Getting the Netduino 2 (STM32F205) working via STM32duino
KarlF
Post by KarlF »
First a big 'Thank You!' to the maintainers of this toolset and forum. I was able to rediscover and find new uses for my outdated and unsupported Netduino 2 board. A board I thought was obsolete. I'm still exploring how I can use STM32duino with this board but getting it programmed via the Arduino IDE, was a major milestone. Hopefully, there is more to come,
The Netduino 2 uses a STM23F205RFT6 MCU, has a user button (PB11/PC14), a blue user-programmable LED (PA10), and the usual Arduino Uno layout with 6 analog and 15 digital pins. The schematic is on Github. Not sure why the button is wired to two pins, but both pin numbers worked in Arduino for the single button. Here's what I did to get this working.
1. Install the STM32CubeProgrammer
2. Open the Arduino IDE 2 and add this additional board manager URL
  1. File -> Preferences -> Additional Board Manager URls
  2. https://github.com/stm32duino/BoardMana ... index.json
3. Install the Board Package
  1. Tools -> Board -> Board Manager
  2. Search for and install the 'STM32 MCU based boards by STMicroelectronics' package.
4. Select the board...
  1. Tools -> Boards
  2. Expand the new 'STM32 MCU Based Boards' sub menu.
  3. Select the 'Generic STM32F2 Series' board
5. Configure the board settings (from the Tools menu)
  1. Click on the Tools menu
  2. Adjust the following additional board settings:
    • Board Port Number: STM32F205RFTx
    • Upload Method: STM32CubeProgrammer (DFU)
    • USB Support: CDC generic 'Serial' supersede U(S)ART'
Now you can use the Arduino IDE to write and upload your code to the Netduino. Try the Blink example using 'PA10' for the LED pin. Before you can upload code to the board, you'll need to put it in bootloader mode. This is done by holding down the user button (BTN) while applying power. When in bootloader mode, both the white and blue LEDs will be lit and remain lit, and the device will appear as 'STMicroelectronics STM Device in DFU Mode' in device manager (Windows) or the command line 'lsusb' (Linux).
If your using Linux and run into issues during code upload, where the Arduino IDE can't find the programmer due to a problem with the PATH, try this fix which worked for me.
That should be it. With this setup you should be able to get all kinds of Arduino sketches running on the Netduino 2.
Here's the pin mapping from MCU to Board. These were pulled from the schematic (which had a few typo's i.e. there are two PB5, one should be PB6). I've not tested all of them so let me know if there are any corrections needed. It'd be nice to have this list also show the alternate pin functions. Although, that is something for another day
| MCU Pin | Board Pin |
|   PC0   |    A0     |
|   PC1   |    A1     |
|   PC2   |    A2     |
|   PC3   |    A3     |
|   PC4   |    A4     |
|   PC5   |    A5     |
|   PC7   |    D0     |
|   PC6   |    D1     |
|   PA3   |    D2     |
|   PA2   |    D3     |
|   PB12  |    D4     |
|   PB8   |    D5     |
|   PB9   |    D6     |
|   PA1   |    D7     |
|   PA0   |    D8     |
|   PA6   |    D9     |
|   PB10  |    D10    |
|   PB15  |    D11    |
|   PB14  |    D12    |
|   PB13  |    D13    |
|   PB7   |    SCA    |
|   PB6   |    SCL    |
|   PA10  | Blue LED  |
|   PC13  | Power LED |
|   PB11  | User Btn  |
|   PC14  | User Btn  |
Stay Curious!
Return to “STM32F2 based boards”
