dhrystone and whetstone benchmarks
Bingo600
Re: dhrystone and whetstone benchmarks
Post by Bingo600 »
fpiSTM wrote: Sun Jan 26, 2020 7:14 pm This is provided by ARM:
https://github.com/ARM-software/CMSIS_5 ... SP/Lib/GCC
Damm ...
".a" files ==> Compiled libraries
No source ..
Well i'd prob not understand the "magic" anyway
/Bingo
Bingo600
Post by Bingo600 »
Mispost
Bingo600
Post by Bingo600 »
What does this flag do ??
ST Core does not specify :
-fsingle-precision-constant
GenF4.build.flags.fp=-mfpu=fpv4-sp-d16 -mfloat-abi=hard
F411 Built as cortex-m7
No -fsingle-precision-constant
-O2
Fast N1 , slow N5 , slow MWIPS
Single Precision C Whetstone Benchmark
Calibrate
       0.15 Seconds          1   Passes (x 100)
       0.77 Seconds          5   Passes (x 100)
       3.86 Seconds         25   Passes (x 100)
Use 64  passes (x 100)
          Single Precision C/C++ Whetstone Benchmark
Loop content                  Result              MFLOPS      MOPS   Seconds
N1 floating point     -1.12475013732910156        48.000              0.026
N2 floating point     -1.12274742126464844        33.340              0.258
N3 if then else        1.00000000000000000                  94.628    0.070
N4 fixed point        12.00000000000000000                 160.001    0.126
N5 sin,cos etc.        0.49909299612045288                   0.924    5.764
N6 floating point      0.99999982118606567        31.994              1.079
N7 assignments         3.00000000000000000                  41.210    0.287
N8 exp,sqrt etc.       0.75110614299774170                   1.052    2.264
MWIPS                                             64.819              9.874
-O2
Slow(er) N1 , fast N5 , fast MWIPS
Calibrate
       0.10 Seconds          1   Passes (x 100)
       0.50 Seconds          5   Passes (x 100)
       2.51 Seconds         25   Passes (x 100)
Use 99  passes (x 100)
N1 floating point     -1.12475013732910156        45.150              0.042
N2 floating point     -1.12274742126464844        33.347              0.399
N3 if then else        1.00000000000000000                  95.761    0.107
N4 fixed point        12.00000000000000000                 143.710    0.217
N5 sin,cos etc.        0.49909299612045288                   2.268    3.631
N6 floating point      0.99999982118606567        33.862              1.577
N7 assignments         3.00000000000000000                  41.113    0.445
N8 exp,sqrt etc.       0.75110614299774170                   1.043    3.532
MWIPS                                             99.496              9.950
F411 built normal s a m4
-O2
Calibrate
       2.48 Seconds         25   Passes (x 100)
Use 100  passes (x 100)
N1 floating point     -1.12475013732910156        46.489              0.041
N2 floating point     -1.12274742126464844        33.350              0.403
N3 if then else        1.00000000000000000                  95.833    0.108
N4 fixed point        12.00000000000000000                 159.898    0.197
N5 sin,cos etc.        0.49909299612045288                   2.261    3.680
N6 floating point      0.99999982118606567        35.984              1.499
N7 assignments         3.00000000000000000                  41.158    0.449
N8 exp,sqrt etc.       0.75110614299774170                   1.051    3.538
MWIPS                                            100.854              9.915
ST Core - Default
-O2
Calibrate
       3.85 Seconds         25   Passes (x 100)
N1 floating point     -1.12475013732910156        46.545              0.026
N3 if then else        1.00000000000000000                  96.000    0.069
N4 fixed point        12.00000000000000000                 180.001    0.112
N5 sin,cos etc.        0.49909299612045288                   0.915    5.817
N6 floating point      0.99999982118606567        33.878              1.019
N8 exp,sqrt etc.       0.75110614299774170                   1.051    2.265
MWIPS                                             64.952              9.853
arm-gcc docs says
https://gcc.gnu.org/onlinedocs/gcc-4.7. ... tions.html
    Treat floating-point constants as single precision instead of implicitly converting them to double-precision constants.
Bingo600
Post by Bingo600 »
Well this day went totally cortex + FPU :)
But at lest i got BLACKPILL_F411CE implemented in the ST Core @96MHz + ART Enabled
I ran my first program on my "Ali Black-F407"
I got my DISCO-F407 dusted off
And i learned a lot about the boards.txt & variants directories
I'm off ... ZZZzzzzzz
Goodbye & Thanx for "all the fish" (help/comments)
/Bingo
Post by Pito »
Bingo600 wrote: Sun Jan 26, 2020 7:28 pm
Damm ...
No source ..
/Bingo
https://github.com/ARM-software/CMSIS_5 ... DSP/Source
my attempt, at benchmarking a variety of chips, and outside of the typical dhrystone / whetstone routines: https://dannyelectronics.wordpress.com/ ... -exercise/
Interesting to see how the chips fall. the numbers are measured in cycle counts.
new benchmark STM32H743VIT6 - 480 Mhz
viewtopic.php?p=8886#p8886
Beginning Whetstone benchmark at 480 MHz ...
Loops:10000, Iterations:1, Duration:1203.82 millisec
C Converted Single Precision Whetstones:830.69 Mflops
Loops:10000, Iterations:1, Duration:1203.48 millisec
C Converted Single Precision Whetstones:830.93 Mflops
-O2 optimised, cache turned on
that 'doubled' fpu speeds is likely real as the FPU in all the series from F4 to F7, H7 is done using the VFP processor. i.e. vector floating point
so in a single instruction it can process 2 lanes of data - vectorized.
spiceagent11
Post by spiceagent11 »
the optimization using vfp libraries may also have used things like fma (floating multiply and add) instructions for the whetstone benchmarks, that does both multiply and add in a single instruction which would make matrix - vector calcs run like they do 2 flops per clock
so after all we do have pretty fast single precision floating pointsVidMate | Bluestacks 3 | hdmoviearea
Yup, i recently ventured reading some stuff about VFP, this is a different 'generation' of FPU, things like fused multiply and add are common, hence, the whetstone benchmark could have been boosted by that alone. And with vectorized 2 lanes, when the compiler compiles the codes that way, every floating-point instruction basically runs in parallel in 1 clock cycle. That makes for the 'apparent' high speeds, the speeds are likely real, but accordingly vector floating point suffers from non-compliance to ieee754 in its rounding (flush to zero) and saturating arithmetic.
richieadam
Post by richieadam »
When looking at the historical whetstone result data - the big CPUs get higher MWIPS, but much lower MFLOPs at the same clock.
Also I do not understand you got 100 MWIPS @96MHz (411) and @168MHz (407) we get 98.
There must be a subtle bug in the code somewhere.
The historical results show nice linear dependency MWIPS on clock.
I do assume we should see something like 150 MWIPS @168MHz (407).
I would suggest small changes in the code, wait..
In the original code it was double
double  theseSecs = 0.0;
double  startSecs = 0.0;
double  secs = 0.0;
Also you may use micros() to get better resolution
void getSecs()
  theseSecs =  micros() / 1000000.0;
  return;
I doubt it helps, however, you may try..
PS: is the ART enabled in the STM core ????
