Arduino_Core_STM32 2.0.0 HSI invalid, NUCLEO F072RB
miniqiang
Post by miniqiang »
test environment : Arduino_Core_STM32 1.9.0 and 2.0.0
test code
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
Remove the SB50 resistor
1.9.0 is work
2.0.0 is not wokr
I'm confused :shock: :shock: :shock: :shock:
by fpiSTM » Tue Jun 22, 2021 7:04 am
With 1.9.0 the Nucleo F072RB used the HSI.
Since 2.0.0 all variant has been unified and by default Nucleo use the HSE bypass for better stability.
As you have removed the SB50 the HSE bypass is not available. So you have to redefine the system core clock config to use the HSI.
https://github.com/stm32duino/wiki/wiki ... ock_config
Re: Arduino_Core_STM32 2.0.0 HSI invalid, NUCLEO F072RB
miniqiang
Post by miniqiang »
:D
Thinks ~! is Working
extern "C" void SystemClock_Config()
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {};
    in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48;
  RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
    Error_Handler();
                                  | RCC_CLOCKTYPE_PCLK1;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI48;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK) {
      Error_Handler();
    PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB;
    PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_HSI48;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK) {
      Error_Handler();
External crystal ok(8Mhz)
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6;
  RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
    Error_Handler();
    Error_Handler();
  /** Enables the Clock Security System
  HAL_RCC_EnableCSS();
