How to Program the STM32 "Blue Pill" with Arduino IDE
myksj1105
Post by myksj1105 »
http://dan.drown.org/stm32duino/package ... index.json
1. How to connect hardware
-Serial(FTDI) :
https://maker.pro/arduino/tutorial/how- ... rduino-ide
- RX-A9, TX-A10
Case 1. first core method
- Board : STM32F1 Boards - Generic STM32F103C6
- Upload : Serial
- Run 'blink' example program: It works well. (The program will be uploaded.)
- but. 'EEPROM' did not work.
Case 2. second core method
-Board : BluePill F103C6(32K)
- Upload : STM32CubeProgrammer(Serial)
- Unable to upload.
I'm curious about 2 things.
Q1) Doesn't 'EEPROM' of 'STM32F103C6' work?
Q2) I want to know how to upload a program in 'second core method'.
by fpiSTM » Thu Jun 22, 2023 10:20 am
myksj1105 wrote: Thu Jun 22, 2023 5:29 am @fpiSTM
hello. thank you for the reply.
STM32F103C8
Q1) Does the chip above not have 'EEPROM'?
- I actually tried to write and read the EEPROM to the corresponding chip.
It works fine.
Q2) If there is no EEPROM, how does it work?
As said by @GonzoG, the STM32F1 series does not have real EEPROM. The library provided within the STM32 core do EPPROM emulation using the FLASH.
myksj1105
Re: How to Program the STM32 "Blue Pill" with Arduino IDE
Post by myksj1105 »
STM32F103C8T6 EEPROM Very well work.
program, USB Booting good!
STM32 MCUs do not have EEPROM.
To have non-volatile memory, virtual EEPROM is created in flash memory. Because every MCU has different memory it virtual EEPROM needs to be configured for each MCU. You're using Roger's/Steave's core, so it's limited to only few MCUs and it may be missing necessary config for virtual EEPROM for F103C6.
As to upload with STM32 core, what error do you get ??
myksj1105
Post by myksj1105 »
GonzoG wrote: Tue Jun 20, 2023 10:20 am STM32 MCUs do not have EEPROM.
STM32F103C6 : EEPROM not work
STM32F103C8 : EEPROM nice work
I don't know why, but 'STM32F103C8T6' works fine. EEPROM works fine.
It is not totally true ;)
2 series have a real EEPROM:
https://www.st.com/en/microcontrollers- ... eries.html: embedded EEPROM memory
https://www.st.com/en/microcontrollers- ... eries.html: 16 Kbytes of true embedded EEPROM
myksj1105
Post by myksj1105 »
@fpiSTM
STM32F103C8
It works fine.
STM32F103C8
It works fine.
myksj1105
Post by myksj1105 »
@GonzoG @fpiSTM
Nice to meet you geniuses. I really appreciate your answer.
1. In conclusion, EEPROM works well.
2. Actually, there is no 'EEPROM', but is it true that it is remembered for life in the same way as above? Or is it only remembered for a certain period of time?
3. In conclusion, what is the difference between 'EEPROM' used in Arduino and 'EEPROM' used in 'STM32Duino' now?
(Will users notice a difference?)
It's saved into flash memory until it's rewritten. If you flash a big program that will need almost whole memory and without virtual EEPROM it may overwrite data saved in virtual EEPROM.
Also:
1. Flash memory has limited (more then EEPROM) erase/write cycles. If you'll write lots of data or very often you will destroy this part of MCU flash.
2. there are only 256B of virtual flash available on F103 blue pills.
3. Virtual EEPROM uses 2kB of flash.
myksj1105
Post by myksj1105 »
@GonzoG @GonzoG
Thank you. understand.
Thank you very much.
