Page 6 of 9
Posted: Sun Jan 19, 2020 2:13 pm
Bingo600 wrote: Sun Jan 19, 2020 1:39 pm I got HW float enabled (i think) -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
Beginning Whetstone benchmark at 84 MHz ...
Loops:10000, Iterations:1, Duration:29795.44 millisec
C Converted Single Precision Whetstones:33.56 Mflops
Wonder what FCPU i'm running
Can't be all wrong , as USB is workingBeginning Whetstone benchmark at 84 MHz ...
Previous was -oS now with -o3
Loops:10000, Iterations:1, Duration:22780.49 millisec
C Converted Single Precision Whetstones:43.90 Mflops
/Bingo
try -O3 :)
the other thing is make sure to check in your variant
https://github.com/stevstrong/Arduino_S ... f401.h#L39
#define CYCLES_PER_MICROSECOND   84
is defined appropriately
it is used to select the clock initialization algorithm
https://github.com/stevstrong/Arduino_S ... cF4.c#L476
void rcc_clk_init(void)
	SystemCoreClock = CYCLES_PER_MICROSECOND * 1000000;
#if CYCLES_PER_MICROSECOND == 168
	  SetupClock168MHz();
#elif CYCLES_PER_MICROSECOND == 120
	  SetupClock120MHz();
#elif CYCLES_PER_MICROSECOND == 96
	  SetupClock96MHz();
#elif CYCLES_PER_MICROSECOND == 84
	  SetupClock84MHz();
#elif CYCLES_PER_MICROSECOND == 72
	  SetupClock72MHz();
#else
	#error Wrong CYCLES_PER_MICROSECOND!
e.g. for 84 Mhz
https://github.com/stevstrong/Arduino_S ... cF4.c#L214
void SetupClock84MHz()
	/*            PLL (clocked by HSE) used as System clock source                */
	/************************* PLL Parameters *************************************/
	// PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N = 25[MHz]/25 * 336 = 336
	int PLL_M = 25;
	int PLL_N = 336;
	// SYSCLK = PLL_VCO / PLL_P = 336 / 4 = 84
	int PLL_P = 4;
	// USB OTG FS, SDIO and RNG Clock = PLL_VCO / PLLQ = 336 / 7 = 48
	int PLL_Q = 7;
^^ it would choose this set of clock configurations
this is the important part, for black pill the crystal runs at 25 Mhz
if you are using a board that has a different crystal speed say 8 Mhz, it may run too slow or too fast
next thing is you can now tweak the clocks if you want, the python script to search clock settings
viewtopic.php?p=393#p393
there are more examples in this thread, i.e. the PLL prescalers and multipliers m, n, p, q
viewtopic.php?f=7&t=92
but if you tweak clocksi.e. the PLL prescalers and multipliers m, n, p, q
^^ you would also need to update the cycles per microsecond manually in your variant,
this matters a lot, because it is used in various places, in particular to set the pre-scaler for systick so that systick counts every milliseconds.
and the timers use that same CYCLES_PER_MICROSECOND macro as well.
and you may need to temporary edit
so that it would always call the clock setting algorithm that you are changing e.g.
Posted: Sun Jan 19, 2020 2:34 pm
by Bingo600
If i'm using your binaries , i get the same speed as you.
