Upgrading to new core
DrBanana
Post by DrBanana »
I'm changing my project core to newer one of stm32duino. I'm getting many many errors, which is expected. But the problem comes when a library becomes incompatible at fullest. One of which is https://github.com/mike-matera/ArduinoSTL. It was working fine on Steve's core but not on new core v.2.0.0.
Also I have a static method of a library with USBSerial* and now getting the following error
error: 'USBSerial' does not name a type; did you mean 'Serial'?
18 | static USBSerial *DebugSerialUsb
| Serial
in CoreLib class
static USBSerial *DebugSerialUsb;
static HardwareSerial *DebugSerialHardware;
static void Init(HardwareSerial *DebugSerial);
static void Init(USBSerial *DebugSerial);
in main .ino
USBSerial *CoreLib::DebugSerialUsb = NULL;
HardwareSerial *CoreLib::DebugSerialHardware = NULL;
then later init them whenever need to.
I'm not getting error on HardwareSerial only on USBSerial.
Re: Upgrading to new core
You have to enable USB in the menu. The name is SerialUSB.
About STL, it is not required as the core already use the C++ standard library by default.
For ref:
https://github.com/stm32duino/Arduino_C ... 2/pull/129
https://github.com/mike-matera/ArduinoSTL/pull/12
DrBanana
Post by DrBanana »
how to use std::vector<> in stm core
DrBanana wrote: Tue Mar 22, 2022 11:22 am how to use std::vector<> in stm core
Simply like that:
#include <vector>
using namespace std;
template<typename T> void printVect(T const & xs) {
  Serial.print("[ ");
  for (auto const & x : xs) {
    Serial.print(x);
    Serial.print(" ");
  Serial.println("]");
  vector <int> numbers;
  printVect(numbers);
  numbers.push_back(5);
  numbers.push_back(3);
  numbers.push_back(4);
  printVect(numbers);
  numbers.pop_back();
  printVect(numbers);
Result:
[ 5 3 4 ]
[ 5 3 ]
