using spi1 and spi2 simultaneously
Posted: Mon Sep 26, 2022 11:16 am
I want to simultaneously use the st7920 LCD at spi1 and mcp2515 at spi2 on stm32f103c8t6. I am using Arduino ide. some explanation and example code is needed.
Everything relating to using STM32 boards with the Arduino IDE and alternatives
https://www.stm32duino.com/
SPI ISR:
if (transmission has reached its end) disable the SPI interrupt;
else load up the next data to be transmitted and advance the pointer
mcp_can.cpp
2012 Copyright (c) Seeed Technology Inc. All right reserved.
2017 Copyright (c) Cory J. Fowler All Rights Reserved.
Author: Loovee
Contributor: Cory J. Fowler
2017-09-25
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-
1301 USA
#include "mcp_can.h"
#define spi_readwrite SPI.transfer
#define spi_read() spi_readwrite(0x00)
** Function name: mcp2515_reset
** Descriptions: Performs a software reset
void MCP_CAN::mcp2515_reset(void)
SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE0));
MCP2515_SELECT();
spi_readwrite(MCP_RESET);
MCP2515_UNSELECT();
SPI.endTransaction();
delay(5); // If the MCP2515 was in sleep mode when the reset command was issued then we need to wait a while for it to reset properly
** Function name: mcp2515_readRegister
** Descriptions: Read data register
INT8U MCP_CAN::mcp2515_readRegister(const INT8U address)
INT8U ret;
MCP2515_SELECT();
spi_readwrite(MCP_READ);
spi_readwrite(address);
ret = spi_read();
MCP2515_UNSELECT();
return ret;
** Function name: mcp2515_readRegisterS
** Descriptions: Reads successive data registers
void MCP_CAN::mcp2515_readRegisterS(const INT8U address, INT8U values[], const INT8U n)
INT8U i;
MCP2515_SELECT();
// mcp2515 has auto-increment of address-pointer
for (i=0; i<n; i++)
values[i] = spi_read();
MCP2515_UNSELECT();
** Function name: mcp2515_setRegister
** Descriptions: Sets data register
void MCP_CAN::mcp2515_setRegister(const INT8U address, const INT8U value)
MCP2515_SELECT();
spi_readwrite(MCP_WRITE);
spi_readwrite(value);
MCP2515_UNSELECT();
** Function name: mcp2515_setRegisterS
** Descriptions: Sets successive data registers
void MCP_CAN::mcp2515_setRegisterS(const INT8U address, const INT8U values[], const INT8U n)
INT8U i;
MCP2515_SELECT();
for (i=0; i<n; i++)
spi_readwrite(values[i]);
MCP2515_UNSELECT();
** Function name: mcp2515_modifyRegister
** Descriptions: Sets specific bits of a register
void MCP_CAN::mcp2515_modifyRegister(const INT8U address, const INT8U mask, const INT8U data)
MCP2515_SELECT();
spi_readwrite(MCP_BITMOD);
spi_readwrite(mask);
spi_readwrite(data);
MCP2515_UNSELECT();
** Function name: mcp2515_readStatus
** Descriptions: Reads status register
INT8U MCP_CAN::mcp2515_readStatus(void)
INT8U i;
MCP2515_SELECT();
spi_readwrite(MCP_READ_STATUS);
i = spi_read();
MCP2515_UNSELECT();
return i;
** Function name: setSleepWakeup
** Descriptions: Enable or disable the wake up interrupt (If disabled the MCP2515 will not be woken up by CAN bus activity)
void MCP_CAN::setSleepWakeup(const INT8U enable)
mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, enable ? MCP_WAKIF : 0);
** Function name: setMode
** Descriptions: Sets control mode
INT8U MCP_CAN::setMode(const INT8U opMode)
mcpMode = opMode;
return mcp2515_setCANCTRL_Mode(mcpMode);
** Function name: mcp2515_setCANCTRL_Mode
** Descriptions: Set control mode
INT8U MCP_CAN::mcp2515_setCANCTRL_Mode(const INT8U newmode)
// If the chip is asleep and we want to change mode then a manual wake needs to be done
// This is done by setting the wake up interrupt flag
// This undocumented trick was found at https://github.com/mkleemann/can/blob/master/can_sleep_mcp2515.c
if((mcp2515_readRegister(MCP_CANSTAT) & MODE_MASK) == MCP_SLEEP && newmode != MCP_SLEEP)
// Make sure wake interrupt is enabled
byte wakeIntEnabled = (mcp2515_readRegister(MCP_CANINTE) & MCP_WAKIF);
if(!wakeIntEnabled)
mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, MCP_WAKIF);
// Set wake flag (this does the actual waking up)
mcp2515_modifyRegister(MCP_CANINTF, MCP_WAKIF, MCP_WAKIF);
// Wait for the chip to exit SLEEP and enter LISTENONLY mode.
