SPI blocked by a flag
gauthierDCC
Post by gauthierDCC »
Hi all,
For I project, I would like to switch from an Arduino Nano to a Nucleo-G431KB.
I use a pressure sensor HRCDRRN100MDSA3 from Honeywell, with the HoneywellTruStabilitySPI library.
Using the Arduino, I have no problem to run the exemple code.
But I can't made it work with my Nucleo, even with adjusting the SPI pin.
I tried to use the debugger to understand where the problem is, but it's to complexe for me to understand :lol:
All I know is that I'm blocked in a infinite loop:
In spi_com.c, at line 546
 while (!LL_SPI_IsActiveFlag_TXE(_SPI));
I have no clue of what that flag is.
Do you have any idea?
Full test sketch
 * PressureSensorTest
 * Fetch and print values from a Honeywell
 * TruStability HSC Pressure Sensor over SPI
 * The sensor values used in this demo are
 * for a -15 to 15 psi gauge pressure sensor.
#include <HoneywellTruStabilitySPI.h>
#define SLAVE_SELECT_PIN PA11 // D10 on Arduino
TruStabilityPressureSensor sensor( SLAVE_SELECT_PIN, -100.0, 100.0 );
  Serial.begin(115200); // start Serial communication
  SPI.setMOSI(PB5);       // D11 on Arduino
  SPI.setMISO(PB4);       // D12 on Arduino
  SPI.setSCLK(PB3);       // D13 on Arduino
  SPI.begin();            // start SPI communication
  sensor.begin();         // run sensor initialization
  // the sensor returns 0 when new data is ready
  if( sensor.readSensor() == 0 ) {
    Serial.print( "temp [C]: " );
    Serial.print( sensor.temperature() );
    Serial.print( "\t pressure [psi]: " );
    Serial.println( sensor.pressure() );
  delay( 100 ); // Slow down sampling to 10 Hz. This is just a test.
gauthierDCC
Re: SPI blocked by a flag
On the STM32G4 Nulceo user manual, it's written that by default, T_SWO is connected to PB3 (SPI1_CLK). https://www.st.com/resource/en/user_man ... ronics.pdf p.17
Could that T_SWO interfere with the SPI?
If I remove the solder bridge (SB4), would I still have access to the debugging functions?
I also tried with PA5 as SCLK and PA6 as MISO (my sensor does not use MOSI), without success.
I'm not blocked in the sensor.readSensor() function, but data are fully corrupted (temps of 150°C or -50°C)
gauthierDCC
I've seen in an errata from ST that my µC is subjected to problem with the BSY bit in the SPI protocol (note that I don't really understand what it means :D )
2.13 SPI
2.13.1 BSY bit may stay high when SPI is disabled
Description
The BSY flag may remain high upon disabling the SPI while operating in:
• master transmit mode and the TXE flag is low (data register full).
• master receive-only mode (simplex receive or half-duplex bidirectional receive phase) and an SCK strobing
edge has not occurred since the transition of the RXNE flag from low to high.
• slave mode and NSS signal is removed during the communication.
Workaround
When the SPI operates in:
• master transmit mode, disable the SPI when TXE = 1 and BSY = 0.
• master receive-only mode, ignore the BSY flag.
• slave mode, do not remove the NSS signal during the communication
I operate in maser receive-only mode, now I have to find a way to ignore that flag (does it mean modifying the library?)
gauthierDCC
I think I went on a wrong direction looking at the BSY flag...
Looking at the oscilloscope, I have the following result with the Arduino:
Using the Arduino
Using the Arduino
And I have that using the STM32:
Using the STM32, without initialization
As they suggest here, I might need to reset the SPI pin before using it: https://electronics.stackexchange.com/q ... rms-poorly
But I have no idea of how to program directly with the registers (I tried copy/past of the given code, but "CRL" is not recognized)
So I tried initializing this way:
  pinMode(SLAVE_SELECT_PIN, OUTPUT);
  pinMode(PB4, INPUT);
  pinMode(PB3, OUTPUT);
Not working...
But it does change something:
Using the STM32, withinitialization