So the HW is the same
This is something in my setup (or compiler choice)
From the build logs it seems like i use this GCC vers : .arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/
Came in w. the "Atmel Arduino ARM setup i think"
/Bingo
Posted: Sun Jan 19, 2020 2:36 pm
note that if you choose the clocks for 96mhz
e.g. by selecting a variant with
it would choose this clock setting algorithm instead
https://github.com/stevstrong/Arduino_S ... cF4.c#L277
void SetupClock96MHz()
	// PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N = 8[MHz]/4 * 192 = 384
	int PLL_M = 4;
	int PLL_N = 192;
	// SYSCLK = PLL_VCO / PLL_P = 384 / 4 = 96
	int PLL_P = 4;
	// USB OTG FS, SDIO and RNG Clock = PLL_VCO / PLLQ = 384 / 8 = 48
	int PLL_Q = 8;
^^^ note in the comment that this set of pre-scalers is intended for a 8 mhz crystal
to check that use my python script
and for 8mhz you would get this line
FHSE: 8 m: 4 n: 192 p: 4 (RCC_PLLP_DIV4) q: 8 fusb: 48.0 fcpu: 96.0
look at that it matches
next step is go back to the python script
change the script to read
#!/usr/bin/python3
#FHSE in mhz
FHSE = 25
#cpu search frequency range
fmin = 90
fmax = 110
run that python script again, you would get this set of clocks
FHSE: 25 m: 25 n: 192 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0
FHSE: 25 m: 25 n: 384 p: 4 (RCC_PLLP_DIV4) q: 8 fusb: 48.0 fcpu: 96.0
FHSE: 25 m: 25 n: 432 p: 4 (RCC_PLLP_DIV4) q: 9 fusb: 48.0 fcpu: 108.0
FHSE: 25 m: 50 n: 384 p: 2 (RCC_PLLP_DIV2) q: 4 fusb: 48.0 fcpu: 96.0
assuming that your variant has already defined
go back in
	int PLL_M = 4;
	int PLL_N = 192;
	int PLL_P = 4;
	int PLL_Q = 8;
and patch the clocks you prefer for the m, n, p, q values from the search suggestions from the python script
if you feel naughty you can patch that python script suggestion for 108 Mhz clocks settings instead, i.e. over clock :lol:
Posted: Sun Jan 19, 2020 2:47 pm
by Bingo600
I'm just trying to get 84MHz to work for now , i'll leave 96MHz for a later excercise,
Here's my build log attached
build-bingo.txt.zip
(3.76 KiB) Downloaded 1105 times
Posted: Sun Jan 19, 2020 2:51 pm
the build log looks ok, fpu flags, -O3 all selected, so it is the rcc clocks settings that cause the difference ;)
if you are using the disco_f411 variant
https://github.com/stevstrong/Arduino_S ... f411.h#L41
#define CYCLES_PER_MICROSECOND   96
^^ it would choose this cycles per us
so it goes back to that
void SetupClock96MHz() {
2 comments above, try patching the clocks settings (m, n, p, q) and u'd likely get better clocks
Posted: Sun Jan 19, 2020 3:10 pm
by Bingo600
I'm using the blackpill_401 variant in Arduino (Steves) , and running on the F411 blackpill.
The strange thing is really that USB is working , so the RCC clock settings aren't totally FSCK'ed up ...
/Bingo
Posted: Sun Jan 19, 2020 3:11 pm
well then you are running at 84 mhz, it would sound a little strange for the low mflops reading in this case
based on what i read so far, it seemed the m, n, p, q settings method is pretty much common in the F4* lines.
i'm not sure if i may be mistaken
one more thing, you should not define in your F401 pill variant
changing that clocks per us to 96 which is the normal run speed for F411
because changing that would use the
clocks setting algorithm which is intended for 8mhz crystal.
nevertheless, if you do that, you could go back in the SetupClock96MHz() and update the m, n, p, q pll pre-scalers to match your crystal frequency like suggested. a few comments above
note that the python script as mentioned search clocks such that fusb = 48mhz
i.e. it returns the clocks settings for which usb will continue to operate i.e. 48 mhz
playing with clocks is fun, try the clock settings > 100 mhz (i.e. overclock) and run that whetstone benchmark
those experiments are tedious and they look like this that i've one on f401 black pill
viewtopic.php?p=539#p539
in a recent commit steve made the ART accelerator go on steroids: prefetch + data cache + instruction cache on.
but steve is a little careful, the disableART() function disables only prefetch, which is deemed a power/battery consuming ops
so disableART() switch off prefetch, but still runs fast due to data cache + instruction cache enabled - that is a power saving recommendation
by st too
https://www.st.com/content/ccc/resource ... 096220.pdf
search for 'ART configuration'
Posted: Sun Jan 19, 2020 4:21 pm
by Bingo600
Could you build this , and report the performance ??
I get w. HW FP enabled , and -03 - and -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
Loops:10000, Iterations:1, Duration:22665.84 millisec
C Converted Single Precision Whetstones:44.12 Mflops
Posted: Sun Jan 19, 2020 4:28 pm
Beginning Whetstone benchmark at 84 MHz ...-OS
Loops:10000, Iterations:1, Duration:74355.56 millisec
C Converted Single Precision Whetstones:13.45 Mflops
Beginning Whetstone benchmark at 84 MHz ...-O3
Loops:10000, Iterations:1, Duration:42268.75 millisec
C Converted Single Precision Whetstones:23.66 Mflops
something is missing somewhere
:lol:
Posted: Sun Jan 19, 2020 4:45 pm
by Bingo600
13Mflop
Was what i got on -OS wo HW float .. I think
Is that Steve's Core ??
Well at least we get the same ...
I have been chasing ghosts all day ... Thinking my build system was BORKED
/Bingo