// If the chip is not connected to a CAN bus (or the bus has no other powered nodes) it will sometimes trigger the wake interrupt as soon
// as it's put to sleep, but it will stay in SLEEP mode instead of automatically switching to LISTENONLY mode.
// In this situation the mode needs to be manually set to LISTENONLY.
if(mcp2515_requestNewMode(MCP_LISTENONLY) != MCP2515_OK)
return MCP2515_FAIL;
// Turn wake interrupt back off if it was originally off
if(!wakeIntEnabled)
mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, 0);
// Clear wake flag
mcp2515_modifyRegister(MCP_CANINTF, MCP_WAKIF, 0);
return mcp2515_requestNewMode(newmode);
** Function name: mcp2515_requestNewMode
INT8U MCP_CAN::mcp2515_requestNewMode(const INT8U newmode)
byte startTime = millis();
// Spam new mode request and wait for the operation to complete
while(1)
// Request new mode
// This is inside the loop as sometimes requesting the new mode once doesn't work (usually when attempting to sleep)
mcp2515_modifyRegister(MCP_CANCTRL, MODE_MASK, newmode);
byte statReg = mcp2515_readRegister(MCP_CANSTAT);
if((statReg & MODE_MASK) == newmode) // We're now in the new mode
return MCP2515_OK;
else if((byte)(millis() - startTime) > 200) // Wait no more than 200ms for the operation to complete
** Function name: mcp2515_configRate
** Descriptions: Set baudrate
INT8U MCP_CAN::mcp2515_configRate(const INT8U canSpeed, const INT8U canClock)
INT8U set, cfg1, cfg2, cfg3;
set = 1;
switch (canClock & MCP_CLOCK_SELECT)
case (MCP_8MHZ):
switch (canSpeed)
case (CAN_5KBPS): // 5KBPS
cfg1 = MCP_8MHz_5kBPS_CFG1;
cfg2 = MCP_8MHz_5kBPS_CFG2;
cfg3 = MCP_8MHz_5kBPS_CFG3;
break;
case (CAN_10KBPS): // 10KBPS
cfg1 = MCP_8MHz_10kBPS_CFG1;
cfg2 = MCP_8MHz_10kBPS_CFG2;
cfg3 = MCP_8MHz_10kBPS_CFG3;
break;
case (CAN_20KBPS): // 20KBPS
cfg1 = MCP_8MHz_20kBPS_CFG1;
cfg2 = MCP_8MHz_20kBPS_CFG2;
cfg3 = MCP_8MHz_20kBPS_CFG3;
break;
case (CAN_31K25BPS): // 31.25KBPS
cfg1 = MCP_8MHz_31k25BPS_CFG1;
cfg2 = MCP_8MHz_31k25BPS_CFG2;
cfg3 = MCP_8MHz_31k25BPS_CFG3;
break;
case (CAN_33K3BPS): // 33.33KBPS
cfg1 = MCP_8MHz_33k3BPS_CFG1;
cfg2 = MCP_8MHz_33k3BPS_CFG2;
cfg3 = MCP_8MHz_33k3BPS_CFG3;
break;
case (CAN_40KBPS): // 40Kbps
cfg1 = MCP_8MHz_40kBPS_CFG1;
cfg2 = MCP_8MHz_40kBPS_CFG2;
cfg3 = MCP_8MHz_40kBPS_CFG3;
break;
case (CAN_50KBPS): // 50Kbps
cfg1 = MCP_8MHz_50kBPS_CFG1;
cfg2 = MCP_8MHz_50kBPS_CFG2;
cfg3 = MCP_8MHz_50kBPS_CFG3;
break;
case (CAN_80KBPS): // 80Kbps
cfg1 = MCP_8MHz_80kBPS_CFG1;
cfg2 = MCP_8MHz_80kBPS_CFG2;
cfg3 = MCP_8MHz_80kBPS_CFG3;
break;
case (CAN_100KBPS): // 100Kbps
cfg1 = MCP_8MHz_100kBPS_CFG1;
cfg2 = MCP_8MHz_100kBPS_CFG2;
cfg3 = MCP_8MHz_100kBPS_CFG3;
break;
case (CAN_125KBPS): // 125Kbps
cfg1 = MCP_8MHz_125kBPS_CFG1;
cfg2 = MCP_8MHz_125kBPS_CFG2;
cfg3 = MCP_8MHz_125kBPS_CFG3;
