Problem with G070KB support
sr28
Post by sr28 »
I have been attempting to add generic support for the G070KB processor but have run into a few issues. I have managed to create other boards (following the 'Add New Varient' guide) without problem but I am in a bit over my head with this problem.
I have created all the required files (ldscript using STM32CubeMX and compared them to the examples ones), Peripheral pins and PinNamesVar from the offical github page and checked them as well and finally created generic varient.h and varient.cpp based off the datasheet for the microcontroller (the 32 pin LQFP version). I have also added the appropriate lines in boards.txt
However when I try and compile the blink program, I get the following errors:
Arduino15/packages/STM32/hardware/stm32/1.9.0/cores/arduino/stm32/timer.h:79:19: error: 'TIM7_LPTIM2_IRQn' undeclared (first use in this function)
   79 | #define TIM7_IRQn TIM7_LPTIM2_IRQn
Arduino15/packages/STM32/hardware/stm32/1.9.0/libraries/SrcWrapper/src/stm32/timer.c:404:16: note: in expansion of macro 'TIM7_IRQn'
  404 |         IRQn = TIM7_IRQn;
Arduino15/packages/STM32/hardware/stm32/1.9.0/cores/arduino/stm32/uart.h:103:21: error: 'USART3_4_LPUART1_IRQn' undeclared (first use in this function)
  103 | #define USART3_IRQn USART3_4_LPUART1_IRQn
Arduino15/packages/STM32/hardware/stm32/1.9.0/libraries/SrcWrapper/src/stm32/uart.c:180:16: note: in expansion of macro 'USART3_IRQn'
  180 |     obj->irq = USART3_IRQn;
These seem to indicate problems with TIM7 / LPTIM2 but these do not appear in the PeripheralPins.c configuration.
Any help would be greatly appreciated! Thanks
by fpiSTM » Fri Aug 07, 2020 8:37 am
Hi @sr28
I've made a fix:
https://github.com/stm32duino/Arduino_C ... /pull/1141
Could you try it, please?
Think to revert your workaround in stm32g070xx.h.
Re: Problem with G070KB support
Hi @sr28
I think this is due to an issue in the core. It probably missed a guard in the timer.h when it handle the TIM IRQ and handler definition.
Could you share your variant then I will b able to fix it.
sr28
Post by sr28 »
Thanks for getting to this!
I managed to get a semi-work around but I'm not hugely familiar with the configuration files. I found that by adding
  USART1_IRQn                 = 27,     /*!< USART1 Interrupt                                                  */
  USART2_IRQn                 = 28,     /*!< USART2 Interrupt                                                  */
  USART3_4_IRQn               = 29,     /*!< USART3, USART4 globlal Interrupts                                 */
  TIM7_LPTIM2_IRQn            = 18,     // <-- These two lines here
  USART3_4_LPUART1_IRQn       = 29,   //
} IRQn_Type;
to the bottom of the stm32g070xx.h file in
STM32/hardware/stm32/1.9.0/cores/system/Drivers/Device/ST/STM32G0xx/Include/
It allowed the code to compile and work correctly for my application. I'm not sure that this is a correct fix however. I did have a look in timer.h file but it seemed to me that there was some differences between the above files (STM32/hardware/stm32/1.9.0/cores/system/Drivers/Device/ST/STM32G0xx/Include/stm32g070xx.h and STM32/hardware/stm32/1.9.0/cores/system/Drivers/Device/ST/STM32G0xx/Include/stm32g071xx.h) which would cause the guards to have no affect. I'm guessing this because the only thing the timer.h file checks is whether the stm32g0xx.h file is called and not the specific chip. Which I also presumed meant that the internals to the two chips would be extremely similar. Unless I have it totally wrong!! (The most likely case)
My variant.cpp file is below. I'd be interested to here if there was anything in it you would change. I used the STM32CubeMX tool to generate the clock code as the other similar boards where giving me different numbers for the PLLM, PLLN, PLLP and PLLR values.
 * Copyright (c) 2019, STMicroelectronics
 * All rights reserved.
