XOn/XOff flow control
https://en.wikipedia.org/wiki/Software_flow_control
#include <Arduino.h>
enum State {
	XOff = 0,
	XOn
State state;
void setup(){
	state = State::XOff;
	pinMode(PA0, INPUT_ANALOG);
	// this part is the command processor
	if(Serial.available()) {
		int c = Serial.read();
		switch(c) {
			case 17: // Ctrl Q
				state = State::XOn;
				break;
			case 19: // Ctrl S
				break;
	if (state == State::XOn) {
		Serial.println(analogRead(PA0));
This is only on the device side, doesn't handle receive from host side
non ideal but simple to implement, requires "escaping" ctrl-Q, ctrl-S for some implementations.
for 'one way' implementations (e.g. only the device respond to commands), this probably 'just works'
the benefit is this can be tested out in most ordinary serial terminals apps, e.g. https://www.putty.org/
Return to “Code snippets”
