STM32F407 + DP83848
kkrusha
STM32F407 + DP83848
Post by kkrusha »
Hello
I found the STM32F407 controller with PHY DP83848, 2xCAN-BUS, RS485, uSD ... Price total 28 USD: https://www.aliexpress.com/item/1005001927391636.htm
Looks good, the only problem is that I have experience with Arduino. I can't find a tidy Ethernet library DP83848. Lots of information for other platforms, but I found an Arduino only for the Arch Max controller and adapted for the Arduino_STM32 platform. Also done very complicated and not friendly with the controller. I have done several projects with STM32Ethernet where everything works great. Maybe someone has tried to adapt this library to DP83848? Looks like it should be close to LAN8720 :)
Re: STM32F407 + DP83848
Hi @kkrusha
I don't know such library but DP83848 is planned as mentioned to https://github.com/stm32duino/STM32Ethernet/issues/34
Anyway, I don't know when it will be done.
kkrusha
Post by kkrusha »
Hello
Thanks for the reply :D
STM32Ethernet Library: https://github.com/stm32duino/STM32Ethernet
kkrusha
Post by kkrusha »
Hello
maybe for someone looks an interesting this controller - I can send his scheme. Write an email.
Frenelius
Post by Frenelius »
Hello,
Were you able to program it using Arduino?
I have that board and used it with STM32CubeIDE and it works, but the ethernet drivers seem to be unstable.
Thank you,
Rex
Post by Rex »
Can you post the *.ioc file for the above board?
The schematic image is blurred.
Tks
satelit
Post by satelit »
I am interested in the JZ-F407VET6I shematic board email rajawaly@gmail.com thanks
