[Forum] Extensions
[Forum] Extensions
Following Vassilis recommendation, the following extensions have been added:
• Privacy policy (for GPDR)
https://github.com/david63/privacypolicy
• highlighter
https://github.com/s9e/phpbb-ext-highlighter/
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
• Simple mentions
https://www.phpbb.com/customise/db/exte ... e_mentions
This extensions add support for mentioning a user by starting to type a @ in the posting field.
Once you select a user from the dropdown, the
[mention]
BBCode will be inserted and after submitting the post it will create a notification to that user.
@fpiSTM
• Best answer
https://www.phpbb.com/customise/db/exte ... st_answer/
https://github.com/kinerity/bestanswer
by fpiSTM » Thu Jan 02, 2020 2:22 pm
Is it the best answer ?
Yes
Re: [Forum] Extensions
Yes
Jblb
Post by Jblb »
Hi @Jblb
I thought to add it as it is really useful like on GitHub.
So, it's done. ;)
Return to “Forum rules, FAQs and HowTo's”
