How to adjust pinouts for new boards
cagz
Post by cagz »
I am developing a new variant using STM32L052K6T6, there are no existing variants for L0 family so I concluded that I had to create my own. Copied over F103 variant_BLUEPILL_F103C6.cpp and variant_BLUEPILL_F103C6.h over and preparing to adapt it to my board. This is where the confusion settled in !
variant_BLUEPILL_F103C6.h:
#define PB9                     0
#define PB8                     1
#define PB7                     2
What are these numbers 0,1,2 ? It is not surely PIN 0 on the chip as there is no PIN 0, so what does this mapping represent ?
#define PC14                    18
#define PC15                    19
#define PA0                     PIN_A0
#define PA1                     PIN_A1
#define PA2                     PIN_A2
#define PA3                     PIN_A3
Why these PAx ones are different ? What are they doing ?
#define PB0_ALT1                (PB0  | ALT1)
#define PB0_ALT2                (PB0  | ALT2)
#define PB1_ALT1                (PB1  | ALT1)
I suppose these are setting alternate functions for those pins, but what are ALT1 / ALT2, how to set them for my board ?
variant_BLUEPILL_F103C6.cpp:
const PinName digitalPin[] = {
  /* USB connector on the top, MCU side */
  /* Left Side */
  PB_9,  //D0
  PB_8,  //D1
  PB_7,  //D2
  PB_6,  //D3
What is the intention here, this array is filled in the order pins are placed on the actual PCB, but I cannot tell the use for them. PB9 is the zeroth element of this array, so is that 0 matching the 0 in .h file ?
Is there a document I can read ? Or otherwise there are references to a "genpinmap" utility, but I couldn't find it, seems like it has been deprecated.
I appreciate if someone can offer me a starting point.
Answers: 92
Re: How to adjust pinouts for new boards
cagz wrote: Mon Aug 14, 2023 11:34 am
#define PB9                     0
#define PB8                     1
#define PB7                     2
This is the pin bumber: 0 is equivalent to D0 (Arduino naming), it is used as index for the digital pin array to get the pinName.
#define PC14                    18
#define PC15                    19
#define PA0                     PIN_A0
#define PA1                     PIN_A1
#define PA2                     PIN_A2
#define PA3                     PIN_A3
PIN_Ax are digital pins with analog capabilities. It allows to know that this pin has analog capabilities.
There is no link with Alternate Function.
It is used to get the Alternate peripheral of a GPI. Like same pin can have several IP instance ex: USART1 and USART2, using this notation allows to use the required instance.
cagz wrote: Mon Aug 14, 2023 11:34 am variant_BLUEPILL_F103C6.cpp:
  /* Left Side */
  PB_9,  //D0
  PB_8,  //D1
  PB_7,  //D2
  PB_6,  //D3
As stated below, yes this is the index.
cagz wrote: Mon Aug 14, 2023 11:34 am Is there a document I can read ? Or otherwise there are references to a "genpinmap" utility, but I couldn't find it, seems like it has been deprecated.
Yes genpinmap is deprected since a while. Now, all generic variants are generated for all MCU. End user do not have to bother with this.
juiweasley
Post by juiweasley »
What can I do when the code does not compile and it marks "file does not exist" Do you have an answer to that?
Answers: 92
Which file does not exist?