break;
case (CAN_200KBPS): // 200Kbps
cfg1 = MCP_8MHz_200kBPS_CFG1;
cfg2 = MCP_8MHz_200kBPS_CFG2;
cfg3 = MCP_8MHz_200kBPS_CFG3;
break;
case (CAN_250KBPS): // 250Kbps
cfg1 = MCP_8MHz_250kBPS_CFG1;
cfg2 = MCP_8MHz_250kBPS_CFG2;
cfg3 = MCP_8MHz_250kBPS_CFG3;
break;
case (CAN_500KBPS): // 500Kbps
cfg1 = MCP_8MHz_500kBPS_CFG1;
cfg2 = MCP_8MHz_500kBPS_CFG2;
cfg3 = MCP_8MHz_500kBPS_CFG3;
break;
case (CAN_1000KBPS): // 1Mbps
cfg1 = MCP_8MHz_1000kBPS_CFG1;
cfg2 = MCP_8MHz_1000kBPS_CFG2;
cfg3 = MCP_8MHz_1000kBPS_CFG3;
break;
default:
set = 0;
break;
break;
case (MCP_16MHZ):
switch (canSpeed)
case (CAN_5KBPS): // 5Kbps
cfg1 = MCP_16MHz_5kBPS_CFG1;
cfg2 = MCP_16MHz_5kBPS_CFG2;
cfg3 = MCP_16MHz_5kBPS_CFG3;
break;
case (CAN_10KBPS): // 10Kbps
cfg1 = MCP_16MHz_10kBPS_CFG1;
cfg2 = MCP_16MHz_10kBPS_CFG2;
cfg3 = MCP_16MHz_10kBPS_CFG3;
break;
case (CAN_20KBPS): // 20Kbps
cfg1 = MCP_16MHz_20kBPS_CFG1;
cfg2 = MCP_16MHz_20kBPS_CFG2;
cfg3 = MCP_16MHz_20kBPS_CFG3;
break;
case (CAN_33K3BPS): // 20Kbps
cfg1 = MCP_16MHz_33k3BPS_CFG1;
cfg2 = MCP_16MHz_33k3BPS_CFG2;
cfg3 = MCP_16MHz_33k3BPS_CFG3;
break;
cfg1 = MCP_16MHz_40kBPS_CFG1;
cfg2 = MCP_16MHz_40kBPS_CFG2;
cfg3 = MCP_16MHz_40kBPS_CFG3;
break;
cfg2 = MCP_16MHz_50kBPS_CFG2;
cfg3 = MCP_16MHz_50kBPS_CFG3;
break;
cfg1 = MCP_16MHz_80kBPS_CFG1;
cfg2 = MCP_16MHz_80kBPS_CFG2;
cfg3 = MCP_16MHz_80kBPS_CFG3;
break;
cfg1 = MCP_16MHz_100kBPS_CFG1;
cfg2 = MCP_16MHz_100kBPS_CFG2;
cfg3 = MCP_16MHz_100kBPS_CFG3;
break;
cfg1 = MCP_16MHz_125kBPS_CFG1;
cfg2 = MCP_16MHz_125kBPS_CFG2;
cfg3 = MCP_16MHz_125kBPS_CFG3;
break;
cfg1 = MCP_16MHz_200kBPS_CFG1;
cfg2 = MCP_16MHz_200kBPS_CFG2;
cfg3 = MCP_16MHz_200kBPS_CFG3;
break;
cfg1 = MCP_16MHz_250kBPS_CFG1;
cfg2 = MCP_16MHz_250kBPS_CFG2;
cfg3 = MCP_16MHz_250kBPS_CFG3;
break;
cfg1 = MCP_16MHz_500kBPS_CFG1;
cfg2 = MCP_16MHz_500kBPS_CFG2;
cfg3 = MCP_16MHz_500kBPS_CFG3;
break;
cfg1 = MCP_16MHz_1000kBPS_CFG1;
cfg2 = MCP_16MHz_1000kBPS_CFG2;
cfg3 = MCP_16MHz_1000kBPS_CFG3;
break;
default:
set = 0;
break;
break;
case (MCP_20MHZ):
switch (canSpeed)
cfg1 = MCP_20MHz_40kBPS_CFG1;
cfg2 = MCP_20MHz_40kBPS_CFG2;
cfg3 = MCP_20MHz_40kBPS_CFG3;
break;
cfg1 = MCP_20MHz_50kBPS_CFG1;
cfg2 = MCP_20MHz_50kBPS_CFG2;
cfg3 = MCP_20MHz_50kBPS_CFG3;
break;
cfg1 = MCP_20MHz_80kBPS_CFG1;
cfg2 = MCP_20MHz_80kBPS_CFG2;
cfg3 = MCP_20MHz_80kBPS_CFG3;
break;
cfg1 = MCP_20MHz_100kBPS_CFG1;
cfg2 = MCP_20MHz_100kBPS_CFG2;
cfg3 = MCP_20MHz_100kBPS_CFG3;
break;
cfg1 = MCP_20MHz_125kBPS_CFG1;
cfg2 = MCP_20MHz_125kBPS_CFG2;
cfg3 = MCP_20MHz_125kBPS_CFG3;
break;
cfg1 = MCP_20MHz_200kBPS_CFG1;
cfg2 = MCP_20MHz_200kBPS_CFG2;
cfg3 = MCP_20MHz_200kBPS_CFG3;
break;
cfg1 = MCP_20MHz_250kBPS_CFG1;
cfg2 = MCP_20MHz_250kBPS_CFG2;
cfg3 = MCP_20MHz_250kBPS_CFG3;
break;
cfg1 = MCP_20MHz_500kBPS_CFG1;
cfg2 = MCP_20MHz_500kBPS_CFG2;
