Correct usage of HAL functions in Arduino code
kvv213
Post by kvv213 »
Hello every one again!
I have a question according to a correct usage of HAL functions inside Arduino code.
For example, I'd like to use my custom board with STM32F103RE and use DMA processing of the chips ADC.
I have code that more or less works in cube code generated. And I took everything that concerns ADC from it and integrated into my arduino code:
#include <Arduino.h>
#include "stm32f1xx_hal.h"
ADC_HandleTypeDef hadc1;
DMA_HandleTypeDef hdma_adc1;
unsigned short adc_value[8];
extern "C" void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {};
  /* Initializes the CPU, AHB and APB busses clocks */
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) {
    Error_Handler();
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC | RCC_PERIPHCLK_USB;
  PeriphClkInit.AdcClockSelection = RCC_ADCPCLK2_DIV6;
  PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL_DIV1_5;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK) {
    Error_Handler();
static void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  hadc1.Instance = ADC1;
  hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 8;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
	sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = ADC_REGULAR_RANK_2;
    Error_Handler();
	sConfig.Channel = ADC_CHANNEL_2;
  sConfig.Rank = ADC_REGULAR_RANK_3;
    Error_Handler();
	sConfig.Channel = ADC_CHANNEL_3;
  sConfig.Rank = ADC_REGULAR_RANK_4;
    Error_Handler();
	sConfig.Channel = ADC_CHANNEL_6;
  sConfig.Rank = ADC_REGULAR_RANK_5;
    Error_Handler();
	sConfig.Channel = ADC_CHANNEL_7;
  sConfig.Rank = ADC_REGULAR_RANK_6;
    Error_Handler();
	sConfig.Channel = ADC_CHANNEL_8;
  sConfig.Rank = ADC_REGULAR_RANK_7;
    Error_Handler();
	sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = ADC_REGULAR_RANK_8;
    Error_Handler();
 HAL_ADCEx_Calibration_Start(&hadc1);
  HAL_Init();
  SystemClock_Config();
  MX_ADC1_Init();
  HAL_ADC_Start_DMA(&hadc1, (uint32_t *)&adc_value, 8);
The code compiles but it falls into an infinite loop at the last string.
Actually it falls at this string (in stm32f1xx_hal_adc.c):
/* Set the DMA half transfer complete callback */
hadc->DMA_Handle->XferHalfCpltCallback = ADC_DMAHalfConvCplt;
I've googled for additional info but with no success. What can be wrong? I feel that there can be a problem with initialization of something (STM32 registers) but don't know what is the right way for HAL inside Arduino usage.
Answers: 109
Re: Correct usage of HAL functions in Arduino code
HAL_ADC_Init
will call
HAL_ADC_MspInit
This HAL_ADC_MspInit is defined in the analog API of the core and use the pinmap feature to configure properly the GPIO.
I advise you to disable all Arduino analog using the 0HAL ADC.
To do this you can define:
HAL_ADC_MODULE_ONLY
using the hal_conf_extra.h:
See https://github.com/stm32duino/wiki/wiki ... odule-only
Note that you do not need to call
  HAL_Init();
They are already called before.
Finally, I didn't see any DMA config ? (clock, IRQ,...)
kvv213
Post by kvv213 »
Did as you recommended :)
The result is the same. Infinite loop at:
HAL_ADC_MODULE_ONLY enabled via -DHAL_ADC_MODULE_ONLY option to compiler.
The first time I indeed forgot about DMA settings. But its presence doesn't make any sense.
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
    Error_Handler();
static void MX_DMA_Init(void)
  /* DMA controller clock enable */
  __HAL_RCC_DMA1_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA1_Channel1_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
  Serial.setRx(UART_RX);
  Serial.setTx(UART_TX);
  MX_DMA_Init();
  MX_ADC1_Init();
  Serial.println("Go On!");
  Serial.println("ADCs: "+((String)adc_value[0])+":"+(String)adc_value[1]+":"+(String)adc_value[2]+":"+(String)adc_value[3]+":"+(String)adc_value[4]+":"+(String)adc_value[4]+":"+(String)adc_value[6]+":"+(String)adc_value[7]);
Answers: 109
Well, it seems it is always incomplete, it misses the GPIO config, the ADC clock enable,...
And where the DMA1_Channel1_IRQHandler is defined?
