Arduino IDE 2.x (2.2)
Tried out the current version of Arduino IDE 2.2.1 and with STM core (2.6.0)
https://www.arduino.cc/en/software
Apparently, it is working quite well now
Arduino IDE 2.2
Arduino IDE 2.2
but that is just initial impressions, have not tried debug etc.
One of the features reference jumps for symbols, works to an extent but imperfect.
for some of the symbols, you can right click select Goto Definition and it would open the include / definition in a new tab.
It is one of the 'missing' features, which accordingly is provided by the clangd https://clangd.llvm.org/.
Some of the reference jumps don't work, but it compiles fine.
The screen print and console response messages is a 'blinky' app, which prints something to usb serial periodically.
it is more of a lousy 'breathing' led test. the sample sketch:
#include <Arduino.h>
#include <HardwareTimer.h>
HardwareTimer *pTimer2 = new HardwareTimer(TIM2);
int16_t count;
int8_t dir;
bool pr = false;
void ledon() {
	int8_t channel = 1;
	if(count > 100) {
		dir = -1;
		count = 100;
	} else if (count < 1) {
		dir = 1;
		count = 1;
		pr = true;
	pTimer2->setCaptureCompare(channel, count, PERCENT_COMPARE_FORMAT); // count here is the duty cycle 1-100
void ledoff() {
	count += dir;
	count = 0;
	dir = 1;
	Serial.begin();
	pinMode(LED_BUILTIN, OUTPUT);
	uint8_t channel = 1;
	pTimer2->pause(); // pause the timer
	pTimer2->setMode(channel, TIMER_OUTPUT_COMPARE_PWM1); //output compare mode, got this from reading the api notes
	pTimer2->setOverflow(50, HERTZ_FORMAT); // call back at 50 hz
	pTimer2->attachInterrupt(ledon); // attach ledon() every cycle turn on the led
	pTimer2->attachInterrupt(channel, ledoff); // attach ledoff() end of duty cycle turn off the led
	pTimer2->refresh(); //reset the counters
	pTimer2->resume();
  if(pr) {
    Serial.println("hello stm32");
    pr = false;
as usual for those who need usb-serial, select USB Support ( CDC generic 'Serial' supercede u(s)art ) from the menu
BennehBoy
Re: Arduino IDE 2.x (2.2)
Post by BennehBoy »
Debug works fine as long as you edit the openocd.cfg supplied with the core release - change "reset_config srst_nogate" to "reset_config none"
slightly improved 'breathing led', this one uses floating point
so use an F4xx or one that has FPU enabled.
that square root function gives roughly a cosine or unit circle function.
#include <math.h>
int16_t count;
int8_t dir;
bool pr = false;
void ledon() {
	int8_t channel = 1;
	if(count > 199) {
		dir = -1;
		count = 199;
		dir = 1;
		count = 1;
		pr = true;
	float x = ((float) count)/200.0F;
	int dutycycle = sqrt(1 - x * x) * 100;
	pTimer2->setCaptureCompare(channel, dutycycle, PERCENT_COMPARE_FORMAT); // count here is the duty cycle 1-100
void ledoff() {
	count += dir;
	count = 0;
	dir = 1;
  Serial.begin();
	pTimer2->resume();
  if(pr) {
    pr = false;
I often use two timer ISRs that flip the led pin at slightly different intervals. This leads to the duty cycle on the led goes up and down gradually.
the output compare interrupts are best for this.
bobihot
Post by bobihot »
I was project with 2.6.0 and compiles well. Today Arduino IDE 2.2.1 was self updating with 2.7.0 and began give error with Serial2
c:/users/stv/appdata/local/arduino15/packages/stmicroelectronics/tools/xpack-arm-none-eabi-gcc/12.2.1-1.2/bin/../lib/gcc/arm-none-eabi/12.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\Stv\AppData\Local\Temp\arduino\sketches\1B21512BF610B2AC24992B858C62C89A\sketch\MultiSerial32.ino.cpp.o: in function `setup':
MultiSerial32.ino.cpp:(.text.setup+0x24): undefined reference to `Serial2'
c:/users/stv/appdata/local/arduino15/packages/stmicroelectronics/tools/xpack-arm-none-eabi-gcc/12.2.1-1.2/bin/../lib/gcc/arm-none-eabi/12.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\Stv\AppData\Local\Temp\arduino\sketches\1B21512BF610B2AC24992B858C62C89A\sketch\MultiSerial32.ino.cpp.o: in function `loop':
MultiSerial32.ino.cpp:(.text.loop+0x40): undefined reference to `Serial2'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
MCU Hardware&Software developer. Desktop programing
Without more info hard to help. Which board? Options selected? Sketch?....
bobihot
Post by bobihot »
This is some changed Example MultiSerial:
Multiple Serial test
https://www.arduino.cc/en/Tutorial/Buil ... SerialMega
// initialize both serial ports:
Serial2.begin(2000000);
// read from port 1, send to port 0:
if (Serial2.available()) {
int inByte = Serial2.read();
Serial.write(inByte);
Serial2.write('A');
// read from port 0, send to port 1:
if (Serial.available()) {
int inByte = Serial.read();
Serial2.write(inByte);
delay(100);
Board is STM32 bluepill compatible
Well the issue here is the BP have only one Serial defined by default: Serial1 which is mapped on default instance Serial.
You have to define the Serial2 instance:
https://github.com/stm32duino/Arduino_C ... wareserial
bobihot
Post by bobihot »
Thanks,
But this was running before?
No. You probably used another sketch which defined Serial2
Return to “IDE's”