cfg3 = MCP_20MHz_500kBPS_CFG3;
break;
cfg1 = MCP_20MHz_1000kBPS_CFG1;
cfg2 = MCP_20MHz_1000kBPS_CFG2;
cfg3 = MCP_20MHz_1000kBPS_CFG3;
break;
default:
set = 0;
break;
break;
default:
set = 0;
break;
if (canClock & MCP_CLKOUT_ENABLE) {
cfg3 &= (~SOF_ENABLE);
if (set) {
mcp2515_setRegister(MCP_CNF1, cfg1);
mcp2515_setRegister(MCP_CNF2, cfg2);
mcp2515_setRegister(MCP_CNF3, cfg3);
return MCP2515_OK;
** Function name: mcp2515_initCANBuffers
** Descriptions: Initialize Buffers, Masks, and Filters
void MCP_CAN::mcp2515_initCANBuffers(void)
INT8U i, a1, a2, a3;
INT8U std = 0;
INT8U ext = 1;
INT32U ulMask = 0x00, ulFilt = 0x00;
mcp2515_write_mf(MCP_RXM0SIDH, ext, ulMask); /*Set both masks to 0 */
mcp2515_write_mf(MCP_RXM1SIDH, ext, ulMask); /*Mask register ignores ext bit */
/* Set all filters to 0 */
mcp2515_write_mf(MCP_RXF0SIDH, ext, ulFilt); /* RXB0: extended */
mcp2515_write_mf(MCP_RXF1SIDH, std, ulFilt); /* RXB1: standard */
mcp2515_write_mf(MCP_RXF2SIDH, ext, ulFilt); /* RXB2: extended */
mcp2515_write_mf(MCP_RXF3SIDH, std, ulFilt); /* RXB3: standard */
mcp2515_write_mf(MCP_RXF4SIDH, ext, ulFilt);
mcp2515_write_mf(MCP_RXF5SIDH, std, ulFilt);
/* Clear, deactivate the three */
/* transmit buffers */
/* TXBnCTRL -> TXBnD7 */
a1 = MCP_TXB0CTRL;
a2 = MCP_TXB1CTRL;
a3 = MCP_TXB2CTRL;
for (i = 0; i < 14; i++) { /* in-buffer loop */
mcp2515_setRegister(a1, 0);
mcp2515_setRegister(a2, 0);
mcp2515_setRegister(a3, 0);
a1++;
a2++;
a3++;
mcp2515_setRegister(MCP_RXB0CTRL, 0);
mcp2515_setRegister(MCP_RXB1CTRL, 0);
** Descriptions: Initialize the controller
INT8U MCP_CAN::mcp2515_init(const INT8U canIDMode, const INT8U canSpeed, const INT8U canClock)
INT8U res;
mcp2515_reset();
mcpMode = MCP_LOOPBACK;
res = mcp2515_setCANCTRL_Mode(MODE_CONFIG);
if(res > 0)
#if DEBUG_MODE
Serial.println(F("Entering Configuration Mode Failure..."));
return res;
#if DEBUG_MODE
Serial.println(F("Entering Configuration Mode Successful!"));
// Set Baudrate
if(mcp2515_configRate(canSpeed, canClock))
#if DEBUG_MODE
Serial.println(F("Setting Baudrate Failure..."));
return res;
#if DEBUG_MODE
Serial.println(F("Setting Baudrate Successful!"));
if ( res == MCP2515_OK ) {
/* init canbuffers */
mcp2515_initCANBuffers();
/* interrupt mode */
mcp2515_setRegister(MCP_CANINTE, MCP_RX0IF | MCP_RX1IF);
//Sets BF pins as GPO
mcp2515_setRegister(MCP_BFPCTRL,MCP_BxBFS_MASK | MCP_BxBFE_MASK);
//Sets RTS pins as GPI
mcp2515_setRegister(MCP_TXRTSCTRL,0x00);
switch(canIDMode)
case (MCP_ANY):
mcp2515_modifyRegister(MCP_RXB0CTRL,
MCP_RXB_RX_MASK | MCP_RXB_BUKT_MASK,
MCP_RXB_RX_ANY | MCP_RXB_BUKT_MASK);
mcp2515_modifyRegister(MCP_RXB1CTRL, MCP_RXB_RX_MASK,
MCP_RXB_RX_ANY);
break;
/* The followingn two functions of the MCP2515 do not work, there is a bug in the silicon.
