FPU Enable - STM32f401CCU6
madhavan
Post by madhavan »
Hi, I am trying to enable the FPU on stm32f401CCU6 .
I keept the following setting as Default in STM Official Core - Duino.
Tools----->Optimize------>Smallest(-Os default).
Tools-----> Debug Symbols ------> None
Tools ------> C Runtime Library ----->Newlib nano (default)
Really what is the exact use of use of above setting ? i do not know and it was working as default . It will be useful if there is brief information of above setting .
i thought of use FPU and i was read forum discussion and attempt to use fpu .
i have tested the following setting condition giving different result for the below attached main code (without FPU enable code ).
Tools----->Optimize------>Smallest(-Os default) = Float sum (ms): 0
Tools----->Optimize------>Smallest(-Os ) with LTO= Float sum (ms): 0
Tools----->Optimize------>Fast(-O1 ) = Float sum (ms): 17
Tools----->Optimize------>Fast(-O1 ) with LTO= Float sum (ms): 17
Tools----->Optimize------>Faster(-O2 ) = Float sum (ms): 0
Tools----->Optimize------>Faster(-O2 ) with LTO= Float sum (ms): 0
Tools----->Optimize------>Fastest-O3 ) = Float sum (ms): 0
Tools----->Optimize------>Fastest(-O3 ) with LTO= Float sum (ms): 0
Tools----->Optimize------>Debug(-Og)= Float sum (ms): 35 .
int sensorValue = 0;
  float fl_2, fl_3;
  unsigned long tloop,tf,to ;
uint32_t itop = 1000000;
fl_2    = 1.00;
fl_3    = 0.00;
to = micros();
for (uint32_t i = 0; i < itop; i++)
  fl_2    = fl_2 + fl_3;
  fl_3    = fl_2 + fl_3;
tf  = micros() - to;
Serial.print("Float sum (ms): ");
Serial.print((tf - tloop)/2000);
Serial.println();
Serial.println();
  // read the value from the sensor:
  sensorValue = analogRead(ATEMP);
  Serial.println(sensorValue);
the below attached main code is working with followed Setting included with FPU enabling code .
the below attached main code is "" Not working “ - Getting Freeze with followed setting included with FPU enabling code .
Tools----->Optimize------>Faster(-Os )
  enablefpu();
  float fl_2, fl_3;
fl_2    = 1.00;
fl_3    = 0.00;
to = micros();
  fl_2    = fl_2 + fl_3;
  fl_3    = fl_2 + fl_3;
tf  = micros() - to;
Serial.println();
Serial.println();
void enablefpu() {
    __asm volatile
     "  ldr.w r0, =0xE000ED88    \n"  /* The FPU enable bits are in the CPACR. */
     "  ldr r1, [r0]             \n"  /* read CAPCR */
     "  orr r1, r1, #( 0xf << 20 )\n" /* Set bits 20-23 to enable CP10 and CP11 coprocessors */
      "  str r1, [r0]              \n" /* Write back the modified value to the CPACR */
      "  dsb                       \n" /* wait for store to complete */
    "  isb"                          /* reset pipeline now the FPU is enabled */
Please Identify where i am doing mistake and suggest me FPU Enabling and setting usage .
Re: FPU Enable - STM32f401CCU6
the FPU is normally already enabled, in both official STM and libmaple based cores.
Accordingly, it helps to put that enable_fpu code in its own .cpp file, then include the definition and include it from a #include
madhavan
Post by madhavan »
hi, Kept default setting .
#include"enable_fpu.h"
  float fl_2, fl_3;
fl_2    = 1.00;
fl_3    = 0.00;
to = micros();
  fl_2    = fl_2 + fl_3;
  fl_3    = fl_2 + fl_3;
tf  = micros() - to;
Serial.print((tf );
Serial.println();
Serial.println();
cpp
void enablefpu() {
    __asm volatile
header
#ifndef ENABLE_FBU_H_
#define ENABLE_FBU_H_
void enablefpu();
output ------> Float sum-Micsec: 71478
without FpU output ---------> Float sum-Micsec :71478
Looks and
as you mentioned FpU is default enabled