 * This software component is licensed by ST under BSD 3-Clause license,
 * the "License"; You may not use this file except in compliance with the
 * License. You may obtain a copy of the License at:
 *                        opensource.org/licenses/BSD-3-Clause
#include "pins_arduino.h"
#ifdef __cplusplus
extern "C" {
// Digital PinName array
// This array allows to wrap Arduino pin number(Dx or x)
// to STM32 PinName (PX_n)
const PinName digitalPin[] = {
  //PX_n, //Dx
  PB_9,  //D0
  PC_14, //D1
  PC_15, //D2
  PA_0,  //D3
  PA_1,  //D4
  PA_2,  //D5
  PA_3,  //D6
  PA_4,  //D7
  PA_5,  //D8
  PA_6,  //D9
  PA_7,  //D10
  PB_0,  //D11
  PB_1,  //D12
  PB_2,  //D13 - LED
  PA_8,  //D14//A0
  PA_9,  //D15//A1
  PC_6,  //D16//A2
  PA_10, //D17//A3
  PA_11, //D18//A4
  PA_12, //D19//A5
  PA_13, //D20//A6
  PA_14, //D21 - STLink Tx (no A7)
  PA_15, //D22 - STLink Rx
  PB_3,  //D23
  PB_4,  //D24
  PB_5,  //D25
  PB_6,  //D26
  PB_7,  //D27
  PB_8  //D28
#ifdef __cplusplus
#ifdef __cplusplus
extern "C" {
  * @brief  System Clock Configuration
  * @param  None
  * @retval None
WEAK void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
  RCC_OscInitStruct.PLL.PLLN = 8;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
    Error_Handler();
                              |RCC_CLOCKTYPE_PCLK1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  /** Initializes the peripherals clocks
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    Error_Handler();
#ifdef __cplusplus
And the code for the variant.h file
#ifndef _VARIANT_ARDUINO_STM32_
#define _VARIANT_ARDUINO_STM32_
#ifdef __cplusplus
extern "C" {
#endif // __cplusplus
 *        Pins
// digital
#define PB9  0
#define PC14 1
#define PC15 2
#define PA0  3
#define PA1  4
#define PA2  5
#define PA3  6
#define PA4  7
#define PA5  8
#define PA6  9
#define PA7  10
#define PB0  11
#define PB1  12
#define PB2  13
#define PA8  14
#define PA9  15
#define PC6  16
#define PA10 17
#define PA11 18
#define PA12 19
#define PA13 20
#define PA14 21
#define PA15 22
#define PB3  23
#define PB4  24
#define PB5  25
#define PB6  26
#define PB7  27
#define PB8  28
// This must be a literal
// It is used with preprocessor tests (e.g. #if NUM_DIGITAL_PINS > 3)
// so an enum will not work.
#define NUM_DIGITAL_PINS        29
// Allow to define Arduino style alias for analog input pin number --> Ax
// If no analog pin required then NUM_ANALOG_INPUTS could not be defined
// or set to `0`
// All pins are digital, analog inputs are a subset of digital pins.
// It is used with preprocessor tests (e.g. #if NUM_ANALOG_INPUTS > 3)
// !!! It must be aligned with the number of analog PinName
// !!! defined in digitalPin[] array in variant.cpp
#define NUM_ANALOG_INPUTS       0
// They are 2 possibles way to define analog pins:
//   - If they are contiguous in the digitalPin array:
//     Simply defined `NUM_ANALOG_FIRST` and all pins Ax will be automatically defined.
//     It define the digital pin number of the first analog input  (i.e. which digital pin is A0)
//     First analog pin value (A0) must be greater than or equal to NUM_ANALOG_INPUTS
//     This must be a literal with a value less than or equal to MAX_ANALOG_INPUTS
//     defined in pin_arduino.h
#define NUM_ANALOG_FIRST        14
//------------------------------------OR------------------------------------------------------
//   - If they are not contiguous in the digitalPin array:
//     Add an analogInputPin array in the variant.cpp without defining NUM_ANALOG_FIRST
//     In that case the defined PYn for analog pin have to define the Ax definition instead of
//     index in digitalPin[] array:
//     #define PA4  A14
// Below ADC and PWM definitions already done in the core
// Could be redefined here if needed
// ADC resolution is 10 bits
//#define ADC_RESOLUTION          10
// PWM resolution
//#define PWM_RESOLUTION          8
//#define PWM_FREQUENCY           1000
//#define PWM_MAX_DUTY_CYCLE      255
// On-board LED pin number
//#define LED_BUILTIN             25
//#define LED_GREEN               LED_BUILTIN
// On-board user button
//#define USER_BTN                1
// Below SPI and I2C definitions already done in the core
// Could be redefined here if differs from the default one
// SPI Definitions
#define PIN_SPI_SS              7 // Default for Arduino connector compatibility
#define PIN_SPI_MOSI            5 // Default for Arduino connector compatibility
#define PIN_SPI_MISO            9 // Default for Arduino connector compatibility
#define PIN_SPI_SCK             4 // Default for Arduino connector compatibility
// I2C Definitions
//#define PIN_WIRE_SDA            14 // Default for Arduino connector compatibility
//#define PIN_WIRE_SCL            15 // Default for Arduino connector compatibility
// I2C timing definitions (optional), avoid time spent to compute if defined
// * I2C_TIMING_SM for Standard Mode (100kHz)
// * I2C_TIMING_FM for Fast Mode (400kHz)
// * I2C_TIMING_FMP for Fast Mode Plus (1000kHz)
//#define I2C_TIMING_SM           0x00000000
//#define I2C_TIMING_FM           0x00000000
//#define I2C_TIMING_FMP          0x00000000
// Timer Definitions (optional)
// Use TIM6/TIM7 when possible as servo and tone don't need GPIO output pin
#define TIMER_TONE              TIM16
#define TIMER_SERVO             TIM17
// UART Definitions
// Define here Serial instance number to map on Serial generic name
#define SERIAL_UART_INSTANCE    1 //ex: 2 for Serial2 (USART2)
// DEBUG_UART could be redefined to print on another instance than 'Serial'
//#define DEBUG_UART              ((USART_TypeDef *) U(S)ARTX) // ex: USART3
// DEBUG_UART baudrate, default: 9600 if not defined
//#define DEBUG_UART_BAUDRATE     x
// DEBUG_UART Tx pin name, default: the first one found in PinMap_UART_TX for DEBUG_UART
//#define DEBUG_PINNAME_TX        PX_n // PinName used for TX
// Default pin used for 'Serial' instance (ex: ST-Link)
// Mandatory for Firmata
#define PIN_SERIAL_RX           PA10
#define PIN_SERIAL_TX           PA9
// Optional PIN_SERIALn_RX and PIN_SERIALn_TX where 'n' is the U(S)ART number
// Used when user instanciate a hardware Serial using its peripheral name.
