[BluePill+] problem with USART interrups
Posted: Sat Jul 12, 2025 9:19 am
by trimarco232
in my current project , I am dealing with RS485 , on my way. I am writing directly into the registers , in order to know exactly what I am doing , and what happens
The problem here is that after receiving a byte , the program stops ; I don't now if it is just before it enters the ISR (USART3_IRQHandler) ,or later .
I have put the same code in CubeIDE , it works , so I wonder what happens in STM32duino ? Thanks !
(my skills to debug in STM32duino are limited because of the terrible each time to compile)
/* rs.h x : rs485 on usart3 /* ua_rt.h */
#define DE485 PB12
void usart3_setup() {
  RCC->APB1ENR |= RCC_APB1ENR_USART3EN;  // Enable clock
  // Configure PB10 (TX) and PB11 (RX)
  GPIOB->CRH &= ~(GPIO_CRH_CNF10 | GPIO_CRH_MODE10 | GPIO_CRH_CNF11 | GPIO_CRH_MODE11);  /// pas nécessaire ...
  GPIOB->CRH |= (GPIO_CRH_CNF10_1 | GPIO_CRH_MODE10_0 | GPIO_CRH_CNF11_0);               // alternate PP // input ... PU
  // Configure USART3
  USART3->BRR = 72000000 / 2 / 57600;                            // 57600 baud rate , APB1 is CLK/2
  USART3->CR1 = USART_CR1_TE | USART_CR1_RE | USART_CR1_RXNEIE;  // Enable TX and RX  // Enable RXNE interrupt
  USART3->CR1 |= USART_CR1_UE;                                   // Enable USART
  NVIC_EnableIRQ(USART3_IRQn);
  pinMode(DE485, OUTPUT);
void USART3_IRQHandler(void) {
  uint16_t data = USART3->DR;
   Serial.print("USART3->DR:");
  Serial.println(data);
Re: [BluePill+] problem with USART interrups
Posted: Sat Jul 12, 2025 10:06 am
extern "C" void USART3_IRQHandler(void)
And avoid print in ISR.
Posted: Sat Jul 12, 2025 11:10 am
by trimarco232
thanks ,
I tried it but got : (.text.USART3_IRQHandler+0x0): multiple definition of `USART3_IRQHandler';
(ok to avoid to print in ISR)
Posted: Sat Jul 12, 2025 12:23 pm
That is normal. The handler is already defined for the serial. You have to comment it in the core if you want use Serial. Else you can define the HAL_UART_MODULE_ONLY but Serial instance will be disabled.
https://github.com/stm32duino/Arduino_C ... odule-only
Posted: Sat Jul 12, 2025 5:56 pm
by trimarco232
I can not change Serial , because I need it for the USB
Can you please tell me where I can find the function "USART3_IRQHandler" in the core , which folder and which file : I was looking for it in Arduino15 , but with no success yet
Posted: Sun Jul 13, 2025 12:36 am
by ozcar
For me Windows File Explorer search (if that is what you did) often tricks me, but I was just looking at another core interrupt routine a few days ago, so I had a clue where to start, and I found it in
Arduino15\packages\STMicroelectronics\hardware\stm32\<version>\libraries\SrcWrapper\src\stm32\uart.c
Posted: Wed Jul 16, 2025 8:42 pm
by trimarco232
yes , that was it , thank you all !
I just modified the name of the function "USART3_IRQHandler" in the uart.c file , and now it works fine (even if I consider it to be a shame to have to do it this way ; I will look for some better HAL function instead)
(But the most important thing is that I can continue and probably finish my project , still no error on my PCB)
Posted: Thu Jul 17, 2025 5:02 am
If you used USB you should be able to define HAL_UART_MODULE_ONLY then no need to change core file.
