Coding STM32H747XI on Arduino GIGA R1 Wifi
Can STM32CubeProgrammer be used to program the Arduino giga that has the STM32H747XI processor. I am trying to connect a LCD display that uses MIPI DSI and the Arduino libraries don't currently support that. Correct me if I'm wrong though! There are a ton of resources that show the STM32 series driving different types of LCD screens which is why I want to try STM32CubeProgrammer. Any insight would be great, thanks again.
Re: Coding STM32H747XI on Arduino GIGA R1 Wifi
May be you misunderstand something?help_bio wrote: Wed May 22, 2024 7:03 pm Can STM32CubeProgrammer be used to program the Arduino giga that has the STM32H747XI processor.
"Arduino for STM32" means, that you copy link to JSON-file into ArduinoIDE and then install "STM32 MCU based boards" by the board manager of IDE.
So you write your program inside ArduinoIDE, compile and link it. The CLI of STM32CubeProgrammer is only used in the last step to upload your bin-file. Advantage may be, that STM32-Core is based on HAL.
The amount of libraries for STM32-Core is very small. There is nothing about a display.help_bio wrote: Wed May 22, 2024 7:03 pm I am trying to connect a LCD display that uses MIPI DSI and the Arduino libraries don't currently support that.
If you are able to convert examples for STM32CubeIDE to ArduinoIDE ... ok.
The good news: there is a list of supported µC and your STM32H747XI is in the list.
The bad news: how to upload?
What is the regular way to upload a sketch to Arduino Giga R1?
Via USB?
Which tool they use for upload?
For a lot of STM32 boards you can use a STLinkV2: one side USB for connection to computer, other side 4pin header with GND, SWDIO, SWCLK and +3.3V. SWDIO is normally connected to PA13 and SWCLK to PA14.
Arduino Giga R1 has JTAG-header. Pins are named "TMS/SWD" going to PA13 and "TCK/SCK" going to PA14. So it may be possible to use a STLinkV2 here? I have a (unused) Arduino GIGA R1 at home, but I can't test it. JTAG-header seems to have a 1,27 mm pitch.
BTW:
There is a display for Arduino GIGA R1. Specs say:
The J4 connector for video (DSI) signals and the
J5 connector for the touch panel signals
Arduino sell a board, a display, but have no example for that???
STM32CubeProgrammer is suitable for programming the STM32H747XI on your Arduino giga board and configuring it to interface with an MIPI DSI LCD display. It provides the flexibility and capabilities needed for handling peripherals that may not be directly supported by Arduino libraries, making it a practical choice for your project.
May be you're talking about STM32CubeIDE ?katebishop wrote: Thu Jun 20, 2024 4:56 am STM32CubeProgrammer is suitable for programming the STM32H747XI on your Arduino giga board and configuring it to interface with an MIPI DSI LCD display. It provides the flexibility and capabilities needed for handling peripherals that may not be directly supported by Arduino libraries, making it a practical choice for your project.