// Example: HardwareSerial mySerial(USART3);
// will use PIN_SERIAL3_RX and PIN_SERIAL3_TX if defined.
#define PIN_SERIAL1_RX          PA10 // For U(S)ARTn RX
#define PIN_SERIAL1_TX          PA9 // For U(S)ARTn TX
//#define PIN_SERIALLP1_RX        x // For LPUART1 RX
//#define PIN_SERIALLP1_TX        x // For LPUART1 TX
// SD card slot Definitions
// SD detect signal can be defined if required
//#define SD_DETECT_PIN           x
// SD Read/Write timeout, default value defined in STM32SD library
//#define SD_DATATIMEOUT          x
// USB Vbus sensing. Require to have Vbus pin connected to Vbus signal.
// Warning, pin is different depending on FullSpeed or High Speed mode used
// See AN4879 https://www.st.com/content/st_com/en/search.html#q=AN4879-t=resources-page=1
//#define USBD_VBUS_DETECTION_ENABLE
// If the board has external USB pullup (on DP/DM depending on speed)
// that can be controlled using a GPIO pin, define these:
//  - If the the pullup is disabled (USB detached) by default, define
//    USBD_ATTACH_PIN to the pin that, when written to
//    USBD_ATTACH_LEVEL, attaches the pullup.
//  - If the the pullup is enabled (attached) by default, define
//    USBD_DETACH_PIN to the pin that, when written to
//    USBD_DETACH_LEVEL, detaches the pullup.
//#define USBD_ATTACH_PIN x
//#define USBD_ATTACH_LEVEL LOW
//#define USBD_DETACH_PIN x
//#define USBD_DETACH_LEVEL LOW
// This indicates that there is an external and fixed 1.5k pullup
// on the D+ line. This define is not normally needed, since a
// fixed pullup is assumed by default. It is only required when
// the USB peripheral has an internal pullup *and* an external
// fixed pullup is present (which is actually a hardware bug, since just
// the internal pullup is sufficient and having two pullups violates the
// USB specification). In this case, defining this forces
// the "write D+ LOW"-trick to be used. In the future, it might also
// disable the internal pullups, but this is not currently implemented.
// #define USBD_FIXED_PULLUP
#ifdef __cplusplus
} // extern "C"
 *        Arduino objects - C++ only
#ifdef __cplusplus
  // These serial port names are intended to allow libraries and architecture-neutral
  // sketches to automatically default to the correct port name for a particular type
  // of use.  For example, a GPS module would normally connect to SERIAL_PORT_HARDWARE_OPEN,
  // the first hardware serial port whose RX/TX pins are not dedicated to another use.
  // SERIAL_PORT_MONITOR        Port which normally prints to the Arduino Serial Monitor
  // SERIAL_PORT_USBVIRTUAL     Port which is USB virtual serial
  // SERIAL_PORT_LINUXBRIDGE    Port which connects to a Linux system via Bridge library
  // SERIAL_PORT_HARDWARE       Hardware serial port, physical RX & TX pins.
  // SERIAL_PORT_HARDWARE_OPEN  Hardware serial ports which are open for use.  Their RX & TX
  //                            pins are NOT connected to anything by default.
  #define SERIAL_PORT_MONITOR     Serial
  #define SERIAL_PORT_HARDWARE    Serial
#endif /* _VARIANT_ARDUINO_STM32_ */
One last thing that I noticed was that by default the SPI pins and USART pins are moved to their alternative location. I don't know if this is on purpose or not.
Thanks again!
This is not the correct fix as you define IRQ handlers which does not exist.
Hi @sr28
I've made a fix:
sr28
Post by sr28 »
Hi @fpiSTM
I've just applied those changes and as far as I can tell everything is working perfectly!
Thanks for your help!
Would it be useful to have my boards.txt configuration as well so the Generic G070KB processor can be added?
Is there also a reason why this processor uses the alternative UART pins by default?
Thanks!
I've tested but not added the Nucleo G070KB as I don't have it for test.
Moreover I'm currently reworking all variants to be more generic and ease integration and deployment of new boards.
For UART, I don't know anyway why not ? ;)
