Has anyone got a STM32F411CE Blackpill working as a USB Host?
Nello
Post by Nello »
Hi. I've got about a million questions and may be on conceptually shaky ground, so apologies if this is a bit scattergun.
I've been trying to work this out with the STM32CubeIDE for a few weeks now and am pretty well stumped. I can't even get VBUS power working, so suffice it to say I'm not getting very far. I've tried following most of these, but most of the doc is centred around Nucleo boards:
https://www.youtube.com/watch?v=MlhUG4GsOT0
https://controllerstech.com/stm32-usb-host-hid
https://www.bennettnotes.com/notes/stm3 ... usb-serial
I managed to find this old stm32duino thread, but it doesn't seem to get anywhere that I could see: viewtopic.php?f=62&t=197&p=3001&hilit=b ... host#p3001
Searching avidly through these forums it seems that mostly people are interested in STM32's as HID devices not as USB hosts. Has anyone ever managed to get this working?
Re: Has anyone got a STM32F411CE Blackpill working as a USB Host?
I'm not familiar with the requirements of USB host, i think host is 'a lot more difficult' vs being a device. among the things, it needs to enumerate buses/devices, poll the buses/devices, power the buses etc.
nevertheless someone has done something, it isn't yet committed, but you could probably pull from the original user's repository
https://github.com/stm32duino/Arduino_C ... /pull/1196
it may not be for the F411 though. I'm not sure about the details.
mathew32
Post by mathew32 »
Have you already tried getting a Nucleo to function with it so you have a reliable starting point?
I'd go in that direction...
sharase
Post by sharase »
Make sure that all the connections between your STM32 microcontroller and the USB connector are correct and secure. Double-check your wiring to ensure that you haven't reversed any connections or made any other errors.
subway surfers
BennehBoy
Post by BennehBoy »
If you get something working, please do share with us - I was wanting to use any form of STM32 as a USB host so I could use USB keyboards with retro hardware. I gave up after much mucking about - but that's over a year ago now.
darkspr1te
Post by darkspr1te »
I think you need to look into the stm32f4xx examples packs available from STM website or git hub,
heres a old github example , note that bugs and api changes by stm to the stmcore renders some example code non-compilable so you may have to hunt down a older stm32core or patch to newer api/core
https://github.com/dbridges/stm32f4-dis ... hid_core.c
darkspr1te
