However I've ran into some issue that might actually be a bug in the library.
Firstly on a fresh pull from github, the config file untouched. I get the error ... when trying to compile.
..\STM32FreeRTOS\portable\MemMang\heap_1.c:61:24: error: variably modified 'ucHeap' at file scope
61 | static uint8_t ucHeap[ configTOTAL_HEAP_SIZE ];
On line 115
#define configTOTAL_HEAP_SIZE ((size_t)((uint32_t)&_estack - (uint32_t)&_Min_Stack_Size - (uint32_t)&_end))
extern char _end; /* Defined in the linker script */
extern char _estack; /* Defined in the linker script */
extern char _Min_Stack_Size; /* Defined in the linker script */
Secondly _Min_Stack_Size = 0x400; /* required amount of stack */ wont fit within a char
And nor would _estack = ORIGIN(RAM) + LENGTH(RAM); /* end of "RAM" Ram type memory */ fit within a char.
If I have made a mistake in this varient setup where these defines are meant to be more properly ... defined somewhere... Or if i need to manually set these values within the freertos config. Please let me know. But at the moment this looks like a bug.