case (MCP_STD):
MCP_RXB_RX_STD | MCP_RXB_BUKT_MASK );
MCP_RXB_RX_STD);
break;
case (MCP_EXT):
MCP_RXB_RX_EXT | MCP_RXB_BUKT_MASK );
MCP_RXB_RX_EXT);
break;
case (MCP_STDEXT):
MCP_RXB_RX_STDEXT | MCP_RXB_BUKT_MASK );
MCP_RXB_RX_STDEXT);
break;
default:
#if DEBUG_MODE
Serial.println(F("`Setting ID Mode Failure..."));
break;
res = mcp2515_setCANCTRL_Mode(mcpMode);
if(res)
#if DEBUG_MODE
Serial.println(F("Returning to Previous Mode Failure..."));
return res;
return res;
** Function name: mcp2515_write_id
** Descriptions: Write CAN ID
void MCP_CAN::mcp2515_write_id( const INT8U mcp_addr, const INT8U ext, const INT32U id )
uint16_t canid;
INT8U tbufdata[4];
canid = (uint16_t)(id & 0x0FFFF);
if ( ext == 1)
tbufdata[MCP_EID0] = (INT8U) (canid & 0xFF);
tbufdata[MCP_EID8] = (INT8U) (canid >> 8);
canid = (uint16_t)(id >> 16);
tbufdata[MCP_SIDL] = (INT8U) (canid & 0x03);
tbufdata[MCP_SIDL] += (INT8U) ((canid & 0x1C) << 3);
tbufdata[MCP_SIDL] |= MCP_TXB_EXIDE_M;
tbufdata[MCP_SIDH] = (INT8U) (canid >> 5 );
else
tbufdata[MCP_SIDH] = (INT8U) (canid >> 3 );
tbufdata[MCP_SIDL] = (INT8U) ((canid & 0x07 ) << 5);
tbufdata[MCP_EID0] = 0;
tbufdata[MCP_EID8] = 0;
mcp2515_setRegisterS( mcp_addr, tbufdata, 4 );
** Function name: mcp2515_write_mf
** Descriptions: Write Masks and Filters
void MCP_CAN::mcp2515_write_mf( const INT8U mcp_addr, const INT8U ext, const INT32U id )
uint16_t canid;
INT8U tbufdata[4];
if ( ext == 1)
else
tbufdata[MCP_SIDL] = (INT8U) ((canid & 0x07) << 5);
** Function name: mcp2515_read_id
** Descriptions: Read CAN ID
void MCP_CAN::mcp2515_read_id( const INT8U mcp_addr, INT8U* ext, INT32U* id )
INT8U tbufdata[4];
*ext = 0;
*id = 0;
mcp2515_readRegisterS( mcp_addr, tbufdata, 4 );
*id = (tbufdata[MCP_SIDH]<<3) + (tbufdata[MCP_SIDL]>>5);
if ( (tbufdata[MCP_SIDL] & MCP_TXB_EXIDE_M) == MCP_TXB_EXIDE_M )
/* extended id */
*id = (*id<<2) + (tbufdata[MCP_SIDL] & 0x03);
*id = (*id<<8) + tbufdata[MCP_EID8];
*id = (*id<<8) + tbufdata[MCP_EID0];
*ext = 1;
** Function name: mcp2515_write_canMsg
** Descriptions: Write message
void MCP_CAN::mcp2515_write_canMsg( const INT8U buffer_sidh_addr)
INT8U mcp_addr;
mcp_addr = buffer_sidh_addr;
mcp2515_setRegisterS(mcp_addr+5, m_nDta, m_nDlc ); /* write data bytes */
if ( m_nRtr == 1) /* if RTR set bit in byte */
m_nDlc |= MCP_RTR_MASK;
mcp2515_setRegister((mcp_addr+4), m_nDlc ); /* write the RTR and DLC */
mcp2515_write_id(mcp_addr, m_nExtFlg, m_nID ); /* write CAN id */
