Designing a new board around existing firmware-F407 vs F417
Posted: Sun Aug 29, 2021 6:45 pm
As the title explains, I am working on a hardware-port to use existing stocks of STM32F417ZGT6 micros, when the original firmware/coding was for an STM32F407VGT6. I'm pretty green on the STM32, I have built one rather complicated project that works, and now I am picking up an old project that has come back around from when I was interested in it previously.
I found the F417ZGT6's on Ebay, still in packaging from Mouser and Digikey, for less than a buck each. I figure no one else bid because they were searching for F407? Either way, they appear to be genuine and I have a small handful.
Given that both the F407ZGT6 and the F417ZGT6 LQFP-144 devices share the same pinout, I would imagine they would substitute readily, with no hardware and only minor software changes?
If this is the case then the next task will be figuring out the existing pin map vs the new pin map, like when I moved from ATmega2560 to 2561 devices, right?
