STM32 SD-Bootloader
Read firmware from sdcard and write to internal flash
darkspr1te
STM32 SD-Bootloader
Post by darkspr1te »
Hi All,
I have completed a bootloader for stm32f107x devices that supports updating via sdcard
core of system uses platformio/stm32cube and HAL calls so porting to others should be easy.
https://github.com/darkspr1te/stm32f107vc_sd_bootloader
same bootloader but with LCD routines (supports HX and ITFT models)
https://github.com/darkspr1te/mksbootloader
bootloader includes hard fault routines which can be excluded to improve file size (24k non-lcd, 28k-lcd)
debug via UART1
any reset vector from 0x6000 and up
spi eeprom read/write supported for settings/icons/fonts
needs optimizing though.
darkspr1te
Re: STM32 SD-Bootloader
Thanks for sharing darkspr1te.
I've created a dedicated forum for this.
darkspr1te
Another bootloader,
https://github.com/darkspr1te/mkstft35_bl_vet_fsmc
for stm32f407 boards
this has support for lcd/touch/spi/sdcard/fatfs
uses adafruit gfx lib so all ada fruit tech demos are usable.
when used on MKS TFT 35 v1 boards frame rate is 140fps via fsmc
this version has make file & platformio build options for those who want to import STM cube into platform io then you can use this as a example.
enjoy, more to come
darkspr1te
Return to “STM32 SD-Bootloader”
