STM32F446 Canbus with Core 2.0 Timing Issues
Posted: Fri May 21, 2021 4:37 am
by Tazzi
I just updated to the latest v2.0 core from v1.9, and the exact same code now results in issues on the canbus.
As soon as the CAN is initiated, the entire bus starts freaking out, it appears almost if either the pins are not being set correctly or the frequency is out, although this works perfectly fine on v1.9
Has there been any changes relating to CANbus in v2.0 of the stm32 arduino core? Or something that affects pinout?
Re: STM32F446 Canbus with Core 2.0 Timing Issues
Posted: Fri May 21, 2021 5:56 am
Which board you select in the menu?
Maybe clock config has changed.
Posted: Fri May 21, 2021 6:22 am
by Tazzi
I am selecting:
Board: Generic STM32F4 Series
Board Part Number: Generic F446RETX
I believe it could be clock related, Im trying to compare all changes from v1.9 to 2.0 in git but it is quite extensive.
Posted: Fri May 21, 2021 8:11 am
Change has been made in this commits
https://github.com/stm32duino/Arduino_C ... 17540678c6
All generic definitions have been unified and only uses the HSI.
Before generic clock config tries several config HSE bypass, HSE and finally HSI anyway we saw several issues using this method that's why it has been removed. You can try to redefine the system clock config:
https://github.com/stm32duino/wiki/wiki ... ock_config
anyway I saw no issue on the default one
Posted: Fri May 21, 2021 9:44 am
by Tazzi
Thankyou so much for that tip!
Right I understand. I have reimplemented the original clock timing functions and it is still not functioning correctly. I have copy/pasted directly from the variant.cpp file for the STM32F446 variant and its now working.
Something done in the new method doesnt seem to line up nicely with the timing.
This is the NEW method:
* Copyright (c) 2020-2021, STMicroelectronics
* All rights reserved.
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
#if defined(ARDUINO_GENERIC_F446RCTX) || defined(ARDUINO_GENERIC_F446RETX)
#include "pins_arduino.h"
* @brief System Clock Configuration
* @param None
* @retval None
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {};
__HAL_RCC_PWR_CLK_ENABLE();
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLN = 180;
RCC_OscInitStruct.PLL.PLLQ = 8;
Error_Handler();
/** Activate the Over-Drive mode
if (HAL_PWREx_EnableOverDrive() != HAL_OK) {
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLRCLK;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK) {
Error_Handler();
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_SDIO | RCC_PERIPHCLK_CLK48;
PeriphClkInitStruct.PLLSAI.PLLSAIM = 16;
PeriphClkInitStruct.PLLSAI.PLLSAIN = 192;
PeriphClkInitStruct.PLLSAI.PLLSAIQ = 2;
PeriphClkInitStruct.PLLSAI.PLLSAIP = RCC_PLLSAIP_DIV4;
PeriphClkInitStruct.PLLSAIDivQ = 1;
PeriphClkInitStruct.Clk48ClockSelection = RCC_CLK48CLKSOURCE_PLLSAIP;
PeriphClkInitStruct.SdioClockSelection = RCC_SDIOCLKSOURCE_CLK48;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK) {
Error_Handler();
#endif /* ARDUINO_GENERIC_* */
And this is the old method which I now have in my main ino up top:
/* PLL (clocked by HSE) used as System clock source */
static uint8_t SetSysClock_PLL_HSE(uint8_t bypass)
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
// Enable HSE oscillator and activate PLL with HSE as source
if (bypass == 0) {
RCC_OscInitStruct.HSEState = RCC_HSE_ON; // External 8 MHz xtal on OSC_IN/OSC_OUT
else {
RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS; // External 8 MHz clock on OSC_IN
RCC_OscInitStruct.PLL.PLLM = HSE_VALUE / 1000000L; // Expects an 8 MHz external clock by default. Redefine HSE_VALUE if not
RCC_OscInitStruct.PLL.PLLN = 360; // VCO output clock = 360 MHz (1 MHz * 360)
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2; // PLLCLK = 180 MHz (360 MHz / 2)
return 0; // FAIL
// Activate the OverDrive to reach the 180 MHz Frequency
return 0; // FAIL
// Select PLLSAI output as USB clock source
PeriphClkInitStruct.PLLSAI.PLLSAIM = HSE_VALUE / 1000000L;
PeriphClkInitStruct.PLLSAI.PLLSAIN = 384;
PeriphClkInitStruct.PLLSAI.PLLSAIP = RCC_PLLSAIP_DIV8;
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_CLK48;
HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
// Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; // 180 MHz
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4; // 45 MHz
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2; // 90 MHz
return 0; // FAIL
/* Output clock on MCO1 pin(PA8) for debugging purpose */
if (bypass == 0)
HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSE, RCC_MCODIV_2); // 4 MHz
else
HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSE, RCC_MCODIV_1); // 8 MHz
return 1; // OK
/* PLL (clocked by HSI) used as System clock source */
uint8_t SetSysClock_PLL_HSI(void)
// Enable HSI oscillator and activate PLL with HSI as source
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_OFF;
RCC_OscInitStruct.PLL.PLLM = 16; // VCO input clock = 1 MHz (16 MHz / 16)
return 0; // FAIL
return 0; // FAIL
PeriphClkInitStruct.PLLSAI.PLLSAIM = 8;
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
return 0; // FAIL
//HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSI, RCC_MCODIV_1); // 16 MHz
return 1; // OK
extern "C" void SystemClock_Config() {
// new clock config
/* 1- If fail try to start with HSE and external xtal */
if (SetSysClock_PLL_HSE(0) == 0) {
/* 2- Try to start with HSE and external clock */
if (SetSysClock_PLL_HSE(1) == 0) {
/* 3- If fail start with HSI clock */
if (SetSysClock_PLL_HSI() == 0) {
Error_Handler();
Posted: Fri May 21, 2021 9:49 am
by Tazzi
Comparing the two, it appears the new core only supports HSI? Instead of trying the external HSE first?
Might be something to add as a user configurable item as that really messed up CAN timing, and I noticed the timed based items like flashing LEDs appeared to be a touch faster which would explain also the CAN having problems.
Posted: Fri May 21, 2021 12:25 pm
Tazzi wrote: Fri May 21, 2021 9:49 am
Yes all generics use the internal clock by default as the goal of a generic is to work on all boards. If user wants use another clock source he have to redefine at sketch level the system clock config as explained in the wiki.
So in your case if your board has an HSE simply define it at sketch level.
The generic F446 has been tested with a Nucleo F446RE but not the CAN as the core has no dedicated development for this.
