Custom Variant Startup File - Error if defined in boards.txt
kjn
Post by kjn »
I've created a custom variant according to the guide: https://github.com/stm32duino/Arduino_C ... 28board%29
In this particular case, its an F042 board with a custom bootloader, I've been able to adjust the linker script in the variant successfully, however I also require some changes to the start-up file.
I followed this guide: https://github.com/stm32duino/Arduino_C ... efinitions
In boards.txt I added the following line to the board-def.
GenF0.menu.pnum.CAN_F042K6TX.build.startup_file=-DCUSTOM_STARTUP_FILE
and added the required .S file to the variant folder (modified from the provided CMSIS template)
However, when this line is enabled I am getting an error - essentially it cannot find the file in the variant folder.
In file included from C:\Users\user\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.11.0\cores\arduino\stm32\startup_stm32yyxx.S:1:
C:\Users\user\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.11.0\cores\arduino\stm32\stm32_def_build.h:541:4: warning: #warning "No CMSIS startup file defined, custom one should be used" [-Wcpp]
  541 |   #warning "No CMSIS startup file defined, custom one should be used"
Sketch uses 11892 bytes (52%) of program storage space. Maximum is 22528 bytes.
Global variables use 1212 bytes (20%) of dynamic memory, leaving 4740 bytes for local variables. Maximum is 5952 bytes.
The variant folder is correctly defined, the variant definitions and header file are correctly found and build will work with the default .S file if this is commented out - am I missing something with respect to the startup_file definition?
Input appreciated.
