How to use SPI2
SphericalSound
How to use SPI2
Post by SphericalSound »
Hi!. So happy to see the forum working again. First time poster here!! :D
Im using a library in the bluepill that uses the SPI. It works but it´s glitchy.
The SPI standard pins are :
PA7 - mosi
PA5 - clk
I would like use the alterante pins:
PB5 - mosi
PB3 - clk
Or SPI2
PB15 mosi2
PB13 clk2
How do I signal to use alternate pins? Im using bluepill under arduino or platformio IDEs
Roger Clark, the creator of the libary said to do:
SPI.setMOSI(PB15);
SPI.setMISO(PB14);
SPI.setSCLK(PB13);
SPI.begin();
Or:
SPIClass SPI_2(PB15,PB14,PB13);
SPI_2.begin();
But this commands are not anymore in the library.
I have read something about SPIclass but I can´t get it to work... Any hints?
Thank you so much
stas2z
Answers: 8
Re: How to use SPI2
Post by stas2z »
SphericalSound wrote: Sun May 17, 2020 4:08 pm Roger Clark, the creator of the libary said to do:
SPI.setMOSI(PB15);
SPI.setMISO(PB14);
SPI.setSCLK(PB13);
SPI.begin();
Or:
SPI_2.begin();
Thank you so much
you are wrong a little bit ) Roger never said what you mentioned
cuz these commands work only with offcial core, not Roger's one)
in case of using roger's core check the example provided py Roger
https://github.com/rogerclarkmelbourne/ ... _ports.ino
a few words about platformio
depends on which board you selected, your platformio project can use roger's (maple target) or official (stm32 target) core and those cores are not compatible in case of SPI
feluga
Re: How to use SPI2
Post by feluga »
SPI.setMOSI(PB15);
SPI.setMISO(PB14);
SPI.setSCLK(PB13);
SPI.begin();
Or:
SPI_2.begin();
This is related to Official STM32 Core.
https://github.com/rogerclarkmelbourne/ ... issues/432
feluga
Re: How to use SPI2
Post by feluga »
This post has an exemple on how to use SPI2 with Roger's core:
https://github.com/rogerclarkmelbourne/ ... 2/pull/536
  // Source: https://community.platformio.org/t/pio-arduino-stm32f103cbt6-remap/6786/5
  afio_cfg_debug_ports(AFIO_DEBUG_SW_ONLY); // PB3 free
  afio_remap(AFIO_REMAP_SPI1);
  gpio_set_mode (GPIOB, 3, GPIO_AF_OUTPUT_PP);
  gpio_set_mode (GPIOB, 4, GPIO_INPUT_FLOATING);
  gpio_set_mode (GPIOB, 5, GPIO_AF_OUTPUT_PP);
Example:
    SPI_1 and SPI_2 port example code
    Description:
    This sketch sends one byte with value 0x55 over the SPI_1 or SPI_2 port.
    The received byte (the answer from the SPI slave device) is stored to the <data> variable.
    The sketch as it is, works with SPI_1 port. For using the SPI_2 port, just
    un-comment all the nessesary code lines marked with <SPI_2> word.
    Created on 10 Jun 2015 by Vassilis Serasidis
    email:  avrsite@yahoo.gr
    Using the first SPI port (SPI_1)
    SS    <-->  PA4 <-->  BOARD_SPI1_NSS_PIN
    SCK   <-->  PA5 <-->  BOARD_SPI1_SCK_PIN
    MISO  <-->  PA6 <-->  BOARD_SPI1_MISO_PIN
    MOSI  <-->  PA7 <-->  BOARD_SPI1_MOSI_PIN
    Using the first SPI port (SPI_1) REMAPPED
    SS    <-->  PA15 <-->  BOARD_SPI1_NSS_PIN
    SCK   <-->  PB3 <-->  BOARD_SPI1_SCK_PIN
    MISO  <-->  PB4 <-->  BOARD_SPI1_MISO_PIN
    MOSI  <-->  PB5 <-->  BOARD_SPI1_MOSI_PIN
    Using the second SPI port (SPI_2)
    SS    <-->  PB12 <-->  BOARD_SPI2_NSS_PIN
    SCK   <-->  PB13 <-->  BOARD_SPI2_SCK_PIN
    MISO  <-->  PB14 <-->  BOARD_SPI2_MISO_PIN
    MOSI  <-->  PB15 <-->  BOARD_SPI2_MOSI_PIN
#include <SPI.h>
#define SPI1_NSS_PIN PA15 //PA4    //SPI_1 Chip Select pin is PA4. You can change it to the STM32 pin you want.
#define SPI2_NSS_PIN PB12   //SPI_2 Chip Select pin is PB12. You can change it to the STM32 pin you want.
SPIClass SPI_2(2); //Create an instance of the SPI Class called SPI_2 that uses the 2nd SPI Port
byte data;
  // Remap SPI 1
  // Setup SPI 1
  SPI.begin(); //Initialize the SPI_1 port.
