Page 1 of 2
Not able to upload code using STLINK ans uart
Posted: Fri Mar 27, 2020 3:13 pm
by ALLSPARK
I tried STLINK2 and FTDI to blink . No success so far!
I am using Arduino 1.8.12 and latest STM32 core.
STLINK and FTDI are completely working and being detected easily.
I am using bluepill stm32f103c8t6.
Where am i going wrong?
Re: Not able to upload code using STLINK ans uart
Posted: Fri Mar 27, 2020 5:27 pm
Which option did you select in the menu and how did you connect STLink and FTDI ?
Posted: Thu Apr 30, 2020 5:59 pm
by electrobling
I have exactly the same problem. Also Arduino IDE 1.8.12 with ST-Link V2. STM core is version 1.8.0.
I downloaded the driver from the ST site, turned antivirus off and followed directions to install as administrator. Everything looked okay.
I have verified ST-Link is connected and working in Windows 10 Device Manager - USB Devices.
The ST-Link is plugged into a USB port on a Lenovo T430 laptop.
I checked the wires between the STLink and device board three times.
My settings:
board - generic STM32F103C
variant - STM32F103C8
upload method - STLink
My sketch compiles okay, reports upload is successful. However, lights on the ST-Link don't blink as they usually do, and the sketch is never uploaded (it's still running the factory blink test).
I haven't tried the FTDI yet.
Posted: Thu Apr 30, 2020 6:11 pm
So you have installed the STM32CubeProgrammer?
Try to connect with it to the board.
Posted: Thu Apr 30, 2020 6:29 pm
by electrobling
I installed STM32cubeprogrammer, I can connect to the board and see object code. Arduino IDE still behaves the same.
Posted: Thu Apr 30, 2020 7:27 pm
Could you share the output log?
With all output enabled in the preference settings.
Posted: Thu Apr 30, 2020 7:53 pm
by electrobling
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ken\Documents\ArduinoData\packages -hardware C:\Users\ken\Documents\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ken\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ken\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10812 -build-path C:\Users\ken\AppData\Local\Temp\arduino_build_782031 -warnings=none -build-cache C:\Users\ken\AppData\Local\Temp\arduino_cache_877129 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ken\Documents\Arduino\BP_BlinkWithoutDelay\BP_BlinkWithoutDelay.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ken\Documents\ArduinoData\packages -hardware C:\Users\ken\Documents\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ken\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ken\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10812 -build-path C:\Users\ken\AppData\Local\Temp\arduino_build_782031 -warnings=none -build-cache C:\Users\ken\AppData\Local\Temp\arduino_cache_877129 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ken\Documents\Arduino\BP_BlinkWithoutDelay\BP_BlinkWithoutDelay.ino
Using board 'genericSTM32F103C' from platform in folder: C:\Users\ken\Documents\Arduino\hardware\Arduino_STM32\STM32F1
Using core 'maple' from platform in folder: C:\Users\ken\Documents\Arduino\hardware\Arduino_STM32\STM32F1
Detecting libraries used...
"C:\\Users\\ken\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10812 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\sketch\\BP_BlinkWithoutDelay.ino.cpp" -o nul
"C:\\Users\\ken\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10812 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\sketch\\BP_BlinkWithoutDelay.ino.cpp" -o "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\ken\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10812 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\sketch\\BP_BlinkWithoutDelay.ino.cpp" -o "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\sketch\\BP_BlinkWithoutDelay.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_782031\core\wirish\start.S.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_782031\core\wirish\start_c.c.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_782031\core\wirish\boards_setup.cpp.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_782031\core\wirish\boards.cpp.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_782031\core\board.cpp.o
Using precompiled core: C:\Users\ken\AppData\Local\Temp\arduino_cache_877129\core\core_0c71c4bc149ce52aa159c88efa0ba277.a
"C:\\Users\\ken\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections -mcpu=cortex-m3 "-TC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c/ld/jtag_c8.ld" "-Wl,-Map,C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031/BP_BlinkWithoutDelay.ino.map" "-LC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c/ld" -specs=nosys.specs -specs=nano.specs -u _printf_float -u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid -o "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031/BP_BlinkWithoutDelay.ino.elf" "-LC:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\sketch\\BP_BlinkWithoutDelay.ino.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\core\\wirish\\start.S.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\core\\wirish\\start_c.c.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\core\\board.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\core\\wirish\\boards.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031\\core\\wirish\\boards_setup.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_cache_877129\\core\\core_0c71c4bc149ce52aa159c88efa0ba277.a" -Wl,--end-group
"C:\\Users\\ken\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031/BP_BlinkWithoutDelay.ino.elf" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031/BP_BlinkWithoutDelay.ino.bin"
"C:\\Users\\ken\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_782031/BP_BlinkWithoutDelay.ino.elf"
Sketch uses 22376 bytes (34%) of program storage space. Maximum is 65536 bytes.
Global variables use 2200 bytes (10%) of dynamic memory, leaving 18280 bytes for local variables. Maximum is 20480 bytes.
