How to output PWM
Posted: Tue Dec 17, 2024 3:05 pm
by narendra.desilva
Hi
Could someone please help me run PWM? I am using the code
#define LED_BUILTIN PE0
pinMode(LED_BUILTIN, OUTPUT);
analogWrite(LED_BUILTIN, 100);
The LED does not get dim but above 125 it is off and below 125 it is on.
Could somebody please help me to understand what is wrong and how to correct it.
Regards
Re: How to output PWM
Posted: Tue Dec 17, 2024 3:14 pm
Which board you used?
It seems PE0 has no timer that's why you don't have pwm.
Posted: Tue Dec 17, 2024 3:18 pm
by narendra.desilva
Hi
I am sorry I forgot to mention the Board. It is STM32F407VG diyMore Black.
PE0 is the BUILTIN_LED pin. I am trying to experiment PWM by checking the brightness of the LED.
regards
Posted: Tue Dec 17, 2024 3:37 pm
So PE0 has no TIM capability so no PWM. In that case analogWrite use it as a simple GPIO (0-127 LOW /128-256 HIGH).
Use one of those pins without '_' (PY_n -->PYn):
https://github.com/stm32duino/Arduino_C ... #L117-L186
Posted: Tue Dec 17, 2024 3:42 pm
by narendra.desilva
Hi
Thank you very much.
It is great to have this support.
Thanks and regards
Posted: Sun Dec 22, 2024 5:29 am
another way is to use the HardwareTimer directly
HardwareTimer *MyTim = new HardwareTimer(TIM3);
const uint8_t channel = 1;
void tim_callback() {
digitalWrite(LED_BUILTIN, ! digitalRead(LED_BUILTIN)); // toggle led
MyTim->pause();
MyTim->setOverflow(1000, HERTZ_FORMAT); // 1 kHz
MyTim->setCaptureCompare(channel, 500, MICROSEC_COMPARE_FORMAT); // 500 microseconds
MyTim->attachInterrupt(channel, tim_callback); //duty cycle
MyTim->attachInterrupt(tim_callback); //update event
MyTim->refresh();
MyTim->resume();
// wait for systick 1ms or any other interrupt, this runs cooler as the cpu is mostly in sleep mode
asm("wfi");
timers can drive gpio pins directly, for that refer to the ref manual and api ref
ref:
https://github.com/stm32duino/Arduino_C ... er-library
there is also a shortcut for all that setup using MyTim->setPWM() for all those configs
