Bootloader Stuck 1EAF:004?
DigitalOsmosis
Post by DigitalOsmosis »
Got my STLINK working, and flashed "generic_boot20_pc13" to my fresh new Blue Pill clone (F103C8). Rapid flash on boot and shows up as [1EAF:0003] in lsusb, and after a few seconds the flashing stops and the usb identifier changes to [1EAF:0004]. So far so good. So far all in Linux.
Here is where I started having problems, and I tried in both Windows and Linux with different errors, but similar effect.
Windows:
mable_loader v0.1
dfu-util - (C) 2007-2008 by Open Moko Inc.
timeout waiting for COM3 serial
Linux:
No DFU capable USB device found
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Please report bugs to dfu-util@lists.gnumonks.org
Filter on vendor = 0x1eaf product = 0x0003
Waiting for /dev/ttyACM0 serial...Done
Although the Linux output is a little less hopeful, in both operating systems the Arduino IDE appears to successfully initiate a DTR pulse reset, and the device comes back up rapidly blinking like it always does for the first few seconds, but stays blinking (as I believe would be expected). What's weird is when I check lsusb on Linux, the device is showing up [1EAF:0004] even immediately after the DTR reset, and even though it visually appears to be in the bootloader.
It seems like after a DTR reset the bootloader is coming back with the USB device identifier [1EAF:0004] instead of the expected [1EAF:0003] associated with the bootloader, and this is causing it to now show up as an eligible target.
If anybody has any suggestions, or ideas what might be going on I'd appreciate it.
Thanks!
Re: Bootloader Stuck 1EAF:004?
DFU runs in the 1st 6 seconds after reset when led is on a fast blink
in linux you can try running dfu-util -l to find out (i've not tried the same in windows)
you can also try setting boot1, roger did an enhancement so that setting boot1 makes it drop into 'perpetual' mode.
A DTR pulse is not enough, a magic sequence should be also transmitted over USB serial.
You can try to manually reset the board short before you upload the code.
DigitalOsmosis wrote: Tue May 25, 2021 12:50 am ...
In my experience, with the non-Maple Mini boards, you have 2 viable options: ST-Link and using the internal serial firmware loader. The bootloader is just a nuisance.
fredbox
Post by fredbox »
I agree: viewtopic.php?p=6984#p6984
Return to “USB bootloader”
