Sleep Mode
hyur
Sleep Mode
Post by hyur »
Board : Stm32f103c8t6 (Roger's Core)
I want to use sleep mode on the board.
So I tried to use the STM32duino LOW POWER library,
Because it is Roger's Core, stm32_def.h compilation error occurs.
How does Roger's Core use sleep mode?
Can you provide a relevant register datasheet or example code?
Ouroboros
Re: Sleep Mode
Post by Ouroboros »
I'm trying to implement standby and stop modes on this core for STM32F103 mcu. I had no isues with standby mode, it works properly with power consumption about of 48 uA. Same power is consumed when using STM32LowPower with official core. Here it's my source:
void lp_init()
	//enable power clock
	RCC_BASE->APB1ENR |= RCC_APB1ENR_PWREN;
	delay(10);
	/* Enable access to RTC and backup registers */
	PWR_BASE->CR |= PWR_CR_DBP;
	/* Check if the system was resumed from StandBy mode */
	if (PWR_BASE->CSR & SCB_SCR_SLEEPONEXIT) {
		/* Clear Standby flag */
		PWR_BASE->CR |= PWR_CR_CSBF;
	//Clear wakeup flag
	PWR_BASE->CR |= PWR_CR_CWUF;
void standby()
	lp_init();
	nvic_globalirq_disable();
	SCB_BASE->SCR |= SCB_SCR_SLEEPDEEP;
	//Power down deepsleep
	PWR_BASE->CR |= PWR_CR_PDDS;
	//Enable wakeup pin
	PWR_BASE->CSR |= PWR_CSR_EWUP;
	__asm volatile("WFI":::"memory");
There are some difficuelties with stop mode. It consumes about 79uA instead of 54uA using original core. Something keeps consuming 25uA. Here the sources of my implementation:
void stop()
	for (int i = 0; i < BOARD_NR_GPIO_PINS; i++)
		pinMode(i, INPUT);
		digitalWrite(i, 0);
	Serial.end();
	adc_disable_all();
	lp_init();
	PWR_BASE->CR &= ~PWR_CR_PDDS;
	//Low-power deepsleep
	PWR_BASE->CR |= PWR_CR_LPDS;
	SCB_BASE->SCR &= ~SCB_SCR_SLEEPDEEP;
	//post wakeup setup
	setup_clocks();
	nvic_init((uint32)VECT_TAB_ADDR, 0);  //setup_nvic();
	systick_init(SYSTICK_RELOAD_VAL);
	adc_set_prescaler(wirish::priv::w_adc_pre); adc_foreach(adc_default_config); //setup_adcs();
	timer_foreach(timer_default_config);  //setup_timers();
	nvic_globalirq_enable();
