Arducam 2MP doesn't work with Nucleo64
mebab
Answers: 4
Post by mebab »
Hi
The example of ArduCAM_Mini_Capture2SD works fine with Arduino. It takes photos and saves them on an SD card. However, it doesn't work with Nucleo64 that offers the same pins as Arduino! It stops at the following command:
while(!myCAM.get_bit(ARDUCHIP_TRIG , CAP_DONE_MASK));
Utilized pin numbers are correct and changing the CPU frequency didn't help. Is it a library problem? what library is suitable to use with my STM32 Nucleo64?
Any help is really appreciated.
Here is the code:
// ArduCAM demo (C)2017 Lee
// Web: http://www.ArduCAM.com
// This program is a demo of how to use most of the functions
// of the library with a supported camera modules, and can run on any Arduino platform.
// This demo was made for Omnivision 2MP/5MP sensor.
// It will run the ArduCAM 2MP/5MP as a real 2MP/5MP digital camera, provide both JPEG capture.
// The demo sketch will do the following tasks:
// 1. Set the sensor to JPEG mode.
// 2. Capture and buffer the image to FIFO every 5 seconds
// 3. Store the image to Micro SD/TF card with JPEG format in sequential.
// 4. Resolution can be changed by myCAM.set_JPEG_size() function.
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM 2MP/5MP shield
// and use Arduino IDE 1.6.8 compiler or above
#include <ArduCAM.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
//This demo can only work on OV2640_MINI_2MP or OV5642_MINI_5MP or OV5642_MINI_5MP_BIT_ROTATION_FIXED platform.
#if !(defined OV5642_MINI_5MP || defined OV5642_MINI_5MP_BIT_ROTATION_FIXED || defined OV2640_MINI_2MP || defined OV3640_MINI_3MP)
  #error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#define SD_CS 4
const int SPI_CS = 7;
#if defined (OV2640_MINI_2MP)
  ArduCAM myCAM( OV2640, SPI_CS );
#elif defined (OV3640_MINI_3MP)
  ArduCAM myCAM( OV3640, SPI_CS );
#else
  ArduCAM myCAM( OV5642, SPI_CS );
void myCAMSaveToSDFile(){
char str[8];
byte buf[256];
static int i = 0;
static int k = 0;
uint8_t temp = 0,temp_last=0;
uint32_t length = 0;
bool is_header = false;
File outFile;
//Flush the FIFO
myCAM.flush_fifo();
//Clear the capture done flag
myCAM.clear_fifo_flag();
//Start capture
myCAM.start_capture();
Serial.println(F("start Capture"));
Serial.println(F("Capture Done."));
length = myCAM.read_fifo_length();
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //384K
  Serial.println(F("Over size."));
  return ;
if (length == 0 ) //0 kb
  Serial.println(F("Size is 0."));
  return ;
//Construct a file name
k = k + 1;
itoa(k, str, 10);
strcat(str, ".jpg");
//Open the new file
outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
if(!outFile){
  Serial.println(F("File open faild"));
  return;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
while ( length-- )
  temp_last = temp;
  temp =  SPI.transfer(0x00);
  //Read JPEG data from FIFO
  if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
    buf[i++] = temp;  //save the last  0XD9
    //Write the remain bytes in the buffer
    myCAM.CS_HIGH();
    outFile.write(buf, i);
    //Close the file
    outFile.close();
    Serial.println(F("Image save OK."));
    is_header = false;
    i = 0;
  if (is_header == true)
    //Write image data to buffer if not full
    if (i < 256)
    buf[i++] = temp;
    else
      //Write 256 bytes image data to file
      myCAM.CS_HIGH();
      outFile.write(buf, 256);
      i = 0;
      buf[i++] = temp;
      myCAM.CS_LOW();
  else if ((temp == 0xD8) & (temp_last == 0xFF))
    is_header = true;
    buf[i++] = temp_last;
    buf[i++] = temp;
void setup(){
uint8_t vid, pid;
uint8_t temp;
Wire.begin();
Serial.println(F("ArduCAM Start!"));
//set the CS as an output:
pinMode(SPI_CS,OUTPUT);
digitalWrite(SPI_CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1){
  //Check if the ArduCAM SPI bus is OK
  myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
  temp = myCAM.read_reg(ARDUCHIP_TEST1);
  if (temp != 0x55){
    Serial.println(F("SPI interface Error!"));
    delay(1000);continue;
  }else{
    Serial.println(F("SPI interface OK."));break;
//Initialize SD Card
while(!SD.begin(SD_CS)){
  Serial.println(F("SD Card Error!"));delay(1000);
Serial.println(F("SD Card detected."));
  while(1){
    //Check if the camera module type is OV2640
    myCAM.wrSensorReg8_8(0xff, 0x01);
    myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
    myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
    if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 ))){
      Serial.println(F("Can't find OV2640 module!"));
    else{
      Serial.println(F("OV2640 detected."));break;
  while(1){
    //Check if the camera module type is OV3640
    myCAM.rdSensorReg16_8(OV3640_CHIPID_HIGH, &vid);
    myCAM.rdSensorReg16_8(OV3640_CHIPID_LOW, &pid);
    if ((vid != 0x36) || (pid != 0x4C)){
      Serial.println(F("Can't find OV3640 module!"));
    }else{
      Serial.println(F("OV3640 detected."));break;
#else
  while(1){
    //Check if the camera module type is OV5642
    myCAM.wrSensorReg16_8(0xff, 0x01);
    myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
    myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
    if((vid != 0x56) || (pid != 0x42)){
      Serial.println(F("Can't find OV5642 module!"));
    else{
      Serial.println(F("OV5642 detected."));break;
myCAM.set_format(JPEG);
myCAM.InitCAM();
  myCAM.OV2640_set_JPEG_size(OV2640_320x240);
  myCAM.OV3640_set_JPEG_size(OV3640_320x240);
#else
  myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);   //VSYNC is active HIGH
  myCAM.OV5642_set_JPEG_size(OV5642_320x240);
void loop(){
myCAMSaveToSDFile();
delay(500);
Answers: 92
Re: Arducam 2MP doesn't work with Nucleo64
Hi @mebab
I never tested with Arducam.
Which Arducam you try ?
mebab
Answers: 4
Post by mebab »
Thanks. It is ARDUCam mini OV2640 2MP.
hobbya
Post by hobbya »
Perhaps you can try further following the guidelines posted on Arducam.com:
https://www.arducam.com/docs/stm32-spi- ... ith-stm32/
mebab
Answers: 4
Post by mebab »
Thanks @hobbya. That is prepared for the specific STM32L1 and employs Keil to run the program that I am not familiar with. I use Arduino IDE to program my NucleoL64.
