Sk Pro v 1.2 Won't let change readout protection level
Posted: Wed Mar 29, 2023 10:58 pm
Hello all! Currently I am trying to reflash an SK Pro board for use as a cnc driver. It is connected through an ST Link v2 and connecting to the board with no issues.
On the connection page it is listing itself as Device ID: 0x413, Revision Idea: Rev Y, flash size: unknown.
On the Options Bytes page the only user configuration option bytes selected are nRST_STOP, nRST_STDBY, and WDG_SW. Read Out Protection is set to lvl 1, BOR Level F: OFF, R: blank grey. All individual sectors show now protection.
On trying to change the readout protection levels it gives the error: "Can Not Read Memory! Disable Read Out Protection and Retry", and above it in the command window it reads "Could not set Option bytes! Please reset the target and retry." The connection information is listed below:
18:53:04 : ST-LINK SN : 440025001500004A4735544E
18:53:04 : V2J29S7
18:53:04 : Connected via SWD.
18:53:04 : SWD Frequency = 4,0 MHz.
18:53:04 : Connection mode : Normal.
18:53:04 : Debug in Low Power mode enabled.
18:53:04 : V2J29S7
