ifdef for selected board
dudmuck
Post by dudmuck »
is preprocessor directive defined for board selected from arduino-IDE?
I have code for multiple boards, it needs to know which board is built for so correct source is built and stuff like pin definitions. Because the nucleo boards typically have arduino-uno form-factor, but others arent and need different pins. An #ifdef used for this in code.
mlundin
Re: ifdef for selected board
Post by mlundin »
every variant have a specific define, to see them use verbose output from compilation and look at the command line sent to the compiler, all the defines can be seen there (its a looooong line of includes and defines).
check the usual places like boards.txt and platforms.txt
https://github.com/stm32duino/Arduino_Core_STM32/blob/a7283739a4d8bafe95c9f9b9156e6f82a1ebbd75/platform.txt#L92-L93
# Build information's
build.info.flags=-D{build.series} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DBOARD_NAME="{build.board}" -DVARIANT_H="{build.variant_h}"
Specifically: -DARDUINO_{build.board}
where build.board is defined in the boards.txt:
For example
GenF1.menu.pnum.BLUEPILL_F103C8.build.board=BLUEPILL_F103C8
So for this board you can use:
#ifdef ARDUINO_BLUEPILL_F103C8
