Page 1 of 2
weact
Posted: Sun Jul 21, 2024 4:41 pm
I'm not too sure if this is after all weact's store
https://weactstudio.aliexpress.com/stor ... match_sort
but they seemed to have some new stm32 offerings
that stm32f103 'blue pill comes back'
stm32f411 'black pill' is there
stm32g431 the 'dac/opamp/comparator' board is there
high end boards stm32h723/h750 is there
stm32f405 is there
I particularly liked that stm32wb55cgu6 board, bluetooth LE yeah :P
etc
Re: weact
Posted: Sun Jul 21, 2024 7:37 pm
by Bakisha
I think it is their official store. I've been ordering from them for the last few years.
Their bluepill is genuine STM32F103CB, the only difference is the LED on PB2 (and with USB-C)
STM32G431CB has DAC, with OK results.
I didn't have time to test STM32F411CE (25Mhz) with 8MB flash.
I did test STM32F412RET6 and SdCard with STM32SD. I couldn't get to work 100% (it works, but it can't read all subfolders).
Only bad thing that i can say about those boards is user button being on Vcc side with very small resistor, and buttons are very stiff and small, hard to press it...
Re: weact
Posted: Mon Jul 22, 2024 7:11 am
the stm32 offerings are quite interesting
the new boards I think are like the
stm32f405 and stm32wb55cgu6
wb55cgu6 is a good one as I've yet to see any other vendors offering that for now
the git repository is apparently here
https://github.com/WeActStudio/WeActStu ... 5CoreBoard
and stm32f405 here
https://github.com/WeActStudio/WeActStu ... _CoreBoard
Re: weact
Posted: Mon Jul 22, 2024 9:52 am
by GonzoG
What's most important, is that they put all necessary data on github.
Exact dimensions, diagrams, 3d model, example source code, even chip pdfs so you don't need to look anywhere else.
One thing I would like to see is a series of mini boards like seeed studio xiao but with STM's ULP MCUs.
Re: weact
Posted: Thu Aug 08, 2024 11:31 am
by STM32ardui
WeActStudio now have the STM32G474 also as "long board" .
And a new STM32H503CBU6: 128 kB Flash and 32 kB RAM, with 250 MHz may be a little bit faster than STM32G431.
Cortex-M33 ...
Re: weact
Posted: Wed Aug 28, 2024 3:18 pm
for the 'blue pill' stm32f103c8/b fans
https://www.aliexpress.com/item/1005004918334754.html
weact seemed to stock their version of 'black/blue' pills :)
the improvements(differences) apparently are:
- the LED is apparently at PB2 active high
- buttons for boot0 (instead of jumpers) and a user button
- sop8 pads for spi flash below
they have a nice github repository for it
https://github.com/WeActStudio/BluePill-Plus
Re: weact
Posted: Thu Aug 29, 2024 1:07 pm
by Bakisha
ag123 wrote: Wed Aug 28, 2024 3:18 pm
Also, there is different layout of pins for power near USB jack. On classic bluepill, it's GND-GND-3V, while on a weact's boards it's 5V-GND-3.3V
Re: weact
Posted: Sat Sep 07, 2024 5:57 pm
by GonzoG
There's new Black Pill with STM32H503CBU, 250 MHz, 128kB ROM, 32kB ROM. With 1 opamp and 1 comparator.
Pinout almost the same as F401/F411 black pills. Just one pin different, there's GND where PB9 was.
https://github.com/WeActStudio/WeActStu ... 3CoreBoard
https://www.aliexpress.com/item/1005007452157414.html
Re: weact
Posted: Sat Sep 07, 2024 8:08 pm
stm32h5 seemed to be a fairly new product line too
https://www.st.com/resource/en/datashee ... h503eb.pdf
cortex M33
quite similar to this I'd guess
viewtopic.php?t=2477
it is more like the F4 / G4 series with ART accelerator and all
I've got a H7 board
https://github.com/WeActStudio/WeActStu ... iSTM32H723
H7xx is apparently quite a different thing
https://www.st.com/resource/en/datashee ... h723zg.pdf
Cortex M7 with its own caches lines etc, the clock setup is also quite different from e.g. the F4xx, Cortex M4 series
H7 has system clocks that can literally be 'untangled' from the peripherals clocks
I'd guess the purpose is so that the cpu clocks can be changed on the fly without affecting IO which may require a fixed and/or lower clock speeds.
but that that setup is more 'complicated' vs F4 etc
for Cortex M33 accordingly it has an FPU
but that apparently it is same as F4
https://community.arm.com/support-forum ... -cortex-m4
while the simplified view of the FPU registers is like such
https://developer.arm.com/documentation ... -registers
what is often less mentioned are that the floating point registers are also mapped as vector registors
https://developer.arm.com/documentation/ddi0553/latest/
^ it is 'briefly' covered in chapter B5 of the Arm-v8M manual
those probably account for the Vxxx instructions covered in pm0264-stm32-cortexm33-mcus-programming-manual
3.10 Floating-point instructions
https://www.st.com/resource/en/programm ... ronics.pdf
that probably accounts for the "surprisingly fast" whetstone benchmarks seen in the F4 family
viewtopic.php?t=27
that makes it likely that those 'Mflops' are likely not bluff
viewtopic.php?p=939#p939
those could very well be deemed the 'DSP' instructions
those numbers rival 'old Intel Pentium 4' like 200 MFlops
http://www.roylongbottom.org.uk/whetstone%20results.htm
just that on Intel P4 that is double precision, so that is still a lot of difference
in hardware at least
but the single precision FPU speeds makes it possible to do various DSP tasks in real time that would likely otherwise be not feasible.
Re: weact
Posted: Sat Sep 14, 2024 2:37 pm
ok I got one of this in the mail bag
https://github.com/WeActStudio/WeActStu ... CoreBoard/
Quite a nice board really, but I've not yet tried it out to see how it works
accordingly, there could be some struggles with the SD card
viewtopic.php?p=14822#p14822
the marginal price difference between h503
vs h562
https://www.aliexpress.com/item/1005007502799023.html
seem to say that the h562 is a more worthwhile 'investment'
I'd guess h562 may fit pretty large stuff, such as an OS (Linux?), but that it'd be pretty cramp and with no MMU for that matter.