** Function name: mcp2515_read_canMsg
** Descriptions: Read message
void MCP_CAN::mcp2515_read_canMsg( const INT8U buffer_sidh_addr) /* read can msg */
INT8U mcp_addr, ctrl;
mcp2515_read_id( mcp_addr, &m_nExtFlg,&m_nID );
ctrl = mcp2515_readRegister( mcp_addr-1 );
m_nDlc = mcp2515_readRegister( mcp_addr+4 );
if (ctrl & 0x08)
m_nRtr = 1;
else
m_nRtr = 0;
m_nDlc &= MCP_DLC_MASK;
mcp2515_readRegisterS( mcp_addr+5, &(m_nDta[0]), m_nDlc );
** Function name: mcp2515_getNextFreeTXBuf
** Descriptions: Send message
INT8U MCP_CAN::mcp2515_getNextFreeTXBuf(INT8U *txbuf_n) /* get Next free txbuf */
INT8U res, i, ctrlval;
INT8U ctrlregs[MCP_N_TXBUFFERS] = { MCP_TXB0CTRL, MCP_TXB1CTRL, MCP_TXB2CTRL };
res = MCP_ALLTXBUSY;
*txbuf_n = 0x00;
/* check all 3 TX-Buffers */
for (i=0; i<MCP_N_TXBUFFERS; i++) {
ctrlval = mcp2515_readRegister( ctrlregs[i] );
if ( (ctrlval & MCP_TXB_TXREQ_M) == 0 ) {
*txbuf_n = ctrlregs[i]+1; /* return SIDH-address of Buffer*/
res = MCP2515_OK;
return res; /* ! function exit */
return res;
** Function name: MCP_CAN
** Descriptions: Public function to declare CAN class and the /CS pin.
MCP_CAN::MCP_CAN(INT8U _CS)
MCPCS = _CS;
MCP2515_UNSELECT();
pinMode(MCPCS, OUTPUT);
** Function name: begin
** Descriptions: Public function to declare controller initialization parameters.
INT8U MCP_CAN::begin(INT8U idmodeset, INT8U speedset, INT8U clockset)
INT8U res;
SPI.begin();
res = mcp2515_init(idmodeset, speedset, clockset);
if (res == MCP2515_OK)
return CAN_OK;
return CAN_FAILINIT;
** Function name: init_Mask
** Descriptions: Public function to set mask(s).
INT8U MCP_CAN::init_Mask(INT8U num, INT8U ext, INT32U ulData)
INT8U res = MCP2515_OK;
#if DEBUG_MODE
Serial.println(F("Starting to Set Mask!"));
if(res > 0){
#if DEBUG_MODE
return res;
if (num == 0){
mcp2515_write_mf(MCP_RXM0SIDH, ext, ulData);
else if(num == 1){
mcp2515_write_mf(MCP_RXM1SIDH, ext, ulData);
else res = MCP2515_FAIL;
if(res > 0){
#if DEBUG_MODE
Serial.println(F("Entering Previous Mode Failure..."));
Serial.println(F("Setting Mask Failure..."));
return res;
#if DEBUG_MODE
Serial.println(F("Setting Mask Successful!"));
return res;
INT8U MCP_CAN::init_Mask(INT8U num, INT32U ulData)
INT8U ext = 0;
#if DEBUG_MODE
if(res > 0){
#if DEBUG_MODE
return res;
if((ulData & 0x80000000) == 0x80000000)
ext = 1;
if (num == 0){
else if(num == 1){
if(res > 0){
#if DEBUG_MODE
return res;
#if DEBUG_MODE
return res;
