AsyncWebServer_STM32 for STM32 using LAN8720 or builtin LAN8742A Ethernet
Posted: Wed Sep 02, 2020 11:46 pm
Why do we need this Async AsyncWebServer_STM32 Library
- Using asynchronous network means that you can handle more than one connection at the same time
- You are called once the request is ready and parsed
- When you send the response, you are immediately ready to handle other connections while the server is taking care of sending the response in the background
- Speed is OMG
- Easy to use API, HTTP Basic and Digest MD5 Authentication (default), ChunkedResponse
- Easily extendible to handle **any type of content**
- Supports Continue 100%
- Async WebSocket plugin offering different locations without extra servers or ports
- Async EventSource (Server-Sent Events) plugin to send events to the browser
- URL Rewrite plugin for conditional and permanent url rewrites
- ServeStatic plugin that supports cache, Last-Modified, default index and more
- Simple template processing engine to handle templates
Initial Releases v1.2.3
1. Initial coding to port the powerful ESPAsyncWebServer Library to STM32 boards using builtin LAN8742A Ethernet. More supports will be added gradually later, such as AsyncUDP, other Ethernet / WiFi shields.
2. Add more examples.
3. Add debugging features.
4. Bump up to v1.2.3 to sync with ESPAsyncWebServer v1.2.3.
Currently Supported Boards
1. Nucleo-144 (F429ZI, F746ZG, F756ZG, F767ZI)
2. Discovery STM32F746G-DISCOVERY
3. Any STM32 boards with enough flash/memory and already configured to run LAN8742A Ethernet.
This is the Async_HelloServer example
and the WebBrowser screen when running Async_AdvancedWebServer example
- Speed is OMG
Currently support
1) STM32 boards with built-in Ethernet (to use USE_BUILTIN_ETHERNET = true) such as :
- Nucleo-144 (F429ZI, F767ZI)
- STM32 boards (STM32F/L/H/G/WB/MP1) with 32K+ Flash, with Built-in Ethernet,
- See How To Use Built-in Ethernet at (https://github.com/khoih-prog/EthernetWebServer_STM32/issues/1)
#if !( defined(STM32F0) || defined(STM32F1) || defined(STM32F2) || defined(STM32F3) ||defined(STM32F4) || defined(STM32F7) || \
defined(STM32L0) || defined(STM32L1) || defined(STM32L4) || defined(STM32H7) ||defined(STM32G0) || defined(STM32G4) || \
defined(STM32WB) || defined(STM32MP1) )
#error This code is designed to run on STM32F/L/H/G/WB/MP1 platform! Please check your Tools->Board setting.
#if defined(STM32F0)
#warning STM32F0 board selected
#define BOARD_TYPE "STM32F0"
#elif defined(STM32F1)
#warning STM32F1 board selected
#define BOARD_TYPE "STM32F1"
#elif defined(STM32F2)
#warning STM32F2 board selected
#define BOARD_TYPE "STM32F2"
#elif defined(STM32F3)
#warning STM32F3 board selected
#define BOARD_TYPE "STM32F3"
#elif defined(STM32F4)
#warning STM32F4 board selected
#define BOARD_TYPE "STM32F4"
#elif defined(STM32F7)
#warning STM32F7 board selected
#define BOARD_TYPE "STM32F7"
#elif defined(STM32L0)
#warning STM32L0 board selected
#define BOARD_TYPE "STM32L0"
#elif defined(STM32L1)
#warning STM32L1 board selected
#define BOARD_TYPE "STM32L1"
#elif defined(STM32L4)
#warning STM32L4 board selected
#define BOARD_TYPE "STM32L4"
#elif defined(STM32H7)
#warning STM32H7 board selected
#define BOARD_TYPE "STM32H7"
#elif defined(STM32G0)
#warning STM32G0 board selected
#define BOARD_TYPE "STM32G0"
#elif defined(STM32G4)
#warning STM32G4 board selected
#define BOARD_TYPE "STM32G4"
#elif defined(STM32WB)
#warning STM32WB board selected
#define BOARD_TYPE "STM32WB"
#elif defined(STM32MP1)
#warning STM32MP1 board selected
#define BOARD_TYPE "STM32MP1"
#else
#warning STM32 unknown board selected
#define BOARD_TYPE "STM32 Unknown"
#ifndef BOARD_NAME
#define BOARD_NAME BOARD_TYPE
#include <LwIP.h>
#include <STM32Ethernet.h>
#include <AsyncWebServer_STM32.h>
#define NUMBER_OF_MAC 20
byte mac[][NUMBER_OF_MAC] =
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x01 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x02 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x03 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x04 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x05 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x06 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x07 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x08 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x09 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x0A },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x0B },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x0C },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x0D },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x0E },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x0F },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x10 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x11 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x12 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x13 },
{ 0xDE, 0xAD, 0xBE, 0xEF, 0x32, 0x14 },
// Select the IP address according to your local network
IPAddress ip(192, 168, 2, 232);
AsyncWebServer server(80);
const int led = 13;
void handleRoot(AsyncWebServerRequest *request)
digitalWrite(led, 1);
request->send(200, "text/plain", String("Hello from AsyncWebServer_STM32 on ") + BOARD_NAME );
digitalWrite(led, 0);
void handleNotFound(AsyncWebServerRequest *request)
String message = "File Not Found\n\n";
message += "URI: ";
//message += server.uri();
message += request->url();
message += "\nMethod: ";
message += (request->method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += request->args();
message += "\n";
for (uint8_t i = 0; i < request->args(); i++)
message += " " + request->argName(i) + ": " + request->arg(i) + "\n";
request->send(404, "text/plain", message);
void setup(void)
pinMode(led, OUTPUT);
Serial.println("\nStart Async_HelloServer on " + String(BOARD_NAME));
// start the ethernet connection and the server
// Use random mac
// Use Static IP
Ethernet.begin(mac[index]);
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request)
handleRoot(request);
server.on("/inline", [](AsyncWebServerRequest * request)
request->send(200, "text/plain", "This works as well");
server.begin();
Serial.print(F("HTTP EthernetWebServer is @ IP : "));
void loop(void)
