STM32F103C8T6 with u8g2 library problem
gabrielwong1991
Post by gabrielwong1991 »
Hi I have an SSD1322 LCD panel that has a 4-pin SPI connection.
The panel works fine with Arduino UNO under Hardware and Software SPI mode. In the FPS test that comes with U8G2 example library, it scores 13 fps which is normal.
Note I am using this board manager
However, i have recently got a genuine C8T6 and plugged it with the following standard configuration:
SCLK (CLOCK) PA5
SDIN (MOSI) PA7
PIN_DC PB0
PIN_RESET PB1
PIN_CS (SS) PA4
It displays okay in Software SPI mode but the FPS is incredibly slow - only 1.4 fps. I am surprised that the STM32 which has a higher CPU clock speed than Arduino UNO.
U8G2_SSD1322_NHD_256X64_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ PA5, /* data=*/ PA7, /* cs=*/ PA4, /* dc=*/ PB0, /* reset=*/ PB1);
So I investigate further to understand whether it is due to page buffer vs full buffer. Turns out FPS is the same.
Then I try it with hardware SPI mode but turns out it just won't show anything and U8G2 constructor does not allow assigning the clock, data pin.
U8G2_SSD1325_NHD_128X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ PA4, /* dc=*/ PB0, /* reset=*/ PB1);
So here are two questions. Is there anywhere I could define the clock and data pin with hardware mode?
What is the reason for such a slow speed with STM32? Could that be the SPI link speed that I shall need to define?
A related problem here in this forum but it seems like it never gets solved...
viewtopic.php?p=9342&hilit=U8G2+HW#p9342
Thanks you all for your help!
hobbya
Re: STM32F103C8T6 with u8g2 library problem
Post by hobbya »
Not sure if the core you used was up to date. You can install the up to date version below:
Roger's original core:
https://github.com/rogerclarkmelbourne/Arduino_STM32 or
A fork of Roger's and is more frequently maintained:
https://github.com/stevstrong/Arduino_STM32
When picking options in the u8g2 library always choose "HW SPI". For example:
U8X8_SSD1306_128X64_NONAME_4W_HW_SPI u8x8(/* cs=*/ PA4, /* dc=*/ PB0, /* reset=*/ PB1);
U8G2_SSD1306_128X64_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ PA4, /* dc=*/ PB0, /* reset=*/ PB1);
If you choose "SW SPI" the clock rate will drop to a very low value. For native hardware SPI you do not need to specify MOSI and SCLK.
