Issue with Installing and Uploading to Blue Pill
How to install core into the Arduino IDE, and any OS specific issues
safi_huss
Post by safi_huss »
I am a newbie here so I must be doing something wrong here.
I installed the bootloader (generic_boot20_pc13.bin) and installed the boards on ArduinoIDE, copied the Arduino_STM32 folder and ran the install_driver.bat file.
After the first code upload the blue pill since flashing with the bootloader. I get the following output in my IDE.
Sketch uses 9968 bytes (7%) of program storage space. Maximum is 131072 bytes.
Global variables use 844 bytes (4%) of dynamic memory, leaving 19636 bytes for local variables. Maximum is 20480 bytes.
maple_loader v0.1
Found it!
Found Runtime: [0x1eaf:0x0003] devnum=1, cfg=0, intf=0, alt=2, name="STM32duino bootloader v1.0  Upload to Flash 0x8002000"
Setting Configuration 1...
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0400
bytes_per_hash=205
error resetting after download: usb_reset: could not reset device, win error: A device which does not exist was specified.
Done!
timeout waiting for COM3 serial
The blue pill is running the sketch though, but all subsequent uploads fail with the following:
maple_loader v0.1
I also checked the device manager and the COM3 port which was available before the first upload is missing. There is also an Unknown USB device.
I don't know what I did wrong. Please help.
Re: Issue with Installing and Uploading to Blue Pill
Welcome to the forum. Before next post, read viewtopic.php?f=2&t=301
Disregard... board programmed just fine... to reload, read viewtopic.php?t=223
Deeper explanations...
https://www.google.com/search?&q=timeou ... oforum.com
In order the automatic reset (to DFU serial) to work you have to upload a sketch in which you use serial USB.
Otherwise you have to set BOOT 1 to high and reset the board each time before next upload. Then set BOOT1 back to low and reset.
DMaisterra
Post by DMaisterra »
Sometimes when it not found the dfu device, its because whe upload is triggered and DFU mode activated with vid 0003 , reset its fast enough or to fast to not see the change..
Im collected a couple a scripts to detects the timing and then change it. Its in a git repo...
For myself reduces the problem to zero, its usefull for forgetting to press the reset button of bluepill...
https://github.com/DMaisterra/stm32duin ... etting.git
Chears
Ghani
Post by Ghani »
hey DMaisterra, i have the same probleme and i download the files .sh but i don't where i must copy the files in the hardware file in arduino?! and thanks in advance.
Return to “Installation and OS related”
