Vector Table Relocation -or- Use of a 3rd Party Bootloader
kjn
Post by kjn »
So I have an interesting problem. I have a F103 module, which we have a custom (CAN based) bootloader, which is written in STM32CubeIDE. I would like the option of writing code using the STM32dunio core, mostly for library/peripheral testing, but also much quicker to bring code online.
The jump from our bootloader is a pretty standard approach, and usually in our application (written in CubeIDE) we can just make sure the vector table is relocated at the start of the application:
SCB->VTOR = 0x08002800U;
I've tried a few different approaches using the STM32duino core (2.3.0), but have yet to have success. It looks like the application is crashing on start-up. Reading further into the core:
from system\SMT32F1xx\system_stm32f1xx.c:
/* Note: Following vector table addresses must be defined in line with linker
         configuration. */
/*!< Uncomment the following line and change the address
     if you need to relocate your vector Table at a custom base address (+ VECT_TAB_OFFSET) */
/* #define VECT_TAB_BASE_ADDRESS 0x08000000 */
/*!< Uncomment the following line if you need to relocate your vector Table
     in Sram else user remap will be done by default in Flash. */
/* #define VECT_TAB_SRAM */
#ifndef VECT_TAB_OFFSET
#define VECT_TAB_OFFSET         0x00000000U     /*!< Vector Table base offset field.
                                                     This value must be a multiple of 0x200. */
#ifndef VECT_TAB_BASE_ADDRESS
#if defined(VECT_TAB_SRAM)
#define VECT_TAB_BASE_ADDRESS   SRAM_BASE       /*!< Vector Table base address field.
#else
#define VECT_TAB_BASE_ADDRESS   FLASH_BASE      /*!< Vector Table base address field.
#endif /* VECT_TAB_SRAM */
#endif /* VECT_TAB_BASE_ADDRESS */
 /* Configure the Vector Table location add offset address ------------------*/
 SCB->VTOR = VECT_TAB_BASE_ADDRESS | VECT_TAB_OFFSET;
I thought just adding the two lines to the start of our sketch (blink.ino):
#define VECT_TAB_OFFSET         0x00002800U
would be sufficient, but still I can't get it to work.
I am using the "Export Compiled Binary" option to generate a BIN which we load into our bootloader host application for transmitting to the target.
Any idea why this isn't working and/or what additional defines I need to add to the sketch to get the Vector table to jump appropriately when using this core?
Cheers
Answers: 91
Re: Vector Table Relocation -or- Use of a 3rd Party Bootloader
Define it at sketch level is not correct as it is a cpp file and so define is not populated.
You should use the build_opt.h feature:
https://github.com/stm32duino/wiki/wiki ... uild_opt.h
Unfortunately, I've introduced a regression with this feature:
https://github.com/stm32duino/Arduino_C ... ssues/1749
You have to manually apply the patch in the system/extras/prebuild.sh.
Then in build_opt.h add:
-DVECT_TAB_OFFSET=0x00002800U
kjn
Post by kjn »
Good answer! Thank you.
Is there a way I can verify that this define/instruction was passed correctly? Inspect the hex/bin or the output?
I am still getting an application non start.
Answers: 91
Simply edit this file system\SMT32F1xx\system_stm32f1xx.c and add some extra characters between the #ifndef.
If it does not failed to build then this mean it is well redefine. But I have no doubt it is well redefined.
kjn
Post by kjn »
fpiSTM wrote: Thu Jun 30, 2022 11:57 am Simply edit this file system\SMT32F1xx\system_stm32f1xx.c and add some extra characters between the #ifndef.
after patching as mentioned and making a "build_opt.h" file...
I was able to verify the compilation and execution vector jump, but poking the register with CubeProgrammer after the bootloader times out.
However my Arduino application still crashes and heads back to bootloader before it does anything (at the moment its just Blink on PB2).\
NB: It just crashes and doesn't head back to bootloader if I have IWDG disabled in the BL.
I've disabled the watchdog in the BL, copied the clock configuration block from the working blink application (in Cube) into the sketch (with exern "C") as the clock config is quite different.
What else could stop my program from running? The bootloader jump is basically the same as the HID bootloader (and as mentioned works with a Cube compiled application)
If anyone could check my work that would be very much appreciated!
Here is the Application Jump in the BL:
void jump_to_application(){
    void (*main_code)(void);
    volatile uint32_t * appl_address = (uint32_t *) (MAIN_PROGRAM_START_ADDRESS_LD);
    HAL_CAN_DeInit(&hcan);
    for(IRQn_Type i = 0; i < 42; i++){
        HAL_NVIC_DisableIRQ(i);
    // Disabling SysTick interrupt
    SysTick->CTRL &= ~SysTick_CTRL_TICKINT_Msk;
    // booting really
    SCB->VTOR = (volatile uint32_t)appl_address;
    appl_address++;
    main_code=(void(*)(void))*appl_address; //give address stored in pointer
    main_code();
Edit: Here is the functional CubeIDE main.c and the non-functional blink.ino + build_opt.c (in a zip due to forum restrictions).
main.zip
(1.92 KiB) Downloaded 126 times
Blink.zip
(1016 Bytes) Downloaded 150 times
kjn
Post by kjn »
So I think I need to specify the application offset in the memory region of the linker:
/* Memories definition */
MEMORY
  RAM    (xrw)    : ORIGIN = 0x20000000,   LENGTH = LD_MAX_DATA_SIZE
  FLASH    (rx)    : ORIGIN = 0x8000000 + LD_FLASH_OFFSET, LENGTH = LD_MAX_SIZE - LD_FLASH_OFFSET
Can I do this with build_opt.h?
-DLD_FLASH_OFFSET = 0x2800?
I've tried this and it doesn't work as expected.
Answers: 91
you are right. I forgot to mention the LD_FLASH_OFFSET.
Anyway, I don't think you could redefine it using build_opt.h as it is not used for this part.
You should use the boards.local.txt:
https://arduino.github.io/arduino-cli/0 ... dslocaltxt
Like this you could simply add a new entry for your board with the correct option, example:
3dprinter.menu.pnum.PRNTR_V2.build.flash_offset=0x8000
3dprinter.menu.pnum.PRNTR_V2.build.st_extra_flags=-D{build.product_line} {build.enable_usb} {build.xSerial} -DVECT_TAB_OFFSET={build.flash_offset}
Pay attention with the last release 2.3.0, build_opt.h has a regression preventing to kept user define:
it is fixed in the main branch.
