STM32F103C8 BluePill VGA Project
What are you developing?
feluga
Re: STM32F103C8 BluePill VGA Project
Post by feluga »
Bakisha wrote:
Thu Sep 03, 2020 7:49 pm
I was thinking BSRR was good choice because it would be possible to use other ports. Yes, it's 32bit register, what i had in mind to use two buffers of 4*pixels bytes per line, and in interrupt use something like:
-Set DMA to send 1st/2nd buffer (with few flags as "if" statement, and always same execution time +/- few cycles)
-Calculate 2nd/1st buffer as stream of 4bytes (32bits) for BSRR (this is not time critical, since DMA is already sending 1st/2nd buffer in background)
-exit interrupt
Only thing to find out is how much cycles is DMA transfer delayed when triggered every 8 cpu ticks (for 224 pixels resolution).
Time for me to dive into RM0008 Reference manual again and find a way to drive DMA with timer :geek:
It sounds like a good plan!
I know that you shall set Timer DIER to update generated DMA, for instance.
Check DMA/Channel linked to that TIMER/Event and set it up to be Memory to Peripheral direction.
Parallel processing with DMA, especially when accessing memory will sufer from bus access arbitration and this may lead to some pixels bigger than others.
But, for sure, it is worth trying!
Let us know about your progress.
feluga
Post by feluga »
Here goes some links that may help on getting DMA+Timer --> GPIO to work:
Some documentation about DMA and paralellism
Check this:
chapter 5 - DMA latency
5.3 Sharing the bus matrix with CPU
AN2548 Application note - Using the STM32F0/F1/F3/Gx/Lx Series DMA controller
Although this AN is not for F103, the general concept will help:
AN4666 Application note - Parallel synchronous transmission using GPIO and DMA
Some links of discussion:
DMA-> GPIO STM32f103
Can STM32F103c8T6 transfer data from memory to GPIO
Not for BluePill, but helps :: STM32E407 Timer->DMA->GPIO
Bakisha
Answers: 3
Post by Bakisha »
Well, i have good news and bad news :)
Good news is that i was able to make timer 4 channel 1 trigger dma to stream memory to BSRR register (i just altered sketch that i had for streaming memory to SPI), but the bad news is that it not much usefull for VGA timings. Once i found what registers and bits to set, i first set overflow of timer to 72 (1uS) and it was running great, but as i lowered overflow, for values lower then 18 (249,84nS) pulses started to have same width and stayed at around 250nS for any overflow less then 18. My guess it is 32bit DMA read-write + CPU time. Will test some day with 8bit values to some other register (maybe ODR), but for now i'll leave it as-is.
I'll attach some pics from logic analyzer and sketch that used for testing.
Pictures.zip
(93.75 KiB) Downloaded 33 times
DMA_TIM_BSSR_test001.rar
(2.16 KiB) Downloaded 31 times
feluga
Post by feluga »
Bakisha wrote:
Fri Sep 04, 2020 1:09 am
.. it was running great, but as i lowered overflow, for values lower then 18 (249,84nS) pulses started to have same width and stayed at around 250nS for any overflow less then 18. My guess it is 32bit DMA read-write + CPU time. Will test some day with 8bit values to some other register (maybe ODR), but for now i'll leave it as-is.
Very Nice Bakisha!
I tested also it, but I changed two things to DMA_TIM_BSSR_test001.ino:
1) DMA sets Peripheral size to 8 bits instead of 32 bits
2) DMA CPAR pointing to ((uint32_t)&GPIOA->ODR)
Results:
Minimal overflow with effect is now 7 (97.2 ns), enough for 262 horizontal pixels.
VGA 640x480@60HZ needs 25.42 us for visible scanline.
With overflow on 8 we get 111.11 ns x 224 = 24.89us (a VGA fit with borders - OK)
This is with no parallel processing (in the sketch it runs a delay(), which has no load on CPU or Bus).
It sounds promising!
Bakisha
Answers: 3
Post by Bakisha »
feluga wrote:
Fri Sep 04, 2020 6:27 pm
Results:
Hopefully, 37.177 uS should be enough time to calculate next scanline.
I also tested with 8bit data to ODR, and i still get minimum time of 250nS. Maybe SK32F103c8 clone issue? Well, at least i know a little more then yesterday :)
Good luck with your library, you are doing good job so far!
feluga
Post by feluga »
Bakisha wrote:
Fri Sep 04, 2020 9:21 pm
Thanks Bakisha!
I've made it work generating 256 colors using GPIOB PB8 to PB15 plus 8 resistors (2K, 1K, 500R for Red and Green, 520R 390R for Blue).
The result is a colorful screen similar to the one we used to see in the 90's.
Some screenshots of a scrolling demo with "a Mario theme":
Check out the video of the scrolling scene:
https://www.youtube.com/watch?v=D1Ie7qcdRL4
Bakisha
Answers: 3
Post by Bakisha »
Nice! That's some NES level 8bit graphic :-)
DMA stream to ODR or BSSR?
Is resolution stll 224x240?
feluga
Post by feluga »
Bakisha wrote:
Tue Sep 15, 2020 5:19 pm
Yes, that's the initial target. I'm trying to push it to the limit and get something between NES and SNES.
No, still direct bitbanging to ODR. DMA suffers from lack of BUS Matrix access priorization mechanisms.
Although DMA can be used, it's not feasible for VGA because the timing and synchronism of pixels are the key for a good image.
Resolution increased to 256 x 240. This particular demo uses 224x208.
Return to “Projects”
