Minimization of Power consumption of L476
Posted: Sun May 23, 2021 1:52 pm
I am trying to minimize the consumed power of my STM32L476 based board by reducing the clock frequency and deactivating unnecessary peripherals. What I have as peripheral are:
1. A LoRa shield
2. An SD card
I expect to reduce the power when I change the clock frequency from 80 to 4 MHz copying from CubeIDE to variant.cpp with the following clock config.:
Although I use sleep mode for LoRa and STM32 whenever is possible, the total board consumes between 6-10 mA. About 3 mA is consumed with other elements than STM32. Then STM consumes more than 3 mA. I have some questions:
1. Is this current normal? I expect this processor to consume 107 µA/MHz! By this, it should consume less than 1 mA!
2. What is the reason for not changing the power with frequency?
3. How to deactivate some peripherals like SPI3 etc., via Arduino IDE?
4. I know that in deep sleep mode, variables are gone after wake up. Then, what can be the best way to save power and keep variables other than sleep mode which I am using now?
Thanks in advance
1. A LoRa shield
2. An SD card
#ifdef __cplusplus
extern "C" {
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 2;
RCC_OscInitStruct.PLL.PLLN = 8;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV7;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV8;
Error_Handler();
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_I2C1;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
Error_Handler();
Thanks in advance