C:\Users\ken\Documents\Arduino\hardware\Arduino_STM32/tools/win/stlink_upload.bat {upload.altID} {upload.usbID} C:\Users\ken\AppData\Local\Temp\arduino_build_782031/BP_BlinkWithoutDelay.ino.bin
Invalid library found in C:\Users\ken\Documents\Arduino\libraries\Arduino: no headers files (.h) found in C:\Users\ken\Documents\Arduino\libraries\Arduino
The last 2 lines were due to another problem, which I have since fixed. When the upload.bat runs during the compile/upload procedure (last line in the log normally), it completes instantaneously and "Done Uploading" appears in the Arduino IDE window.
Posted: Fri May 01, 2020 12:23 pm
by stevestrong
Try to use Arduino 1.8.10 or 12, the very latest version can always have bugs.
Posted: Fri May 01, 2020 1:04 pm
This is the Windows store version, this should work.
You should enable the verbose for the upload also to see what happened
Posted: Fri May 01, 2020 3:44 pm
by electrobling
I began to revert to 1.8.10 before I saw your reply. If you think 1.8.12 should work, I will re-install it and try again.
Edit - I went ahead and installed 1.8.10 to see what would happen - I get the same behaviour. I have both verbose compilation and upload boxes checked in preferences.. I also tried disabling the anti-virus and I checked permissions on the upload bat file, for what that is worth. This log is from 1.8.10:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ken\AppData\Local\Arduino15\packages -hardware C:\Users\ken\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ken\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ken\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10810 -build-path C:\Users\ken\AppData\Local\Temp\arduino_build_436672 -warnings=none -build-cache C:\Users\ken\AppData\Local\Temp\arduino_cache_107096 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ken\AppData\Local\Temp\untitled1278292926.tmp\sketch_may01a\sketch_may01a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ken\AppData\Local\Arduino15\packages -hardware C:\Users\ken\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ken\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ken\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10810 -build-path C:\Users\ken\AppData\Local\Temp\arduino_build_436672 -warnings=none -build-cache C:\Users\ken\AppData\Local\Temp\arduino_cache_107096 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ken\AppData\Local\Temp\untitled1278292926.tmp\sketch_may01a\sketch_may01a.ino
"C:\\Users\\ken\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10810 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\sketch\\sketch_may01a.ino.cpp" -o nul
"C:\\Users\\ken\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10810 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\sketch\\sketch_may01a.ino.cpp" -o "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\ken\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOC -DERROR_LED_PIN=13 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10810 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8 -mthumb -march=armv7-m -D__STM32F1__ "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/stm32f1/include" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/stm32f1" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\system/libmaple/usb/usb_lib" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\cores\\maple" "-IC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\sketch\\sketch_may01a.ino.cpp" -o "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\sketch\\sketch_may01a.ino.cpp.o"
Compiling core...
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_436672\core\wirish\start.S.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_436672\core\wirish\start_c.c.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_436672\core\wirish\boards.cpp.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_436672\core\wirish\boards_setup.cpp.o
Using previously compiled file: C:\Users\ken\AppData\Local\Temp\arduino_build_436672\core\board.cpp.o
Using precompiled core: C:\Users\ken\AppData\Local\Temp\arduino_cache_107096\core\core_0c71c4bc149ce52aa159c88efa0ba277.a
"C:\\Users\\ken\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections -mcpu=cortex-m3 "-TC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c/ld/jtag_c8.ld" "-Wl,-Map,C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672/sketch_may01a.ino.map" "-LC:\\Users\\ken\\Documents\\Arduino\\hardware\\Arduino_STM32\\STM32F1\\variants\\generic_stm32f103c/ld" -specs=nosys.specs -specs=nano.specs -u _printf_float -u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid -o "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672/sketch_may01a.ino.elf" "-LC:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\sketch\\sketch_may01a.ino.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\core\\wirish\\start.S.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\core\\wirish\\start_c.c.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\core\\board.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\core\\wirish\\boards.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672\\core\\wirish\\boards_setup.cpp.o" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_cache_107096\\core\\core_0c71c4bc149ce52aa159c88efa0ba277.a" -Wl,--end-group
"C:\\Users\\ken\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672/sketch_may01a.ino.elf" "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672/sketch_may01a.ino.bin"
"C:\\Users\\ken\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\ken\\AppData\\Local\\Temp\\arduino_build_436672/sketch_may01a.ino.elf"
Sketch uses 21864 bytes (33%) of program storage space. Maximum is 65536 bytes.
Global variables use 2192 bytes (10%) of dynamic memory, leaving 18288 bytes for local variables. Maximum is 20480 bytes.
C:\Users\ken\Documents\Arduino\hardware\Arduino_STM32/tools/win/stlink_upload.bat {upload.altID} {upload.usbID} C:\Users\ken\AppData\Local\Temp\arduino_build_436672/sketch_may01a.ino.bin
