I used the Arduino IDE 2.0.3,but some error issue to build STM32-GPSDO, the error information is:
C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino:53:1: warning: "/*" within comment [-Wcomment]
/* Commands to be implemented:
C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino:62:1: warning: "/*" within comment [-Wcomment]
C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino: In function 'void Timer_ISR_2Hz()':
C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino:862:20: error: base operand of '->' is not a pointer
lsfcount = TIM2->CCR3; // read TIM2->CCR3
C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino: In function 'void docalibration()':
18: warning: unused variable 'e1' [-Wunused-variable]
double f1, f2, e1, e2;
22: warning: unused variable 'e2' [-Wunused-variable]
C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino: In function 'void displayscreen_OLED()':
9: warning: unused variable 'tempfloat' [-Wunused-variable]
float tempfloat;
C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino: In function 'void setup()':
26: error: 'HERTZ_FORMAT' was not declared in this scope
tim2Hz->setOverflow(2, HERTZ_FORMAT); // 2 Hz
40: error: no matching function for call to 'HardwareTimer::attachInterrupt(void (&)())'
tim2Hz->attachInterrupt(Timer_ISR_2Hz);
40: note: candidate is:
In file included from C:\Users\Administrator\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F4\2022.9.26\cores\maple/wirish.h:49:0,
from C:\Users\Administrator\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F4\2022.9.26\cores\maple/WProgram.h:30,
from C:\Users\Administrator\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F4\2022.9.26\system/libmaple/Arduino.h:31,
from C:\Users\Administrator\Downloads\ArduinoIDE\GPSDO_V006c\GPSDO_V006c.ino:113:
C:\Users\Administrator\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F4\2022.9.26\cores\maple/HardwareTimer.h:200:10: note: void HardwareTimer::attachInterrupt(uint8, voidFuncPtr)
void attachInterrupt(uint8 channel, voidFuncPtr handler) {
C:\Users\Administrator\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F4\2022.9.26\cores\maple/HardwareTimer.h:200:10: note: candidate expects 2 arguments, 1 provided
26: error: 'analogReadResolution' was not declared in this scope
analogReadResolution(12); // make sure we read 12 bit values when we read from any ADC analog channel
28: error: 'analogWriteFrequency' was not declared in this scope
analogWriteFrequency(2000); // default PWM frequency is 1kHz, change it to 2kHz
27: error: 'analogWriteResolution' was not declared in this scope
analogWriteResolution(16); // set PWM resolution to 16 bits (the maximum for the STM32F411CEU6)
19: error: 'GPIO_AF1_TIM2' was not declared in this scope
pinModeAF(PA15, GPIO_AF1_TIM2); // setup PA15 as TIM2 channel 1 / ETR
27: error: 'TIMER_INPUT_CAPTURE_RISING' was not declared in this scope
FreqMeasTim->setMode(3, TIMER_INPUT_CAPTURE_RISING, PB10);
7: error: base operand of '->' is not a pointer
TIM2->ARR = 0xffffffff; // count to 2^32, then wraparound (approximately every 429 seconds)
51: error: no matching function for call to 'HardwareTimer::attachInterrupt(void (&)())'
FreqMeasTim->attachInterrupt(Timer2_Overflow_ISR);
51: note: candidate is:
TIM2->SMCR |= TIM_SMCR_ECE; // 0x4000
17: error: 'TIM_SMCR_ECE' was not declared in this scope
25: error: 'AVREF' was not declared in this scope
adcVdd = analogRead(AVREF);
exit status 1
Compilation error: base operand of '->' is not a pointer
How to solve this issue. Thanks!
