How do I use STM32Duino with Platformio?
Alextrical
Post by Alextrical »
Hi all
I'm wondering if anyone can point me in the direction of any instructions on how to setup Platformio in Visual Studio Code to use the STM32Duino core.
I'm hoping to make use of the STM32G0B1RBTx board definition that is available in Arduino 1.8.19
Kind regards
Alextrical
by ag123 » Tue Aug 02, 2022 3:41 pm
I'm unable to comment about platformIO as I don't use it myself.
But if you are prefer VSCode, you may want to try the arduiono extension
https://github.com/stm32duino/wiki/wiki ... -extension
and to try the core here
this is the repository for 'official' STM core.
platformIO likely pull this occasionally and adapt it for PlatformIO
if you find that you are building a new variant for your board, you may like to start with this core instead and placing your new variant files in the appropriate file structure/directories. it'd likely be necessary to update boards.txt for your entry as well (normally, by examining similar entries as examples and making a new one).
if your board is after all distributed in public, and your codes are part of this core, you may want to work with @fpiSTM to contribute your variant to the repository subsequently
Re: How do I use STM32Duino with Platformio?
welcome,
I'm not sure about Platform IO, but do take a look at the wiki
https://github.com/stm32duino/wiki/wiki/PlatformIO
for a while I tried VSCode with Arduino extension
that works, but I've not used it in a while.
Alextrical
ag123 wrote: Tue Aug 02, 2022 2:30 pm I'm not sure about Platform IO, but do take a look at the wiki
Hi ag123, thank you for your message, just to confirm as the way that link is phrased confuses me slightly
it mentions
Behind the scenes this will create a dependency on the ST STM32: development platform for PlatformIO.... This repository should not be confused with the ST STM32: development platform which is located at https://github.com/platformio/platform-ststm32.
when is says "This repository" it reads as if its referencing the previous block, that is also referencing "platform-ststm32"
I think I've managed to get the Blink sketch to compile for a STM32F401CC (BlackPill) using the information from what you sent, and finally this link https://docs.platformio.org/en/latest/p ... ion-system
Thank you for the heads up on the Arduino for VSCode extension, I will look into that :)
Alextrical
The next question I have is, Is there a list of compatible board names I can use?
This definition works for the Black pill, but I'm not sure how to setup for a STM32G0B1RBTx based chip.
[env:genericSTM32F401CC]
platform = ststm32
board = genericSTM32F401CC
framework = arduino
build_flags =
  -D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
  -D PIO_FRAMEWORK_ARDUINO_NANOLIB_FLOAT_PRINTF
i think the maintainers of PlatformIO has made a fork of
and made it one of their cores.
however, this repository is the "original" STM core, i.e. any developments done here is only in this repository.
to use STM32G0B1RBTx a new variant is needed
https://github.com/stm32duino/wiki/wiki ... 28board%29
However, what I'd normally do is to look at existing definitions and try to copy that structure and make a new set for my board.
you can take a look at the codes in the variants directory.
https://github.com/stm32duino/Arduino_C ... /STM32G0xx
a variant is normally needed for a new board as for instance there is a crystal on board (HSE)
https://github.com/stm32duino/Arduino_C ... -E)(I-T)xN
https://github.com/stm32duino/Arduino_C ... ic_clock.c
you would at least need a
 void SystemClock_Config(void)
if you want to use the external crystal to setup your system clock i.e. HSE
an easier way is to look for codes that is done for existing boards replace and adapt the codes for your variant/board
Alextrical
Ah, is it that https://registry.platformio.org/platfor ... io/ststm32 manages the board definitions, and then passes over to stm32duino for the Arduino Core?
If I define my own board layout for the STM32G0B1RBT6 in the format similar to https://github.com/platformio/platform- ... 401cc.json would stm32duino be able to handle that?
Alextrical
I'm not all that up to speed with PlatformIO, but I'm hoping that VisualStudio will let me build for multiple board types with the Arduino extension like PlatformIO's ini allowed.
The exact chip I'm trying to use is actually the one used by BigTreeTech on the EBB42 v1.1 is a STM32G0B1CBT6 however the already made definition for STM32G0B1RBTx is a close enough match to work. The required board definitions for the CBT are already compiled in the stm32duino code, just not exposed as the required ldscript.ld wasn't generated
I would also be interested in getting support added for the other STM32 chips used on the BTT EBB boards in this repo
I'm more than happy to try and add support for the chips in question, as I have the hardware to confirm functionality. I take it that best practice would be to fork the git repo, and then create a pull request once the changes are made?
umar.techboy
Post by umar.techboy »
Actually, PlatformIO already has the support.
viewtopic.php?t=2025
There are two catches, 1, you have to add some defines to enable CDC serial and 2, DFU is actually STM32duino bootloader!
Return to “IDE's”
