ADC issue
Posted: Fri Jul 19, 2024 3:17 pm
by alexanderpruss
When I put a standard red LED with a 100ohm resistor on a gpio (or just between ground and V3) on my black pill, and I connect PA6 to ground with a 10K resistor, analogRead(PA6) returns around 300 when the LED is on, and 0 when it's off. Is 10K not enough for a pulldown?
I don't have any issue with the built in LED on the board.
Re: ADC issue
Posted: Fri Jul 19, 2024 5:05 pm
by GonzoG
Checked with bluepill (F103) and blackpill (F411) and no problems. It reads 1-2 with LED connected.
There must be something wrong with your circuit.
If I connected 100 Ohm resistor to GND and then LED and pull down resistor to it, then I got ~150-170 with white, blue and green LEDs and ~350 with yellow and red LEDs, but this is expected as there is voltage loss on this 100 Ohm resistor and it depends on current drawn by LED.
Re: ADC issue
Posted: Sat Jul 20, 2024 5:33 am
working some numbers
300 / 4096 * 3.3 = 0.24v
Then look at some datasheets
https://downloads.cree-led.com/files/ds/h/HB-C4SMA.pdf
it turns out forward voltage can run from 2-3.8v
TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) table
given that if the voltage is measured across the 100 ohm resistor, 0.24v isn't after all incorrect
the other thing is to use a large sample time, especially if you are using a higher series resistance to the adc.
Re: ADC issue
Posted: Mon Jul 22, 2024 5:54 pm
by alexanderpruss
But the 100 ohm resistor is not connected to the ADC pin, only to V3 or another GPIO.
Re: ADC issue
Posted: Tue Jul 23, 2024 8:02 am
by STM32ardui
alexanderpruss wrote: Mon Jul 22, 2024 5:54 pm
Learn to describe your problem correctly, so everyone has the same understanding!
From your start posting
alexanderpruss wrote: Fri Jul 19, 2024 3:17 pm
When I put a standard red LED with a 100ohm resistor ... (or just between ground and V3) on my black pill, and I connect PA6 to ground with a 10K resistor ...
it can be this:
- ADC-problem.jpg (12.73 KiB) Viewed 3026 times
