PIN_MAP in STM32 cores
bit_factory
Post by bit_factory »
Hi everybody,
passing from Roger Clark to STM32 cores I've noticed there is no structure analogue to PIN_MAP present in the last one.
My problem is to get the GPIO port of a given pin referred by his macro. For example I need to get the GPIO pointer of PA12 pin.
With Clarks library the pointer is PIN_MAP[PA12].gpio_device
Is in STM32 cores an analogue struct, macro or function to get the same result?
Any help very grateful Thank you
Re: PIN_MAP in STM32 cores
The STM32 core is based on CMSIS.
So you can directly access to GPIO port register it by their name:
GPIOA->IDR
bit_factory
I know,
but with maple I can do that:
#define RS_PIN PA6
gpio_dev* RS_GPIO = PIN_MAP[RS_PIN].gpio_device;
//now I can use RS_GPIO that points to GPIOA (the port device of PA6 pin)
I'm looking for something similiar with The STM32 core
Thank
This implementation is not available in STM32 core.
What do you want achieve ?
Maybe this is you what you looking for:
digitalPinToPort(PA12);
This will return the GPIOA register pointer.
