USBComposite is working like a charm to simulate a keyboard.
But, how to deal with key-mapping ?
On my test machine I have a french keyboard (AZERTY) and a "Keyboard.press('a');" give a "q".
Is there a way to deal with this problem ?
Cheers,
Phil
USBComposite and keymapping
Re: USBComposite and keymapping
Background: https://stackoverflow.com/questions/393 ... d-keyboard
I guess you'll need to generate a map for the locale. I don't think there is a general solution on the stm side.
Hi Arpruss,
Thanks for the pointer.
As the project was for an event mid November, I've found a quick & dirt solution: I have map myself an AZERTY keyboard over the QWERTY template I've found. Just modify the output code with a translate table.
The major issue was the need of the key "Alt Gr" to obtain the specific chars related to this combo key. If someone have to do a similar job, have a look at the "modifiers". So the table is a char translation plus optionally the Alt Gr or Shift pressed and released.
It's so ugly, I can't show this mess ... But it worked as expected.
It's a shame I can't commit it, but as I'm not an expert of those HID devices, my patch will not be useful to someone aware of how it really works.
Cheers,
Phil
Cheers,
Phil
I had a similar problem. I will try it. Thank you!arpruss wrote: ↑Tue Dec 27, 2022 3:10 pm Background: https://stackoverflow.com/questions/393 ... d-keyboard