By default it fallback to Default_Handler:
  .thumb_set DMA1_Channel1_IRQHandler,Default_Handler
which is an infinite loop ;)
kvv213
Post by kvv213 »
I may be wrong, but as I understand the code:
it enables DMA1_Channel1_IRQn IRQ-handler. That is defined at stm32f103xe.h driver as
DMA1_Channel1_IRQn = 11, /*!< DMA1 Channel 1 global Interrupt */
This code works if I compile it under Keil. But not under Arduino. Or I understand this wrong?
Answers: 109
Yes this enable the IRQ, but when the IRQ raised what should be done ?
kvv213
Post by kvv213 »
fpiSTM wrote: Mon Jan 06, 2020 1:55 pm Yes this enable the IRQ, but when the IRQ raised what should be done ?
In my understanding the following should happen:
1. Chip does some ADC measurments in infinite cycle.
2. When it measures enough it rises interrupt "TCIE: Transfer complete interrupt enable"
3. And in that interrupt it should populate my array adc_value.
4. When I need I can query my array and receive fresh values.
As I understand the problem is somewhere around "TCIE: Transfer complete interrupt enable". It is not defined or defined in a wrong way.
My problem is that I don't understand where I need to define the handler for this interrupt and why Cube code works without this. Arduino code is almost 100% copy of the cube code. :?
Added the following code:
void DMA1_Channel1_IRQHandler(void)
  HAL_DMA_IRQHandler(&hdma_adc1);
No success. Infinite loop at the same position for Half Transfer Complete call.... Should I define the handler for it somehow?
HAL codes are complicated, i messed a little into it in VSCode
apparently when i typed HAL_ADC, VSCode didn't even find the completions,
the code stacks are very large and deep due to the multitude of supported skus, and the sheer set of features
good luck for the effort, i'd let go for now didn't quite get started with adc as well
perhaps i'd install Cube as well so that i'd have a reference of working codes
i'm wondering if somehow i need to set the include paths in the VSCode c++ extension, so far hit a blank as well
:lol:
i'm messing with my f401 pill board as that is what i've on my table.reading the ref manual
DMA_SCxR (dma configuration) register has 2 flags TCIE - transfer complete interrupt enable, HTIE - half transfer interrupt enable
so presumably both interrupt calls the same irq handler?
then in DMA_LISR and DMA_HISR interrupt status register there are 2 more flags TCIFx and HTIFx and one'd need to read and clear that flag when you are done handling the interrupt
it seemes cube patched a default interrupt handler so that it looks like everything is working
hope it helps, i'm way far from even reaching dma
can't find the codes for the vector table the actual definition itself
but do take note of this particular piece during system init
there is a particular define VECT_TAB_SRAM
https://github.com/stm32duino/Arduino_C ... 4xx.c#L198
if that is defined, my guess is it sets up the vector table in sram, otherwise in flash
what i do not understand is if it is
VECTOR_TAB -> HAL_handler -> user adc interrupt hook
or
VECTOR_TAB -> user adc interrupt hook
if it is the 2nd case, my guess is setting the hook would throw a hardfault. it is flash not sram.
for the 2nd case, define VECT_TAB_SRAM may solve the issue.
while the 1st case, it is actually better as that should point to a fixed HAL function while the hal function calls user code, presumably from a pointer in sram
add: found VECTOR_TAB in the start up assembly code
https://github.com/stm32duino/Arduino_C ... 1xc.s#L312
so try to define VECT_TAB_SRAM to see if it helps to resolve the issue
then the next big catch is would you after all need to call
VECTOR_TAB->DMA1_Stream0_IRQHandler = &MyDMAIRQHandler
(it seemed that would read g_pfnVectors->DMA1_Stream0_IRQHandler = &MyDMAIRQHandler; )
and i'm not sure if a interrupt vector can call a regular C or C++ function / method after all
:lol:
hi fpistm,
i noted something strange in the codes for analogRead().
analogRead() seem to call a function adc_read_value()
https://github.com/stm32duino/Arduino_C ... log.c#L164
i found the declaration in the headers, but it seemed it isn't implemented. i.e. a search or reference jump did not find the definition
I'm not too sure if it is after all true
Answers: 109
I've answered you :mrgreen:
If the functions was not defined this simply not build as the linker will not find any reference.
