwmBuffer[BUFFER_SIZE];
// Use TIM4
HardwareTimer timer(TIM4);
// DMA Interrupt Handler
extern "C" void DMA1_Channel7_IRQHandler();
#if ES_RGBW == 1
    void setColor(uint8_t r, uint8_t g, uint8_t b, uint8_t w);
    void setPixelColor(unsigned int a_pixel_num, uint8_t r, uint8_t g, uint8_t b, uint8_t w);
#else
    void setColor(uint8_t r, uint8_t g, uint8_t b);
    void setPixelColor(uint8_t r, uint8_t g, uint8_t b);
void sendBuffer();
    digitalWrite(PB6, LOW);
    pinMode(PB6, OUTPUT);
    // Enable DMA Clock
    RCC->AHBENR |= RCC_AHBENR_DMA1EN;
    // Configure DMA for TIM4 CH1 (PB6)
    /*DMA1_Channel7->CPAR = (uint32_t)&TIM4->CCR1;  Peripheral address (TIM4 Capture Compare Register)
    Acà se relaciona al DMA con el timer4, para que ante cada lectura de DMA, se llene
    el registro CCR1 del TIMER 4 con el valor del BUFFER, que es lo que determina que el pin permanece HIGH,
    una vez que se llega a ese valor, el pin pasa a LOW
    DMA1_Channel7->CMAR = (uint32_t)pwmBuffer;  //"Channel x Memory Address Register" (CMAR) and is used to store the memory address where the DMA will read from or write to.
    DMA1_Channel7->CNDTR = BUFFER_SIZE;         // Number of data items to transfer
    DMA1_Channel7->CCR = DMA_CCR_MINC           // Memory increment mode
                        | DMA_CCR_DIR           // Memory to Peripheral
                        | DMA_CCR_TCIE          // Transfer complete interrupt
                        | DMA_CCR_PSIZE_0       // Peripheral size = 16-bit
                        | DMA_CCR_MSIZE_0       // Memory size = 16-bit
                        | DMA_CCR_PL;           // Priority level
    // Enable DMA Interrupt
    NVIC_EnableIRQ(DMA1_Channel7_IRQn);
    // Configure TIM4 (Now outputs PWM on PB6)
    timer.setPWM(1, PB6, 800000, 0);           // 800kHz. 0% dutycycle = no pulse
    setColor(0, 255, 0, 0); // Green
    sendBuffer();
    delay(500);
    setColor(0, 0, 255, 0); // Blue
    sendBuffer();
    delay(500);
    setColor(255, 0, 0, 0); // red
    sendBuffer();
    delay(500);
    setColor(0, 0, 0, 255); // white
    sendBuffer();
    delay(500);
    for (int i = 0; i < LED_COUNT; i++) {
        setPixelColor(i, random(255), random(255), random(255), random(255));
    sendBuffer();
    delay(500);
#if ES_RGBW == 1
    void setColor(uint8_t r, uint8_t g, uint8_t b, uint8_t w){
        // Fill all LEDs with the same color
            leds[i][0] = g; // WS2812 uses GRB format
            leds[i][1] = r;
            leds[i][2] = b;
            leds[i][3] = w;
    void setPixelColor(unsigned int a_pixel_index, uint8_t r, uint8_t g, uint8_t b, uint8_t w){
        if (a_pixel_index<LED_COUNT){
            leds[a_pixel_index][0] = g; // WS2812 uses GRB format
            leds[a_pixel_index][1] = r;
            leds[a_pixel_index][2] = b;
            leds[a_pixel_index][3] = w;
    void fillBuffer(){
        // Convert to PWM signal
        int index = 0;
            for (int j = 0; j < 4; j++) {
                for (int bit = 7; bit >= 0; bit--) {
                    if (leds[i][j] & (1 << bit)) {
                        pwmBuffer[index++] = T1H; // High for "1"
                    } else {
                        pwmBuffer[index++] = T0H; // High for "0"
       pwmBuffer[index++] = 0;            // add dummy pulse
#else
    // Convert RGB to PWM timing buffer
    void setColor(uint8_t r, uint8_t g, uint8_t b, uint8_t a_unused) {
            leds[i][1] = r;
            leds[i][2] = b;
        int index = 0;
            for (int j = 0; j < 3; j++) {
                    } else {
// Start DMA Transfer
void sendBuffer() {
    fillBuffer();
    // **Reset Pulse**: Ensure at least 50µs LOW before sending data
    delayMicroseconds(50);                 // 50µs to be safe
    TIM4->CR1 &= ~TIM_CR1_CEN;             // ensure TIM4 stopped
    TIM4->DIER |= TIM_DIER_UDE; /*cuando el buffer se transfirio completamente, se deshabilita este bit TIM4->DIER &= ~TIM_DIER_UDE; (ver dma irq handler)*/
    // Reset DMA
    Reset the DMA channel: Before initiating a new DMA transfer,
    it's often necessary to disable the channel to ensure that it's in a known state.
    DMA1_Channel7->CCR &= ~DMA_CCR_EN;
    DMA1->IFCR |= DMA_IFCR_CHTIF7;         // clear half-transfer interrupt
    DMA1->IFCR |= DMA_IFCR_CTCIF7;         // clear transfer complete interrupt
    DMA1->IFCR |= DMA_IFCR_CTEIF7;         // clear error flag
    /*The CNDTR register holds the number of data items that the DMA channel is programmed to transfer. When the DMA transfer starts,
    this register is loaded with the desired number of data items. As each data item is transferred, the CNDTR register is decremented.
    When it reaches zero, the DMA transfer is complete.
    /*This line of code sets the "Enable" bit in the DMA1 Channel 1 Control Register. In simpler terms, it enables the DMA channel. */
    DMA1_Channel7->CCR |= DMA_CCR_EN;
    /*This enables the timer to generate a DMA request when an update event occurs.*/
    TIM4->CR1 |= TIM_CR1_CEN;             // start TIM4
// DMA Transfer Complete Interrupt
extern "C" void DMA1_Channel7_IRQHandler(void) {
     /*DMA_ISR_TCIF1 "Transfer Complete Interrupt Flag"....
     entonces con el & queda claro que ese bit del DMA1->ISR està en 1*/
     if (DMA1->ISR & DMA_ISR_TCIF7) { /*// acà se setea el flag de transferencia completa*/
        DMA1->IFCR = DMA_IFCR_CTCIF7;  // Clear only the Transfer Complete flag
        TIM4->CR1 &= ~TIM_CR1_CEN;     // stop TIM4