  SPI.setBitOrder(MSBFIRST); // Set the SPI_1 bit order
  SPI.setDataMode(SPI_MODE0); //Set the  SPI_2 data mode 0
  SPI.setClockDivider(SPI_CLOCK_DIV16);      // Slow speed (72 / 16 = 4.5 MHz SPI_1 speed)
  pinMode(SPI1_NSS_PIN, OUTPUT);
  // Setup SPI 2
  SPI_2.begin(); //Initialize the SPI_2 port.
  SPI_2.setBitOrder(MSBFIRST); // Set the SPI_2 bit order
  SPI_2.setDataMode(SPI_MODE0); //Set the  SPI_2 data mode 0
  SPI_2.setClockDivider(SPI_CLOCK_DIV16);  // Use a different speed to SPI 1
  pinMode(SPI2_NSS_PIN, OUTPUT);
  sendSPI();
  sendSPI2();
  delayMicroseconds(10);    //Delay 10 micro seconds.
void sendSPI()
  digitalWrite(SPI1_NSS_PIN, LOW); // manually take CSN low for SPI_1 transmission
  data = SPI.transfer(0x55); //Send the HEX data 0x55 over SPI-1 port and store the received byte to the <data> variable.
  digitalWrite(SPI1_NSS_PIN, HIGH); // manually take CSN high between spi transmissions
void sendSPI2()
  digitalWrite(SPI2_NSS_PIN, LOW); // manually take CSN low for SPI_2 transmission
  data = SPI_2.transfer(0x55); //Send the HEX data 0x55 over SPI-2 port and store the received byte to the <data> variable.
  digitalWrite(SPI2_NSS_PIN, HIGH); // manually take CSN high between spi transmissions
SphericalSound
Re: How to use SPI2
stas2z wrote: Sun May 17, 2020 4:13 pm
Thank you so much for the info. What are the differences between Roger´s and Official ones?
What would you use?
Thank you so much :)
SphericalSound
Re: How to use SPI2
feluga wrote: Sun May 17, 2020 4:23 pm
SPI.setMOSI(PB15);
SPI.setMISO(PB14);
SPI.setSCLK(PB13);
SPI.begin();
Or:
SPI_2.begin();
I totally didnt know that there were 2 cores. Im only one week with the bluepill but loving it to bits. thanks for explaining this
SphericalSound
Re: How to use SPI2
feluga wrote: Sun May 17, 2020 4:35 pm This post has an exemple on how to use SPI2 with Roger's core:
Example:
    Description:
#include <SPI.h>
byte data;
  // Remap SPI 1
  // Setup SPI 1
  // Setup SPI 2
  sendSPI();
  sendSPI2();
void sendSPI()
void sendSPI2()
I have been looking for this something like one solid week non stop... No idea wjere you get it, but to me it seems solid gold. I will try. Thank you all!!
Re: How to use SPI2
SphericalSound wrote: Sun May 17, 2020 11:53 pm ...
What would you use?
There are 4 or more cores, 3 which are viable: Official, Roger's, Steve's
https://stm32duinoforum.com/forum/viewt ... _3111.html
But only one core has the weight of STM and a dedicated staff and this forum to dialog with casual users of STM32 ARM uC, we call that one "Official" core: https://github.com/stm32duino/Arduino_Core_STM32
Steve (a founding member) uses Steve's core which is derived from Roger's core with some nice tweets. Roger's core was inherited from LeafLab's original effort: https://github.com/leaflabs/maple but that effort became unsupported around the time of ArduinoIDE ver 1.5x
If you are a professional developer, use the Official core as it is well supported, has an upgrade path to professional tools and corporate support. If you are a hobbyist or even doing a really small for-sale project or prototype, then Roger's core will conform well to Arduino'ish expectations.
Of course, others may have different opinions.
mrguen
Re: How to use SPI2
Post by mrguen »
Hello, Thanks for the code example.
1) I get the error
'AFIO_DEBUG_SW_ONLY' was not declared in this scope
on STM32F401RCT6 (CoreBoard) / STM32 Cores 1.9.0
2) Is it possible to use the remapped SPI2 (SCK: PB13, MOSI: PC3, MISO: PC2)?
Answers: 109
Re: How to use SPI2
mrguen wrote: Wed Jul 15, 2020 11:34 am Hello, Thanks for the code example.
1) I get the error
As mentionned by @feluga the given example code using AFIO_DEBUG_SW_ONLY is for LibMaple core from Roger:
https://github.com/rogerclarkmelbourne/ ... pio.h#L399
mrguen wrote: Wed Jul 15, 2020 11:34 am 2) Is it possible to use the remapped SPI2 (SCK: PB13, MOSI: PC3, MISO: PC2)?
For the Core board (STM32F401RC) by default the SPI instance uses SPI1 with pins:
SCK: PA5, MOSI: PA7, MISO: PA6.
You have two possibilities:
  1. Change the pins used by default if you don't want use the SPI1 as explained in the WiKi:
    https://github.com/stm32duino/wiki/wiki ... tance-pins
    SPI.setMOSI(PC3);
    SPI.setMISO(PC2);
    SPI.setSCLK(PB13);
    SPI.begin();
  • Define a new instance:
    SPIClass SPI_2(PC3, PC2, PB13);
    SPI_2.begin();