** Function name: init_Filt
** Descriptions: Public function to set filter(s).
INT8U MCP_CAN::init_Filt(INT8U num, INT8U ext, INT32U ulData)
#if DEBUG_MODE
Serial.println(F("Starting to Set Filter!"));
if(res > 0)
#if DEBUG_MODE
Serial.println(F("Enter Configuration Mode Failure..."));
return res;
switch( num )
case 0:
mcp2515_write_mf(MCP_RXF0SIDH, ext, ulData);
break;
case 1:
mcp2515_write_mf(MCP_RXF1SIDH, ext, ulData);
break;
case 2:
mcp2515_write_mf(MCP_RXF2SIDH, ext, ulData);
break;
case 3:
mcp2515_write_mf(MCP_RXF3SIDH, ext, ulData);
break;
case 4:
mcp2515_write_mf(MCP_RXF4SIDH, ext, ulData);
break;
case 5:
mcp2515_write_mf(MCP_RXF5SIDH, ext, ulData);
break;
default:
res = MCP2515_FAIL;
if(res > 0)
#if DEBUG_MODE
Serial.println(F("Setting Filter Failure..."));
return res;
#if DEBUG_MODE
Serial.println(F("Setting Filter Successful!"));
return res;
INT8U MCP_CAN::init_Filt(INT8U num, INT32U ulData)
INT8U ext = 0;
#if DEBUG_MODE
if(res > 0)
#if DEBUG_MODE
return res;
ext = 1;
switch( num )
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
default:
res = MCP2515_FAIL;
if(res > 0)
#if DEBUG_MODE
return res;
#if DEBUG_MODE
return res;
** Function name: setMsg
** Descriptions: Set can message, such as dlc, id, dta[] and so on
INT8U MCP_CAN::setMsg(INT32U id, INT8U rtr, INT8U ext, INT8U len, INT8U *pData)
int i = 0;
m_nID = id;
m_nRtr = rtr;
m_nExtFlg = ext;
m_nDlc = len;
for(i = 0; i<MAX_CHAR_IN_MESSAGE; i++)
m_nDta[i] = *(pData+i);
return MCP2515_OK;
** Function name: clearMsg
** Descriptions: Set all messages to zero
INT8U MCP_CAN::clearMsg()
m_nID = 0;
m_nDlc = 0;
m_nExtFlg = 0;
m_nRtr = 0;
m_nfilhit = 0;
for(int i = 0; i<m_nDlc; i++ )
m_nDta[i] = 0x00;
return MCP2515_OK;
** Function name: sendMsg
INT8U MCP_CAN::sendMsg()
INT8U res, res1, txbuf_n;
uint32_t uiTimeOut, temp;
temp = micros();
// 24 * 4 microseconds typical
do {
res = mcp2515_getNextFreeTXBuf(&txbuf_n); /* info = addr. */
uiTimeOut = micros() - temp;
} while (res == MCP_ALLTXBUSY && (uiTimeOut < TIMEOUTVALUE));
if(uiTimeOut >= TIMEOUTVALUE)
return CAN_GETTXBFTIMEOUT; /* get tx buff time out */
uiTimeOut = 0;
mcp2515_write_canMsg( txbuf_n);
mcp2515_modifyRegister( txbuf_n-1 , MCP_TXB_TXREQ_M, MCP_TXB_TXREQ_M );
temp = micros();
do
res1 = mcp2515_readRegister(txbuf_n-1); /* read send buff ctrl reg */
res1 = res1 & 0x08;
} while (res1 && (uiTimeOut < TIMEOUTVALUE));
if(uiTimeOut >= TIMEOUTVALUE) /* send msg timeout */
return CAN_SENDMSGTIMEOUT;
return CAN_OK;
** Function name: sendMsgBuf
** Descriptions: Send message to transmitt buffer
INT8U MCP_CAN::sendMsgBuf(INT32U id, INT8U ext, INT8U len, INT8U *buf)
INT8U res;
setMsg(id, 0, ext, len, buf);
res = sendMsg();
return res;
INT8U MCP_CAN::sendMsgBuf(INT32U id, INT8U len, INT8U *buf)
INT8U ext = 0, rtr = 0;
INT8U res;
if((id & 0x80000000) == 0x80000000)
ext = 1;
if((id & 0x40000000) == 0x40000000)
rtr = 1;
setMsg(id, rtr, ext, len, buf);
res = sendMsg();
return res;
** Function name: readMsg
INT8U MCP_CAN::readMsg()
INT8U stat, res;
stat = mcp2515_readStatus();
if ( stat & MCP_STAT_RX0IF ) /* Msg in Buffer 0 */
mcp2515_read_canMsg( MCP_RXBUF_0);
mcp2515_modifyRegister(MCP_CANINTF, MCP_RX0IF, 0);
res = CAN_OK;
else if ( stat & MCP_STAT_RX1IF ) /* Msg in Buffer 1 */
mcp2515_read_canMsg( MCP_RXBUF_1);
mcp2515_modifyRegister(MCP_CANINTF, MCP_RX1IF, 0);
res = CAN_OK;
else
res = CAN_NOMSG;
return res;
