Hi.
I'm trying to configure watchdog to reboot the board in case of its freeze or lag. But I can’t find how this is done, maybe you have an example of such use? stm32f103c8t6
sorry for broken english
#define LIBMAPPLE_CORE //comment it for HAL based core
#define IWDG_PR_DIV_4 0x0
#define IWDG_PR_DIV_8 0x1
#define IWDG_PR_DIV_16 0x2
#define IWDG_PR_DIV_32 0x3
#define IWDG_PR_DIV_64 0x4
#define IWDG_PR_DIV_128 0x5
#define IWDG_PR_DIV_256 0x6
typedef enum iwdg_prescaler {
IWDG_PRE_4 = IWDG_PR_DIV_4, /**< Divide by 4 */
IWDG_PRE_8 = IWDG_PR_DIV_8, /**< Divide by 8 */
IWDG_PRE_16 = IWDG_PR_DIV_16, /**< Divide by 16 */
IWDG_PRE_32 = IWDG_PR_DIV_32, /**< Divide by 32 */
IWDG_PRE_64 = IWDG_PR_DIV_64, /**< Divide by 64 */
IWDG_PRE_128 = IWDG_PR_DIV_128, /**< Divide by 128 */
IWDG_PRE_256 = IWDG_PR_DIV_256 /**< Divide by 256 */
} iwdg_prescaler;
#if defined(LIBMAPPLE_CORE)
typedef struct iwdg_reg_map {
volatile uint32_t KR; /**< Key register. */
volatile uint32_t PR; /**< Prescaler register. */
volatile uint32_t RLR; /**< Reload register. */
volatile uint32_t SR; /**< Status register */
} iwdg_reg_map;
#define IWDG ((struct iwdg_reg_map *)0x40003000)
void iwdg_feed(void) { IWDG->KR = 0xAAAA; }
void iwdg_init(iwdg_prescaler prescaler, uint16_t reload) {
IWDG->KR = 0x5555;
IWDG->PR = prescaler;
IWDG->RLR = reload;
IWDG->KR = 0xCCCC;
IWDG->KR = 0xAAAA;
for example with 32khz LSI clock and divider 32, reload value 1000 will be one second to avoid reboot by calling iwdg_feed in the main loop
Re: watchdog to reboot the board
The IWDG can help you.
If you use the STM32 core, there is a library to ease the use:
https://github.com/stm32duino/Arduino_C ... /IWatchdog
For Roger's core, I don't know if there is such API, anyway, it is simple to configure using register.
Yes, I tried this library, and this is the core. but My projects, almost all, are not compiled by that core(. Can you help to do this with registers? Unfortunately, I haven’t figured it out yet.
} iwdg_prescaler;
} iwdg_reg_map;
IWDG->KR = 0x5555;
IWDG->RLR = reload;
IWDG->KR = 0xCCCC;
IWDG->KR = 0xAAAA;
It is working! It works!) Thank you very much) I surfed the Internet for several hours in search of a working solution. Thanks)