** Function name: readMsgBuf
** Descriptions: Public function, Reads message from receive buffer.
INT8U MCP_CAN::readMsgBuf(INT32U *id, INT8U *ext, INT8U *len, INT8U buf[])
if(readMsg() == CAN_NOMSG)
return CAN_NOMSG;
*id = m_nID;
*len = m_nDlc;
*ext = m_nExtFlg;
for(int i = 0; i<m_nDlc; i++)
buf[i] = m_nDta[i];
return CAN_OK;
INT8U MCP_CAN::readMsgBuf(INT32U *id, INT8U *len, INT8U buf[])
return CAN_NOMSG;
if (m_nExtFlg)
m_nID |= 0x80000000;
if (m_nRtr)
m_nID |= 0x40000000;
*id = m_nID;
*len = m_nDlc;
buf[i] = m_nDta[i];
return CAN_OK;
** Function name: checkReceive
** Descriptions: Public function, Checks for received data. (Used if not using the interrupt output)
INT8U MCP_CAN::checkReceive(void)
INT8U res;
res = mcp2515_readStatus(); /* RXnIF in Bit 1 and 0 */
if ( res & MCP_STAT_RXIF_MASK )
return CAN_MSGAVAIL;
else
return CAN_NOMSG;
** Function name: checkError
** Descriptions: Public function, Returns error register data.
INT8U MCP_CAN::checkError(void)
INT8U eflg = mcp2515_readRegister(MCP_EFLG);
if ( eflg & MCP_EFLG_ERRORMASK )
return CAN_CTRLERROR;
else
return CAN_OK;
** Function name: getError
** Descriptions: Returns error register value.
INT8U MCP_CAN::getError(void)
return mcp2515_readRegister(MCP_EFLG);
** Function name: mcp2515_errorCountRX
** Descriptions: Returns REC register value
INT8U MCP_CAN::errorCountRX(void)
return mcp2515_readRegister(MCP_REC);
** Function name: mcp2515_errorCountTX
** Descriptions: Returns TEC register value
INT8U MCP_CAN::errorCountTX(void)
return mcp2515_readRegister(MCP_TEC);
** Function name: mcp2515_enOneShotTX
** Descriptions: Enables one shot transmission mode
INT8U MCP_CAN::enOneShotTX(void)
mcp2515_modifyRegister(MCP_CANCTRL, MODE_ONESHOT, MODE_ONESHOT);
if((mcp2515_readRegister(MCP_CANCTRL) & MODE_ONESHOT) != MODE_ONESHOT)
return CAN_FAIL;
else
return CAN_OK;
** Function name: mcp2515_disOneShotTX
** Descriptions: Disables one shot transmission mode
INT8U MCP_CAN::disOneShotTX(void)
mcp2515_modifyRegister(MCP_CANCTRL, MODE_ONESHOT, 0);
if((mcp2515_readRegister(MCP_CANCTRL) & MODE_ONESHOT) != 0)
return CAN_FAIL;
else
return CAN_OK;
** Function name: mcp2515_abortTX
** Descriptions: Aborts any queued transmissions
INT8U MCP_CAN::abortTX(void)
mcp2515_modifyRegister(MCP_CANCTRL, ABORT_TX, ABORT_TX);
// Maybe check to see if the TX buffer transmission request bits are cleared instead?
if((mcp2515_readRegister(MCP_CANCTRL) & ABORT_TX) != ABORT_TX)
return CAN_FAIL;
else
return CAN_OK;
** Function name: setGPO
INT8U MCP_CAN::setGPO(INT8U data)
mcp2515_modifyRegister(MCP_BFPCTRL, MCP_BxBFS_MASK, (data<<4));
return 0;
** Function name: getGPI
INT8U MCP_CAN::getGPI(void)
INT8U res;
res = mcp2515_readRegister(MCP_TXRTSCTRL) & MCP_BxRTS_MASK;
return (res >> 3);
END FILE
#include <SPI.h>
#ifndef _MYSKETCH_H
#define _MYSKETCH_H
extern SPIClass SPI_2;
// MOSI MISO SCLK
SPIClass SPI_2(PB15, PB14, PB13);
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STLink, 72Mhz (Normal), Smallest (default)"
cans:16:32: error: no matching function for call to 'SPIClass::SPIClass(<anonymous enum>, <anonymous enum>, <anonymous enum>)'
C:\Users\Arunsaravana\Documents\Arduino\cans\cans.ino:16:32: note: candidates are:
In file included from C:\Users\Arunsaravana\Documents\Arduino\cans\arun.h:1:0,
from C:\Users\Arunsaravana\Documents\Arduino\cans\cans.ino:10:
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:176:5: note: SPIClass::SPIClass(uint32)
SPIClass(uint32 spiPortNumber);
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:176:5: note: candidate expects 1 argument, 3 provided
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:170:7: note: constexpr SPIClass::SPIClass(const SPIClass&)
class SPIClass {
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:170:7: note: candidate expects 1 argument, 3 provided
C:\Users\Arunsaravana\Documents\ArduinoData\packages\stm32duino\hardware\STM32F1\2021.5.31\libraries\SPI\src/SPI.h:170:7: note: constexpr SPIClass::SPIClass(SPIClass&&)
exit status 1
